Number of posts : 2778 Age : 73 Location : NE Oklahoma Points : 8911 Registration date : 2008-12-28
Subject: Main Fuse...How to find Wed Nov 29, 2023 2:39 pm
Been a long time....
"Silverwing won't start
In the search area type in "Main fuse" and you will find a solution to your starting problems.
I added a pictorial on were to locate it and how to get to it.
Good Luck
laJose Scooter Rider
Number of posts : 7 Location : B C Points : 184 Registration date : 2023-11-26
Subject: Re: Main Fuse...How to find Wed Nov 29, 2023 4:25 pm
2006 SWing FSC 600 Owner manual pg 184. Two main fuses. Main fuse A is under the left side cover on the starter solenoid. Remove left cover, remove wires connector from solenoid, pull fuse out. Main fuse B is under the seat.
