Billy23 Guest
| Subject: Starting problem Tue May 26, 2020 11:57 am | |
| Hi Guys I have just put the battery onto the bike after the winter (I have had health problem otherwise would have done it before) everything works...except when I push the start button....nothing, the lights dont dim, just nothing. Any chance that someone could point me in a direction please. |
| Subject: Re: Starting problem Tue May 26, 2020 12:21 pm | |
| Have you checked the engine kill switch position? |
Billy23 Scooter Rider
Number of posts : 15 Age : 83 Location : Corby, Northants UK Points : 1730 Registration date : 2019-09-12
| Subject: Re: Starting problem Tue May 26, 2020 12:28 pm | |
| Yup have checked kill switch. beginning to think it is an earth problem, just got to figure out where to look :-) |
DickO Founding Member
Number of posts : 1018 Age : 79 Location : Atchison, KS Points : 6775 Registration date : 2008-12-23
Number of posts : 393 Age : 59 Location : Auckland, New Zealand Points : 1947 Registration date : 2020-03-11
| Subject: Re: Starting problem Wed May 27, 2020 1:00 am | |
| If the lights don't dim then that has to be the starter switch not working. When the starter button is pushed, as well as completing the circuit to the starter solenoid, the switch also cuts power to the lights. So if the lights are working but not cutting when the button is pushed, that would indicate the starter button mechanism needs to be cleaned.
steve_h80 Silver Wing Expert
| Subject: Re: Starting problem Wed May 27, 2020 2:04 am | |
| And the left brake switch, make sure that's not in need of a squirt of wd40. |
| Subject: Re: Starting problem Thu May 28, 2020 5:43 am | |
| Thank you very much, it was the switch, problem solved.
Cheers |
| Subject: Re: Starting problem | |
