» Goodbye guys
Auxiliary Fuse box I_icon_minitimeby Dale N. Yesterday at 10:58 pm
» LF extended back rest
Auxiliary Fuse box I_icon_minitimeby Rzor93 Yesterday at 4:29 pm
» noise under load
Auxiliary Fuse box I_icon_minitimeby dmosemorris Sat May 18, 2024 1:30 pm
» checking the oil
Auxiliary Fuse box I_icon_minitimeby arcamedies13 Sat May 18, 2024 9:32 am
Auxiliary Fuse box I_icon_minitimeby Terry Smith Thu May 16, 2024 6:39 pm
» Hello from Illinois!
Auxiliary Fuse box I_icon_minitimeby DescendingRaven Wed May 15, 2024 2:13 pm
» Silverwing Brakes
Auxiliary Fuse box I_icon_minitimeby Terry Smith Tue May 14, 2024 11:57 pm
Auxiliary Fuse box I_icon_minitimeby BrianInVA Mon May 13, 2024 12:53 pm
» Left brake micro-switch
Auxiliary Fuse box I_icon_minitimeby Johnboy Fri May 10, 2024 7:57 pm
Auxiliary Fuse box I_icon_minitimeby BrianInVA Fri May 10, 2024 5:36 pm
 Auxiliary Fuse box
2 posters
africa1228
africa1228
Number of posts : 24
Registration date : 2023-04-19
Auxiliary Fuse box Empty
PostSubject: Auxiliary Fuse box   Auxiliary Fuse box I_icon_minitimeWed Apr 26, 2023 11:59 am
With all the added accessories that people add to their bikes, it amazes me that manufacturers don't leave some fuse locations free for adding accessories.
However, i am not a fan of these "add a fuse" contraptions that attach to existing fuse outlets and in the past have added an additional fuse box to my bikes on occasion.
I am wondering if anyone has done the same for a Swing? And if so, where did they mount the auxiliary?
If not, when I do, I will post where I put it and how I wired it all up. I would make it so that it only powers on when the bike is switched on.
Number of posts : 929
PostSubject: Re: Auxiliary Fuse box   Auxiliary Fuse box I_icon_minitimeWed Apr 26, 2023 1:13 pm
africa1228, I bought an auxiliary fuse block for the electrical accessories I'll be adding soon. I plan to install it in the under seat area where the OEM toolkit and Owner's Manual are currently strapped in. I will drill holes in the sides of that "storage dish" to run the wires to where I need them. I'm also installing a separate ground block and haven't decided where to put it. It'll likely be close to the starter and/pr where the main ground to frame is. I can't say for sure because I haven't physically removed the tupperware in that area to see for myself.
Auxiliary Fuse box
» 10 Watt LED Auxiliary Lights
» LED Auxiliary Light Project
» LED auxiliary lights and FM Radio interference
» LEDs for auxiliary headlight modifications
» Auxiliary Front Lights - Advice Wanted
