» LF extended back rest
Horn button replacement  I_icon_minitimeby Rzor93 Today at 4:29 pm
» Goodbye guys
Horn button replacement  I_icon_minitimeby Rzor93 Today at 4:27 pm
» noise under load
Horn button replacement  I_icon_minitimeby dmosemorris Yesterday at 1:30 pm
» checking the oil
Horn button replacement  I_icon_minitimeby arcamedies13 Yesterday at 9:32 am
Horn button replacement  I_icon_minitimeby Terry Smith Thu May 16, 2024 6:39 pm
» Hello from Illinois!
Horn button replacement  I_icon_minitimeby DescendingRaven Wed May 15, 2024 2:13 pm
» Silverwing Brakes
Horn button replacement  I_icon_minitimeby Terry Smith Tue May 14, 2024 11:57 pm
Horn button replacement  I_icon_minitimeby BrianInVA Mon May 13, 2024 12:53 pm
» Left brake micro-switch
Horn button replacement  I_icon_minitimeby Johnboy Fri May 10, 2024 7:57 pm
Horn button replacement  I_icon_minitimeby BrianInVA Fri May 10, 2024 5:36 pm
2 posters
johnd
Number of posts : 543
Horn button replacement  Empty
PostSubject: Horn button replacement    Horn button replacement  I_icon_minitimeWed Oct 26, 2022 3:42 pm
Before digging in and replacing the horn button ,I thought it might be a good idea to ask if there is a short video here or on youtube that I have not found on how it's done?
Number of posts : 1570
PostSubject: Re: Horn button replacement    Horn button replacement  I_icon_minitimeThu Oct 27, 2022 11:19 pm
I'm not sure if this has been covered before. I don't know of any tutorials but if it's anything like the starter button it screws onto the inside of the lower half of the switch assembly.
I doubt if it's a part you could buy from Honda.
What exactly is the problem? Can it be repaired?
johnd
PostSubject: Re: Horn button replacement    Horn button replacement  I_icon_minitimeThu Oct 27, 2022 11:39 pm
The switch was iffie and at times not work at all.
Took the switch apart and sprayed WD-40 and then a contact spray and it worked once so I believe the horn itself is ok. Have not called the dealer yet on tje price.
PostSubject: Re: Horn button replacement    Horn button replacement  I_icon_minitimeFri Oct 28, 2022 2:36 am
Did the switch look to be in good condition? If so, it could be the horn at fault. They can be temperamental when they start to fail.
You could try testing the horn separately. Try short and then very long bursts to see if it begins to 'crackle'
johnd
PostSubject: Re: Horn button replacement    Horn button replacement  I_icon_minitimeThu Nov 03, 2022 6:42 pm
Thank you very much. After removing the plastics around the handlebars, it was easy to see the connections are down inside the fairing.  I did take the switch apart and used some 3000 grit sandpaper on the button, fowelled buy contact spray.
That did not help. I figured an 08 with 51,000 and with the right side starter switch that also just went out, if I have to take to front off to replace the switch , I might as well replace to Walo Bad Boy 519 horn that I've had for 9 years as well. I did try the short and long idea but nothing happen.
The original switch cost $ 109.00 and they gave me a discount for being a senior so that was nice.
Again super glad I don't own a BMW any more.
That stand for BRING ME YOUR WALLET! HAHA
PostSubject: Re: Horn button replacement    Horn button replacement  I_icon_minitimeFri Nov 04, 2022 1:01 am
John, do you mean you're replacing the whole left hand switch assembly?
johnd
PostSubject: Re: Horn button replacement    Horn button replacement  I_icon_minitimeSat Nov 05, 2022 9:07 pm
Yes I will when the part arrives. I really don't think there was any other choice.
» horn replacement
» horn replacement on swing
» Logging in
» mode button
» Multiple Quote Button is activated !!!
Honda Silver Wing Scooter Forum :: Tips on using this site-
