| Coolant change | |
+3Cosmic_Jumper Loosemarbles oldwingguy 7 posters |
Number of posts : 1936 Location : Hocking Hills U.S.A. Points : 5176 Registration date : 2016-01-29
| Subject: Coolant change Thu Apr 01, 2021 7:18 am | |
| Just a hmmmmmm on my part, to drain it's on the side stand, to fill it's on the center stand, why not drain then fill on the center stand like an oil change or final drive? Yes I do have an idea to try but lets hear your thought. |
| Subject: Re: Coolant change Thu Apr 01, 2021 8:05 am | |
| As it happens, I will doing a coolant change soon and I suspect that having the bike on the side stand would help drain the coolant as the hole is on left side of the engine, gravity and all that.
I'll certainly go along with Honda's recommendation.
Other thoughts also welcome. |
| Subject: Re: Coolant change Thu Apr 01, 2021 8:29 am | |
| I’m more concerned about burping the baby. I’ve even considered removing the Coolant Temp Sensor to let the bubble out. The CTS seems is located at the top of coolant plumbing at the left side of the bike —under the seat undercover.
Whaddya think? |
| Subject: Re: Coolant change Thu Apr 01, 2021 9:11 am | |
| well I'm about to find out, I'm going to drain on the center stand. After that has finished dripping I will apply LIGHT PRESSURE at the fill point to see what if any more of the fluid comes out. |
| Subject: Re: Coolant change Thu Apr 01, 2021 10:41 am | |
| Once you've done that, put the bike on the side stand and see if any more comes out of the drain hole...I'm curious. Go on..do it...you know you want to |
zrx212 Silver Wing Expert
| Subject: Re: Coolant change Thu Apr 01, 2021 3:05 pm | |
| I recently drained and refilled, did it twice to fully remove/flush out old coolant (on centerstand because you can start bike), yes I know a gallon is not enough for twice but 2 is enough for 3 times , IAC you should really recheck coolant after a full heat/cool cycle with the cap on to build pressure and check for leaks, the SSM procedure is lacking in my opinion, the good thing is that the radiator cap and overflow tank are at highest point of system, really helps with self bleeding air out, kinda like newer cars. |
Salth2ofish Scooter Rider
Number of posts : 30 Location : North Carolina Points : 1149 Registration date : 2021-05-01
| Subject: Re: Coolant change Wed May 05, 2021 7:39 am | |
| I just did the drain and fill on mine. Did it on center stand . Really because I forgot to lean it over, but I think it’s ok. I did rev it like manual says to burp it, until no more bubbles. Only concern is now I have a faint coolant smell. I did spill some though. I don’t see any leaks afte 40 miles and several rides , so should be good. Temp is running right in the middle as before. |
| Subject: Re: Coolant change Sat Jul 24, 2021 12:09 pm | |
| I'm about to do a coolant and thermostat change and Tim's comments above about 'burping the baby' is an interesting point.
After my last coolant change I had the engine boil over in traffic on a very hot day, trapped air being the cause. No damage done, but this time I want to make sure I get it right.
If the Coolant Temp Censor is easy enough to access, I'll give it a go.
Has anybody else tried this? |
Craftbike Scooter Rider
Number of posts : 28 Location : S'traya Points : 759 Registration date : 2022-05-28
| Subject: Re: Coolant change Wed Jan 17, 2024 11:45 am | |
| Hi, another coolant query…. How much do you fill the filler neck? I’ve emptied, refilled and now when I warm it up (filler cap off) it keeps burping and spilling over. I’ve done two cycles and this is still occurring (fill neck, run ‘till fan comes on).
| Subject: Re: Coolant change Wed Jan 17, 2024 12:34 pm | |
| The only 'hacks' which I learned when refilling the system are:
Be patient when pouring in the coolant, take it slowly. Also, stop occasionally and 'tllt' the bike over 'left and right', as much as you dare; don't drop it!
It's worth rocking the bike backwards and forwards on the brakes before putting the caps on.
I believe it's easy to create an air lock because of the SWs plumbing layout.
| Subject: Re: Coolant change Sat Jan 20, 2024 2:09 am | |
I believe it's easy to create an air lock because of the SWs plumbing layout. Thanks, I did another run through but didn't bother rocking/shaking (did it all on the centrestand). Will give it one more 'rock' tomorrow and then give it a test run. |
ezed1 Scooter Rider
Number of posts : 35 Age : 63 Location : Huntsville AL Points : 348 Registration date : 2023-07-28
| Subject: Re: Coolant change Wed Jan 24, 2024 7:15 am | |
| I did mines yesterday , I just followed the instructions in the manual the only thing I did different was I let the bike sit over night , in the morning popped the cap topped it off and started it up let it run for 3min cap off popped the throttle 3quick times saw some bobbles popped the throttle 3 more times no bobbles fluid dropped slightly then I put the cap back on , My temp gauge stayed at the third mark level but haven’t road anywhere yet |
| Subject: Re: Coolant change | |
| Coolant change | |
