| Throttle Grip Feels Weird | |
+6Meldrew steve_h80 Dale N. Mech 1 twa JamieB Loosemarbles 10 posters |
| Subject: Throttle Grip Feels Weird Mon Mar 08, 2021 3:07 pm | |
| I don't know if it's my imagination but my throttle twist grip feels like its 'snagging' very very slightly on opening up when the bike is stationery without the engine running. It's not noticeable when riding. Shutting off seems fine.
I haven't ridden the bike for a couple of months until recently, and then today I noticed this sensation on the twist grip. Maybe it's always been there but should the throttle grip be completely 'smooth' in its action? |
JamieB Super Scooter Rider
Number of posts : 223 Age : 47 Location : North West UK Points : 5179 Registration date : 2011-02-01
| Subject: Re: Throttle Grip Feels Weird Mon Mar 08, 2021 4:15 pm | |
| Hi, get some lube down those cables and take it from there. |
| Subject: Re: Throttle Grip Feels Weird Mon Mar 08, 2021 6:02 pm | |
| Throttle cables, tube binding on bar or gummed up throttle bodies. This type cable luber works very nice forces lube into cable housings. Must take housing apart so first two issues will be solved. Doubt it's throttle bodies. |
Number of posts : 1987 Age : 77 Location : Princeton, MN Points : 5876 Registration date : 2014-02-13
| Subject: Re: Throttle Grip Feels Weird Mon Mar 08, 2021 8:51 pm | |
| I have one of those cable lubers like Mech 1 showed. They work very nice but if you use a spray can spray it slowly and gently. When I use mine if I just give it a good spray it will leak out a bit so keep a rag handy. Other than that they work great. |
steve_h80 Silver Wing Expert
| Subject: Re: Throttle Grip Feels Weird Tue Mar 09, 2021 2:57 am | |
| Modern cables should not be lubed, once they start to fail they need replacing. Time to strip the plastic off again :-) But it might be just the twist grip itself. |
| Subject: Re: Throttle Grip Feels Weird Tue Mar 09, 2021 3:44 am | |
| I haven't needed to lube any motorcycle or maxi scooter cable since way back the Nineties when I regularly used to use a hydraulic cable oiler on my MZ's.
I've also had that snagging feeling on a MZ throttle cable, it was caused by one of the wire strands breaking inside the cable. Which may or may not be the problem here. |
| Subject: Re: Throttle Grip Feels Weird Tue Mar 09, 2021 9:30 am | |
| First, now remember these bikes are now old, in addition to oiling the cable inners now and then---they are probably not designed to be oiled....but it works for me! The grip and barrel should be removed from handlebar, bar greased and thing put back together.....maybe every 5 years or so. Also look on fuel injector cable pivot...little oil will not hurt. I like real smooth throttle feel/operation.....and get it. |
| Subject: Re: Throttle Grip Feels Weird Tue Mar 09, 2021 12:56 pm | |
| I was always advised not to oil nylon-lined cables and never have, or needed to.
I would like to take a look at the twist-grip end of things and also the throttle body but I need to know what's involved. The twist-grip end looks fairly straight forward but as for the throttle body?...is access easy?
John? Fuel injector cable pivot? Where's that to be found?
My SW is getting old and has been a bit neglected by its' previous owners. I would ride much happier if I could check out these items. |
| Subject: Re: Throttle Grip Feels Weird Tue Mar 09, 2021 3:08 pm | |
| Fuel injector pivot is where the cables wind around the drum. |
| Subject: Re: Throttle Grip Feels Weird Wed Mar 10, 2021 2:38 pm | |
| You mean like the butterfly throttle arrangement on a carburettor? Where the cable end nipples attach to the pulley? |
| Subject: Re: Throttle Grip Feels Weird Wed Mar 10, 2021 4:02 pm | |
| Subject: Re: Throttle Grip Feels Weird Thu Mar 11, 2021 12:20 pm | |
| Got it. I'd like to have look in there one day while I'm tinkering. Is it easy to get to without removing too much tupperware? |
| Subject: Re: Throttle Grip Feels Weird Thu Mar 11, 2021 12:47 pm | |
Leinees66 Scooter Rider
Number of posts : 19 Location : Palm Bay Florida Points : 196 Registration date : 2023-11-26
| Subject: Throttle lube Sat Dec 30, 2023 12:44 pm | |
| I've noticed that my throttle sticks randomly when I let go. I bought some PJ cable lube and the tool to lube the cable. Has anyone lubed the throttle cables? I'm looking for any instructions. I'm afraid I'll remove the housing and it come apart in my hands. Any instructions? |
| Subject: Re: Throttle Grip Feels Weird Sat Dec 30, 2023 4:55 pm | |
| I had this trouble a few years ago and from my experience I think you'll have to separate the throttle grip assembly.
When you release the two halves of the switch assembly there are no surprises. You can either grease the cable ends and the cable runner in situ, or take the cable ends off and give it all a good old clean-off.
Getting the cable ends (nipples) back on the cable runner can be tricky when reassembling.
If the problem doesn't lie there, it may be at the throttle body under the seat. The cable ends are also easy to grease up at that end too. |
| Subject: Thank you Sat Dec 30, 2023 9:48 pm | |
JohnyC Touring Scooter Rider
| Subject: Re: Throttle Grip Feels Weird Tue Jan 02, 2024 1:26 pm | |
| Hi.
Also check inside the throttle body for staining or oil/breather residues that can bind against the buttfly and stop a full return. If it looks dirty strip it out and clean well with brake cleaner, refit and try. Hope this helps.
Be safe, be seen! |
| Subject: Re: Throttle Grip Feels Weird Tue Jan 02, 2024 2:10 pm | |
| Thank you. I'm a bit leary taking it apart. More worried about I UT getting it apart and putting it back together. Fingers crossed. Thanks again. |
Johnbil09 Maxi-Scooter Rider
Number of posts : 129 Age : 59 Location : Jersey City Points : 568 Registration date : 2023-03-23
| Subject: Re: Throttle Grip Feels Weird Wed Jan 17, 2024 12:53 pm | |
| Wow I just seen this after finding mine frozen,I try to start it daily but the recent temp drop caused me to skip a day but mine works but you need to let if warm up way beyond the normal time and then it’ll move freely,is it really cold in your location(in the teens,without considering the wind,,,I forgot to mention in my thread that the wheel rotor lock was beeping when I woke up this morning and I put it by my trucks heater and it’s operating like normal now….. |
| Subject: Re: Throttle Grip Feels Weird | |
