| CCA (cold cranking amps) battery for a motorcycle? | |
+4sonuvabug steve_h80 GHM-PM Cosmic_Jumper 8 posters |
XDM© Maxi-Scooter Rider
Number of posts : 110 Location : Philly, Pennsylvania Points : 1831 Registration date : 2019-10-20
| Subject: CCA (cold cranking amps) battery for a motorcycle? Thu Dec 15, 2022 2:45 pm | |
| My SWing keeps dying in cold weather. (like 32F) the battery is only 2 years old but even when it was brand new it was a issue. I park it outside my apartment and lock & cover it over when im done. its my primary vehicle and i ride all year but as the seasons change im left high and dry sometimes. i know cars have a CCA battery thats designed for winter, do they have this for motorcycles as well? and if so one that can actually fit in the SWing. for now im buying a portable jumper to keep with me as i was only lucky to get a jump at work. |
| Subject: Re: CCA (cold cranking amps) battery for a motorcycle? Thu Dec 15, 2022 3:18 pm | |
| When you decide to replace the battery go with a Yuasa YTZ14-S. It has 20 more CCA than the YTZ12-S. The OEM battery is Yuasa YTZ12-S. Yuasa is a premium battery manufacturer, so don’t expect to find a bargain price. The YTZ12-S is 210 CCA; the YTZ14-S is 230 CCA. Both the 12-S and 14-S are the exact same size and have the same pole configuration. |
zrx212 Silver Wing Expert
| Subject: Re: CCA (cold cranking amps) battery for a motorcycle? Thu Dec 15, 2022 7:54 pm | |
| Unfortunately, besides all good aspects of modern AGM Batteries, cold weather/low temperatures still affect voltage/amperage/capacity similarly as the old acid flooded type, so at 32F you could be down to 80% of your battery full charge, more so depending on time hours/days outside and overall battery condition, in other words, your battery is literally dead before you push the start button, a larger/more cranking amps battery will hold out better, but unless it's used regularly/daily, it should be either trickle charged, kept in a warm place or both. Maybe find a spot/way to run a extension cord to trickle charge. The constant discharging due to cold weather, etc., has probably diminished capacity already. You could use the booster to get going in an emergency, but I don't recommend regular use, not good for charging system components. In the other hand a properly set-up Lithium battery with built in BMS (battery management system) will work in all temperatures, just turn high beam on for 5-10 seconds before cranking |
| Subject: Re: CCA (cold cranking amps) battery for a motorcycle? Fri Dec 16, 2022 7:54 am | |
| I use an YTZ12-S battery in my SWing and my Forza. That works fine but a couple of points to consider:
1. My SWing is based in Arizona and is garaged. Not that cold.
2. My Forza lives in cold country but is in a shed with a battery maintainer for the winter.
Another point, I don't buy an expensive battery but I replace them every two years without fail. Cost about 1/5th what a Yuasa does but I could replace them yearly and still save $$$. Good luck with whatever you decide to do. |
| Subject: Re: CCA (cold cranking amps) battery for a motorcycle? Fri Dec 16, 2022 4:30 pm | |
- When you decide to replace the battery go with a Yuasa YTZ14-S. It has 20 more CCA than the YTZ12-S. The OEM battery is Yuasa YTZ12-S. Yuasa is a premium battery manufacturer, so don’t expect to find a bargain price. The YTZ12-S is 210 CCA; the YTZ14-S is 230 CCA. Both the 12-S and 14-S are the exact same size and have the same pole configuration.
I think I'll look into that, I took a look at my current battery and it's a measly 120 cca duralast. Question, When it comes to amps is their any danger levels I should avoid or is their a too high of a amperage? |
steve_h80 Silver Wing Expert
| Subject: Re: CCA (cold cranking amps) battery for a motorcycle? Sat Dec 17, 2022 3:14 am | |
| Why not use a solar trickle charger to keep the battery topped up? You would need to find some way of attaching it to the cover or fixing it to a nearby wall, I appreciate if you have thieving vermin in the area this might not be too good an idea. |
| Subject: Re: CCA (cold cranking amps) battery for a motorcycle? Sat Dec 17, 2022 3:17 am | |
| - steve_h80 wrote:
- Why not use a solar trickle charger to keep the battery topped up?
You would need to find some way of attaching it to the cover or fixing it to a nearby wall, I appreciate if you have thieving vermin in the area this might not be too good an idea. Yea Cant do that, im in a VERY high theft area. they dont even care about the cameras half the time. for now i got a small portable jumper until i decide to get that upgraded battery. |
| Subject: Re: CCA (cold cranking amps) battery for a motorcycle? Sat Dec 17, 2022 7:23 am | |
| This is the outfit I use. Never any problems. This is the 14 that Cosmic Jumper spoke rather than the YTZ12S.
https://www.batterysharks.com/Yuasa-YTZ14S-p/ytz14s_m12-11.2-230-k.htm |
sonuvabug Silver Wing Expert
Number of posts : 929 Location : Mid-Western Ontario Canada Points : 6008 Registration date : 2010-09-15
| Subject: Re: CCA (cold cranking amps) battery for a motorcycle? Sat Dec 17, 2022 4:35 pm | |
| - XDM:copyright: wrote:
- ... snipped ... Question, When it comes to amps is their any danger levels I should avoid or is their a too high of a amperage?
If you stick to batteries that physically fit in the SWing's battery compartment, you will not ever get a battery with "too high of an amperage" rating to fit. Our Burgman 400 currently has a FTZ 14-BS battery up from the original FTZ 9-BS and there are no issues. BTW - the "S" stands for factory supplied/installed acid and the BS stands for "bottle supplied" where the buyer must install the acid themselves post purchase. At the price of the battery in the link you included, you can afford to get a new one of the off brands every season. By comparison, the Yuasa batteries are much more expensive. However, they last a long, long time if properly maintained. I recall our original 2004 Burgman battery lasting over a decade. |
| Subject: Re: CCA (cold cranking amps) battery for a motorcycle? Sun Dec 18, 2022 9:57 am | |
| I've have used the Batteries Plus "Duracell Ultra" batteries with great results and they are local, one in my Burgman now, surprisingly the cheap no brand in my SW600 still going strong at almost 3 years old, they have a "seasonal" 20% discount on online purchases, pickup in store and get your core charge back.
The Duracell Ultra 14AH-BS 12V 220CCA AGM Powersport Battery, will cost approx. $110 OTD (after discount and core return), depending on state taxes/disposal fees ??
https://www.batteriesplus.com/battery-tips/powersport
https://www.batteriesplus.com/productdetails/cylaz14sxta
Last edited by zrx212 on Sun Dec 18, 2022 11:48 am; edited 3 times in total (Reason for editing : Wrong battery size on previous link, corrected.) |
| Subject: Re: CCA (cold cranking amps) battery for a motorcycle? Sun Dec 18, 2022 10:22 am | |
| - zrx212 wrote:
- I've have used the Batteries Plus "Duracell Ultra" batteries with great results and they are local, one in my Burgman now, surprisingly the cheap no brand in my SW600 still going strong at almost 3 years old, they have a "seasonal" 20% discount on online purchases, pickup in store and get your core charge back.
The Duracell Ultra 14AH-BS 12V 220CCA AGM Powersport Battery, will cost approx. $120 OTD (after discount and core return), depending on state taxes/disposal fees ??
https://www.batteriesplus.com/productdetails/cyl10003?variationCode=VI790980 I notice the "H" in the battery product descriptor. At 6.5" tall, isn't it too tall to fit into the SWing's battery cubby? |
| Subject: Re: CCA (cold cranking amps) battery for a motorcycle? Sun Dec 18, 2022 10:36 am | |
| " I notice the "H" in the battery product descriptor. At 6.5" tall, isn't it too tall to fit into the SWing's battery cubby?"
Yes, I just caught that myself, this one should work, I'll edit ...
| Subject: Re: CCA (cold cranking amps) battery for a motorcycle? Sun Dec 18, 2022 11:24 am | |
| - zrx212 wrote:
- " I notice the "H" in the battery product descriptor. At 6.5" tall, isn't it too tall to fit into the SWing's battery cubby?"
Yes, I just caught that myself, this one should work, I'll edit ... https://www.batteriesplus.com/productdetails/cyl10001 With all due respect, I think you'll need to edit your edit as it doesn't appear that one will fit either. The FSM states a battery size of 6" x 3-7/16" x 4-3/8" (150mm x 87mm x 110mm) LxWxH. I just physically measured my SWing and there would be no way to install a battery much taller than 4-1/2 inches. The YUASA catalogue list their YTZ 14S battery as having the same dimensions as their YTZ 12S or YTZ 12BS batteries (the SWing's OEM battery size stated above). Unfortunately, there doesn't appear to be a YTZ 14"BS" (bottle supplied) made, with the lower height, that I could find so people have to pay the higher, factory acid " Supplied" price for an " S" battery. |
| Subject: Re: CCA (cold cranking amps) battery for a motorcycle? Sun Dec 18, 2022 12:24 pm | |
| " Unfortunately, there doesn't appear to be a YTZ 14"BS" (bottle supplied) made, with the lower height, that I could find so people have to pay the higher, factory acid "Supplied" price for an "S" battery. " Thanks for pointing that out, again Thumbs, my thinking cap was a little crooked this am, after last nights "season celebrations party" (have to be use proper terms nowadays) IAC, they actually have a replacement battery that fits and it's cheaper , edited my previous post. Just to be sure, I went out to scooter check cavity and my "No Brand" battery dimensions https://www.batteriesplus.com/productdetails/cylaz14sxta BTW, the oem replacement battery at Ron Ayers (USA) is reasonable cost considering is a "Yuasa", but I don't believe is JDM as original equipped (better quality), possibly US made in Pennsylvania ? and still 210 CCA, in any case buying from a local vendor will give you a warranty recourse, not sure on a mail order purchase |
MUCHoldERwingguy Scooter Rider
Number of posts : 89 Location : Hocking Hills USA Points : 940 Registration date : 2022-01-29
| Subject: Re: CCA (cold cranking amps) battery for a motorcycle? Mon Dec 19, 2022 1:35 pm | |
| The Lithium Ion battery I put in mine S'Wing 5 years ago left with the bike this summer, it's still in and doing fine. The only maintenance was putting the Battery Tender on it overnight once in a while. I have 6 others some that are at least 8 years old that I use for string trimmers, chainsaw ect. they are good and do very well until they don't. It's either good or bad no slow cranking. |
JohnyC Touring Scooter Rider
| Subject: Re: CCA (cold cranking amps) battery for a motorcycle? Mon Dec 26, 2022 9:15 am | |
| I found by trial and error that If your swing has injection, Lithium Ion is the best way to go, It'll be the first time your starter has had a true 12 v supply, and you will hear/feel the difference. Transformed both my Burgman Skywave and my Swing. After some unusually cold nights here in the UK, Lithium started first fire on each... If your worried by the low Ah of Lithium, don't be you can get bigger(same package size) if you think you need it, just dearer, although personally I'm happy with stock one. |
| Subject: Re: CCA (cold cranking amps) battery for a motorcycle? Mon Dec 26, 2022 5:22 pm | |
| - JohnyC wrote:
- I found by trial and error that If your swing has injection, Lithium Ion is the best way to go, It'll be the first time your starter has had a true 12 v supply, and you will hear/feel the difference. Transformed both my Burgman Skywave and my Swing.
After some unusually cold nights here in the UK, Lithium started first fire on each... If your worried by the low Ah of Lithium, don't be you can get bigger(same package size) if you think you need it, just dearer, although personally I'm happy with stock one. i have been interested in those Lithium Ion batteries but i was wondering why they were more expensive and if they were winter tolerant. question on that. can i still charge it like a regular battery at home? i have a battery charger for vehicle batteries, can that still work for it? |
| Subject: Re: CCA (cold cranking amps) battery for a motorcycle? Mon Dec 26, 2022 6:11 pm | |
| They do require a LiFePO4 charger, I found a cheap one on Ebay, one of the new wave of multi use chargers, not that I have used it yet. The swings never more than a couple of days under cover so batteries always fully charged. Have you tested for a parasitic leak on the battery or do you use a tracker, they kill any battery.
Not allowed to leave a link to the charger, but I have tested it on lead, AGM and Lithium so far. |
| Subject: Re: CCA (cold cranking amps) battery for a motorcycle? Mon Dec 26, 2022 6:14 pm | |
| When I say not used it yet, not in anger on the scoots, pure bench testing. |
| Subject: Re: CCA (cold cranking amps) battery for a motorcycle? Mon Dec 26, 2022 6:25 pm | |
| - JohnyC wrote:
- They do require a LiFePO4 charger, I found a cheap one on Ebay, one of the new wave of multi use chargers, not that I have used it yet.
Not allowed to leave a link to the charger, but I have tested it on lead, AGM and Lithium so far. ok so that new charger is backwards compatible with lead? that's good. perhaps ill sell my current charger and get that so im able to charge regular car batteries too. i don't have anything connected to the battery besides a phone charger BUT that is physically turned off when im not using it. my issue is what i suspect above, the cca was WAY to low to begin with. looking into it i should have 200+ and i only have 140 so ANY little cold weather will kill it. |
| Subject: Re: CCA (cold cranking amps) battery for a motorcycle? Mon Dec 26, 2022 8:38 pm | |
Not allowed to leave a link to the charger, but I have tested it on lead, AGM and Lithium so far. I find this whole got have a special charger interesting as we put that / those batteries right into the S'Wing regardless of year and yet no one seems to have reported a problem keeping them charged doing that. ??? |
| Subject: Re: CCA (cold cranking amps) battery for a motorcycle? Tue Dec 27, 2022 12:03 am | |
| These batteries have built in BMS(Battery Management System) you can use most regular chargers, but should not need to charge it much or at all, if used regularly/normally. In any case, scroll down and read PDF user manual on this page, this battery will fit, check around, maybe find better deal.
https://www.amazon.com/dp/B07JQWFS7Z?tag=batterytechie-se-20&linkCode=ogi&th=1
I've not personally used them, but had several friends that used them successfully in winter months when I lived in NC. |
| Subject: Re: CCA (cold cranking amps) battery for a motorcycle? Tue Dec 27, 2022 8:48 am | |
| - zrx212 wrote:
- These batteries have built in BMS(Battery Management System) you can use most regular chargers, but should not need to charge it much or at all, if used regularly/normally. In any case, scroll down and read PDF user manual on this page, this battery will fit, check around, maybe find better deal.
I've not personally used them, but had several friends that used them successfully in winter months when I lived in NC. zero problems with the cold here when I had it and yes they seldom needed an extra boost from a charger. Like any battery cold cuts into use, look at how the range is cut down on the new Electric Vehicles not just from the cold but to from using a battery to keep warm, all this without an on-board charging system. |
| Subject: Re: CCA (cold cranking amps) battery for a motorcycle? Sat Dec 16, 2023 6:46 pm | |
| for the sake of wrapping up this thread, i was again having the issue this year too and just one week ago i decided to get a Lithium ION battery (NOCO Lithium NLP14 12V) its 500 CCA and t does WONDERS! fast, strong cranks even in 30 degrees F! |
| Subject: Re: CCA (cold cranking amps) battery for a motorcycle? | |
