» LF extended back rest
Sliders weights for my Voyager trike I_icon_minitimeby Rzor93 Today at 4:29 pm
» Goodbye guys
Sliders weights for my Voyager trike I_icon_minitimeby Rzor93 Today at 4:27 pm
» noise under load
Sliders weights for my Voyager trike I_icon_minitimeby dmosemorris Yesterday at 1:30 pm
» checking the oil
Sliders weights for my Voyager trike I_icon_minitimeby arcamedies13 Yesterday at 9:32 am
Sliders weights for my Voyager trike I_icon_minitimeby Terry Smith Thu May 16, 2024 6:39 pm
» Hello from Illinois!
Sliders weights for my Voyager trike I_icon_minitimeby DescendingRaven Wed May 15, 2024 2:13 pm
» Silverwing Brakes
Sliders weights for my Voyager trike I_icon_minitimeby Terry Smith Tue May 14, 2024 11:57 pm
Sliders weights for my Voyager trike I_icon_minitimeby BrianInVA Mon May 13, 2024 12:53 pm
» Left brake micro-switch
Sliders weights for my Voyager trike I_icon_minitimeby Johnboy Fri May 10, 2024 7:57 pm
Sliders weights for my Voyager trike I_icon_minitimeby BrianInVA Fri May 10, 2024 5:36 pm
4 posters
Sliders weights for my Voyager trike Empty
PostSubject: Sliders weights for my Voyager trike   Sliders weights for my Voyager trike I_icon_minitimeMon Oct 08, 2018 3:05 pm
Now that all maintenance is done on my 2004 Swing trike, should I be considering a slider weight replacement? It currently has the original rollers. With the additional weight of the trike, should lighter slider weight be better?
I'm thinking 22g sliders.
Number of posts : 3299
PostSubject: Re: Sliders weights for my Voyager trike   Sliders weights for my Voyager trike I_icon_minitimeMon Oct 08, 2018 3:25 pm
I would stick with fresh OEM sliders/rollers and Belt. trike you are asking drive train to do something it was never designed for----older bike probably needs fresh belt anyway. I speak from over 90,000 miles of SilverWing miles on 2 new SilverWings.....and never walked.
Number of posts : 1987
PostSubject: Re: Sliders weights for my Voyager trike   Sliders weights for my Voyager trike I_icon_minitimeMon Oct 08, 2018 6:13 pm
I put 26 gram sliders in mine when it was still a two wheeler and haven't changed them. I agree that the belt does have more work to do so I don't try Popping Wheelies with it. I take off rather calmly but accelerate good once it gets rolling. I'm still going to change the belt at recommended intervals but not going to change the sliders.
I suppose it's something like a car with a standard tranny. If you pop the clutch and try to "peel out" at every intersection the clutch and tranny aren't going to last all that long before repairs are needed.
PostSubject: Re: Sliders weights for my Voyager trike   Sliders weights for my Voyager trike I_icon_minitimeMon Oct 08, 2018 7:25 pm
John,
If you read my prior posts you would have read that I just installed a new belt a couple of weeks ago. That is when I discovered that the trike had the original rollers with a lot of flat spots. It was to late to order replacement. Due to the extra weight of the trike, I was trying to gather information from existing trike owners if they changed their weights. Or are thinking of changing them.
Number of posts : 1382
PostSubject: Re: Sliders weights for my Voyager trike   Sliders weights for my Voyager trike I_icon_minitimeMon Oct 08, 2018 8:40 pm
How much does the trike kit weigh? What are tire diameters compared to stock rear tire?
Is the engine speed similar to your other SW? There are many factors to consider.
Sliders all have the same shape its just RPM when they fully move out. I have 26G work fine but not a trike. 22G will help with acceleration work fine at highway speeds.
PostSubject: Re: Sliders weights for my Voyager trike   Sliders weights for my Voyager trike I_icon_minitimeMon Oct 08, 2018 9:21 pm
The kit weighs 195 lbs including the two 13inch chrome wheels and tires.
Engine speed is similar on a flat surface. Gas mileage is down to around 40 MPG. I have the GIVI AF214 screen which is wider. I ride two up. I was thinking that the lighter weights will help accelerating from a standing start, NOT to do jack rabbit starts. The lighter weight may put less stress on the drive components.
PostSubject: Re: Sliders weights for my Voyager trike   Sliders weights for my Voyager trike I_icon_minitimeMon Oct 08, 2018 9:57 pm
That's not very heavy. A large passenger could weigh that much. SW has a very low loaded weight rating but most bikes do and are often pushed beyond that. 3 wheels can handle that and a passenger.
Belt is the most stressed part. Go with the 22G gas mileage might improve compared to worn rollers and a steady throttle hand.
PostSubject: Re: Sliders weights for my Voyager trike   Sliders weights for my Voyager trike I_icon_minitimeMon Oct 08, 2018 11:15 pm
For added load...like sidecar...rules used to be 20% lowering of overall gearing. I assume 3 wheel conversion/training wheels provide probably more drag than loaded sidecar..... but will rollers alone lower overall gearing? 40MPG is indicator to me, engine is working too hard.
I rode sidecar outfits for 40 years so have some experience in selecting proper overall gearing.
My idea, SilverWing as Trike or training wheel conversion, may be alright for simple around town riding---low annual mileage.....but serious long distance trips?? How about steering damper? different trail front fork. Braking?ABS? My idea is not to get killed or run out of control.
PostSubject: Re: Sliders weights for my Voyager trike   Sliders weights for my Voyager trike I_icon_minitimeTue Oct 09, 2018 4:32 am
My 2004 Swing has always been a trike. The PO had the kit installed for his wife when they purchased the bike new. The Swing handles the added weight just fine. I don't usually race off of the light, but it has a lot of reserve power if needed. Never felt any lack of power when touring.
UPDATE: Just ordered 22g sliders and sliding pieces through the promotion from Dr. pulley. Thanks Daniel.
» 03 and 08 Silverwings, one with voyager trike kit
»  Voyager trike kit forsale
» Silverwing 600 trike vs non trike
» Had it up to 130 KPH for the first time
» Dr Pulley sliding weights vs rolling weights
Honda Silver Wing Scooter Forum :: Other Scooters and Motorcycles :: Trikes-
