» LF extended back rest
Ignition switch I_icon_minitimeby Rzor93 Today at 4:29 pm
» Goodbye guys
Ignition switch I_icon_minitimeby Rzor93 Today at 4:27 pm
» noise under load
Ignition switch I_icon_minitimeby dmosemorris Yesterday at 1:30 pm
» checking the oil
Ignition switch I_icon_minitimeby arcamedies13 Yesterday at 9:32 am
Ignition switch I_icon_minitimeby Terry Smith Thu May 16, 2024 6:39 pm
» Hello from Illinois!
Ignition switch I_icon_minitimeby DescendingRaven Wed May 15, 2024 2:13 pm
» Silverwing Brakes
Ignition switch I_icon_minitimeby Terry Smith Tue May 14, 2024 11:57 pm
Ignition switch I_icon_minitimeby BrianInVA Mon May 13, 2024 12:53 pm
» Left brake micro-switch
Ignition switch I_icon_minitimeby Johnboy Fri May 10, 2024 7:57 pm
Ignition switch I_icon_minitimeby BrianInVA Fri May 10, 2024 5:36 pm
 Ignition switch
kupid
kupid
Number of posts : 21
Registration date : 2020-01-01
Ignition switch Empty
PostSubject: Ignition switch   Ignition switch I_icon_minitimeSat Jun 06, 2020 4:01 pm
I have had this happen to me twice not able to get key in ignition switch so I'm thinking new ignition switch. I have tried WD 40 worked for a spell.
Number of posts : 1987
PostSubject: Re: Ignition switch   Ignition switch I_icon_minitimeSat Jun 06, 2020 4:07 pm
Sometimes on my 08 SWing the key gets fussy and doesn't want to go in easy. I have to wiggle it a bit to get it to line up, so to speak. then it goes in nicely. Other than that I haven't had any problems or trouble with it. And a shot of WD-40 now and then doesn't hurt either. Then I run the key in and out several times to "spread" the WD-40 on the pins in the lock.
kupid
PostSubject: Ignition switch   Ignition switch I_icon_minitimeSat Jun 06, 2020 4:31 pm
Thanks Dale N I will try that
PostSubject: Re: Ignition switch   Ignition switch I_icon_minitimeSat Jun 06, 2020 7:32 pm
Don’t use WD-40 in the lock. Go to the hardware store and get a small tube of lock graphite and use that. Graphite will lube the lock pins and tumbler. WD-40 may clean some crud from the lock but also dry out the pins and tumbler causing them to bind.
Number of posts : 3299
PostSubject: Re: Ignition switch   Ignition switch I_icon_minitimeSat Jun 06, 2020 9:07 pm
WD 40 worked fine for me
Number of posts : 999
PostSubject: Re: Ignition switch   Ignition switch I_icon_minitimeSun Jun 07, 2020 3:26 am
It seems to be a Honda thing, both Scootie and the CBF1000 often need a bit of jiggery to get the key to line up. Be careful what you squirt into locks though as it can cause problems, I usually use a tiny bit of light oil.
PostSubject: Re: Ignition switch   Ignition switch I_icon_minitimeSun Jun 07, 2020 5:50 am
As Tim says ^^ dry grapite lubricant is best for the job, even comes in a puffer bottle with a pointed tip to hold the cover plate open ...
Ignition switch 51wxR1llP4L._SY355_
Or as the lock is horizontal, you could scrape the 'lead' (which is actually graphite) from a pencil onto a piece of paper, then holding the lock cover open with a small screwdriver (or similar) tip the dust into the lock
PostSubject: Re: Ignition switch   Ignition switch I_icon_minitimeSun Jun 07, 2020 8:23 am
Here Honda, I think some of the problem with Honda and many other bikes-----the ignition switches are not waterproof----my out look on bikes is different than most, I seldom keep one over 50,000 miles and do not buy used----my interest is having it work when I own it---I hate walking.
PostSubject: Re: Ignition switch   Ignition switch I_icon_minitimeSun Jun 07, 2020 10:15 am
I didn't know that about WD-40 Tim. Thanks. I'll get some graphite and give that a try.
kupid
PostSubject: Ignition switch   Ignition switch I_icon_minitimeSun Jun 07, 2020 1:20 pm
Thanks Cosmic_Jumper I will try it an see if it helps
kupid
PostSubject: Ignition switch   Ignition switch I_icon_minitimeWed Jul 01, 2020 5:37 pm
[quote="kupid"]
Thanks Cosmic_Jumper I used the graphite and it worked
Donie
Number of posts : 80
Registration date : 2013-04-07
PostSubject: Re: Ignition switch   Ignition switch I_icon_minitimeThu Jul 02, 2020 5:23 am
WD40 is alright for helping release frozen parts, but if you don't follow up with some real lubrication then you will soon have more problems.
I've seen it turn into a glue-like substance in door locks.
Ignition switch
» Ignition Switch
» Ignition barrel, may have a problem.
» Ignition switch glitch
» Ignition key
» About Lights and Ignition.
Honda Silver Wing Scooter Forum :: Honda Silver Wing :: "Pictorials" Maintenance-
