| Fuel tank removal (fuel pump replacement) | |
IronSky Scooter Rider
Number of posts : 32 Location : Colorado Points : 1113 Registration date : 2021-06-24
| Subject: Fuel tank removal (fuel pump replacement) Wed Jul 07, 2021 8:24 pm | |
| Do I need to disconnect and remove fuel tank in order to get fuel pump assembly out? I’m worried if there is little clearance to get tank out once drop to floor.
Do you know a YouTube video link that we can watch?
Thanks |
Number of posts : 393 Age : 59 Location : Auckland, New Zealand Points : 1948 Registration date : 2020-03-11
| Subject: Re: Fuel tank removal (fuel pump replacement) Wed Jul 07, 2021 9:05 pm | |
| There's a channel by a guy called Stefano Bonacasa, he's Italian but for endless Silver Wing maintenance videos, this would be a good shot. |
| Subject: Re: Fuel tank removal (fuel pump replacement) Thu Jul 08, 2021 10:29 am | |
| Quite a few fuel tank removal discussions here on the forum. Use the Search or Advance Search function to find them
One good trick which someone mentioned recently is to use a block near the fuel fill to raise up the body to access that upper tank nut. It saves the aggro of removing the entire front body work. IIRC he used a duct tape roll. |
| Subject: Re: Fuel tank removal (fuel pump replacement) Thu Jul 08, 2021 10:57 am | |
| I did the search with “gas tank removal” etc but no topic were found. Just fuel pump. Gas leak etc. no instruction on removal of gas tank. I have service manual but it doesn’t say how to remove gas tank once drop from body. |
| Subject: Re: Fuel tank removal (fuel pump replacement) Thu Jul 08, 2021 12:21 pm | |
- One good trick which someone mentioned recently is to use a block near the fuel fill to raise up the body to access that upper tank nut. It saves the aggro of removing the entire front body work. IIRC he used a duct tape roll.
I do not think I follow what you are saying. "block ner the fuel fill to raise up the body" How? What block? |
| Subject: Re: Fuel tank removal (fuel pump replacement) Thu Jul 08, 2021 2:40 pm | |
I do not think I follow what you are saying. "block ner the fuel fill to raise up the body" How? What block? It was a comment made wherein someone jammed a duct tape roll under the upper panel at the fuel fill to raise that panel enough to allow removing that 12mm (?) nut which holds the top tank mount. Presumably then you can lift the tank up off that fixed bolt stud then drop the tank down out of the scoot. The alternative is to remove the entire front end and dash body work to expose that tank nut. Of course you'll still need to remove the side skirts, tunnel cover, and probably the seat. |
| Subject: Re: Fuel tank removal (fuel pump replacement) Mon Nov 15, 2021 8:38 pm | |
| Subject: Re: Fuel tank removal (fuel pump replacement) | |
