» LF extended back rest
Squeaking Rubbing sound  I_icon_minitimeby Rzor93 Today at 4:29 pm
» Goodbye guys
Squeaking Rubbing sound  I_icon_minitimeby Rzor93 Today at 4:27 pm
» noise under load
Squeaking Rubbing sound  I_icon_minitimeby dmosemorris Yesterday at 1:30 pm
» checking the oil
Squeaking Rubbing sound  I_icon_minitimeby arcamedies13 Yesterday at 9:32 am
Squeaking Rubbing sound  I_icon_minitimeby Terry Smith Thu May 16, 2024 6:39 pm
» Hello from Illinois!
Squeaking Rubbing sound  I_icon_minitimeby DescendingRaven Wed May 15, 2024 2:13 pm
» Silverwing Brakes
Squeaking Rubbing sound  I_icon_minitimeby Terry Smith Tue May 14, 2024 11:57 pm
Squeaking Rubbing sound  I_icon_minitimeby BrianInVA Mon May 13, 2024 12:53 pm
» Left brake micro-switch
Squeaking Rubbing sound  I_icon_minitimeby Johnboy Fri May 10, 2024 7:57 pm
Squeaking Rubbing sound  I_icon_minitimeby BrianInVA Fri May 10, 2024 5:36 pm
3 posters
HayvenMoses
Number of posts : 8
Registration date : 2020-10-14
Squeaking Rubbing sound  Empty
PostSubject: Squeaking Rubbing sound    Squeaking Rubbing sound  I_icon_minitimeSat Jul 31, 2021 7:03 am
I have a 2009 Silverwing and it has just under 13,000 miles. Lately Ive noticed a rubbing noise coming from the rear left near the belt. It has also been shaking when I first give it throttle. I read that it could be the Clutch and was told to give it throttle with front brake on to de glaze it,is that right?
Number of posts : 3299
PostSubject: Re: Squeaking Rubbing sound    Squeaking Rubbing sound  I_icon_minitimeSat Jul 31, 2021 7:54 am
Befroe taking things apart---just run engine up against brakes for 5--10 seconds. Burns glaze off things.... and remember bike is 12 years old and near 15,000 miles---time for new OEM belt soon!
HayvenMoses
Number of posts : 8
PostSubject: Re: Squeaking Rubbing sound    Squeaking Rubbing sound  I_icon_minitimeSat Jul 31, 2021 8:12 am
So throttle it up withbrakes on? Is the OEM Belt the drive belt?
PostSubject: Re: Squeaking Rubbing sound    Squeaking Rubbing sound  I_icon_minitimeSat Jul 31, 2021 10:30 am
Yes is drive belt
HayvenMoses
Number of posts : 8
PostSubject: Re: Squeaking Rubbing sound    Squeaking Rubbing sound  I_icon_minitimeSat Jul 31, 2021 12:45 pm
Thanks Im gonna order one today.
Number of posts : 1382
PostSubject: Re: Squeaking Rubbing sound    Squeaking Rubbing sound  I_icon_minitimeSat Jul 31, 2021 5:38 pm
Follow John's advice.  Clutch shoe noise comes and goes it's normal.  While you have that belt off pull the driven pulley and clean shoes and sand the clutch drum  320 400 Grit. There is a little bearing inside drum add a little grease to it at same time.   Set the parking brake and hold rear brake to remove the nut on pulley housing Very easy. Nut that holds it 40lbf. torque.
» Common Silverwing Sounds and behaviors
» rubbing belt
» squeaking front shock
» Givi windscreen squeaking
» Squeaking/Squealing Noise
Honda Silver Wing Scooter Forum :: Tips on using this site-
