» Goodbye guys
2008 Honda fes 125 Honda s-wing I_icon_minitimeby GHM-PM Today at 7:58 am
» noise under load
2008 Honda fes 125 Honda s-wing I_icon_minitimeby dmosemorris Yesterday at 1:30 pm
» checking the oil
2008 Honda fes 125 Honda s-wing I_icon_minitimeby arcamedies13 Yesterday at 9:32 am
2008 Honda fes 125 Honda s-wing I_icon_minitimeby Terry Smith Thu May 16, 2024 6:39 pm
» Hello from Illinois!
2008 Honda fes 125 Honda s-wing I_icon_minitimeby DescendingRaven Wed May 15, 2024 2:13 pm
» Silverwing Brakes
2008 Honda fes 125 Honda s-wing I_icon_minitimeby Terry Smith Tue May 14, 2024 11:57 pm
» LF extended back rest
2008 Honda fes 125 Honda s-wing I_icon_minitimeby Frenchy Mon May 13, 2024 7:57 pm
2008 Honda fes 125 Honda s-wing I_icon_minitimeby BrianInVA Mon May 13, 2024 12:53 pm
» Left brake micro-switch
2008 Honda fes 125 Honda s-wing I_icon_minitimeby Johnboy Fri May 10, 2024 7:57 pm
2008 Honda fes 125 Honda s-wing I_icon_minitimeby BrianInVA Fri May 10, 2024 5:36 pm
3 posters
Barryjones2010
Number of posts : 1
Registration date : 2019-05-30
2008 Honda fes 125 Honda s-wing Empty
PostSubject: 2008 Honda fes 125 Honda s-wing   2008 Honda fes 125 Honda s-wing I_icon_minitimeThu May 30, 2019 2:39 pm
I am having oil seep from the drive belt case. Any ideas with this could be coming from ?
AldusFran
Number of posts : 204
PostSubject: Re: 2008 Honda fes 125 Honda s-wing   2008 Honda fes 125 Honda s-wing I_icon_minitimeThu May 30, 2019 7:03 pm
Barry I think someone over filled the rear gear box, What I do is remove the plastic covers and aluminum belt cover and remove the filler bolt for the rear gear box so I can see and prevent oil from getting anyplace else (rags). If you follow the Silverwing's service manual way of checking oil level; oil can get into your belt case. My way takes a little longer but meanwhile you can check condition of belt and clean housing. Do you know last time oil was changed?
Number of posts : 397
PostSubject: Re: 2008 Honda fes 125 Honda s-wing   2008 Honda fes 125 Honda s-wing I_icon_minitimeThu May 30, 2019 10:43 pm
Is it from the small weep hole on the bottom of the clutch housing? Did you have oil spatter on the left side of your rear rim?
If so, gear oil is the likely culprit. I had some oil inside the belt case and as described above due to overfilling the final drive oil. You turn the rear wheel in its forward direction to help drain the oil, but you DO NOT turn it as you fill the oil. I did that and overfilled, which produced the oil weeping and spatter.
I changed the oil again and put in EXACTLY .32 liters of oil and the problem disappeared.
I talked to two mechanics trying to solve this and both said, "Honda's don't leak." So I concluded the problem was operator error.
Also, taking off the covers for this oil change is a good idea because you can be very precise about filling the oil.
» 2008 Silver Wing
» 2008 S Wing finally running
» New member with 2008 Silver Wing
» Honda Silver Wing 600
» Honda Silver Wing bestbackrests
Honda Silver Wing Scooter Forum :: Other Scooters and Motorcycles-
