| Brake disc thickness | |
agreat Scooter Rider
Number of posts : 32 Location : Ware, UK Points : 4105 Registration date : 2013-04-03
| Subject: Brake disc thickness Sat Sep 28, 2019 8:55 am | |
| Hi does anyone know what the minimum thickness of a rear disc should be? or should I buy a new one for £44 from Ebay. The pads wore out on a 220 mile ride and scored the disc badly. |
DLK Scooter Rider
Number of posts : 75 Location : Cincinnati Ohio Points : 1973 Registration date : 2019-04-01
| Subject: Re: Brake disc thickness Sat Sep 28, 2019 9:32 am | |
| Rear disk standard is 6.3mm-6.7mm or .25-.26" service limit 5.5mm or .22"
If it was scored it will need to be replaced. They are to thin to turn the rotor to remove any grooves.
Hope that helps Dan |
| Subject: Re: Brake disc thickness Sat Sep 28, 2019 12:05 pm | |
| Since these are now old bikes---I would buy new cheap brake pads, ride it and see how that works. Pads are not going to wear the groves out/off of the disk, probably. |
| Subject: Re: Brake disc thickness Sat Sep 28, 2019 1:20 pm | |
| Thank's I couldn't find that information. I'll get a new one 6.5mm not the 5.5mm ones that are cheaper. |
Lost it Maxi-Scooter Rider
Number of posts : 136 Age : 67 Location : Hayling Island UK Points : 1983 Registration date : 2019-05-13
| Subject: Re: Brake disc thickness Mon Sep 30, 2019 2:38 pm | |
| I'd do what John suggested first. Unless you were on the rear brakes a lot during that 220 mile run, there won't be that much damage to the disc, it's harder than the backing pad...
Some aftermarket Organic ones will tell you if it's too far gone. |
Number of posts : 221 Age : 70 Location : uk saddleworth Points : 3845 Registration date : 2014-08-24
| Subject: Re: Brake disc thickness Wed Oct 02, 2019 12:27 pm | |
| I have a like new rear disc that has its matching pads with it listed on ebay at £30 (no news on the wheels as yet) |
| Subject: Re: Brake disc thickness Wed Oct 02, 2019 4:17 pm | |
| Sadly I ordered 1 last night I've got the pads in the Garage. |
| Subject: Re: Brake disc thickness Thu Oct 03, 2019 4:26 pm | |
| I prefer organic brake pads on bikes. Unless you're into racing the organic pads work well and don't tend to damage the disk as metallic sintered pads do. |
| Subject: Re: Brake disc thickness | |
