» Goodbye guys
Led Upgrade I_icon_minitimeby Dale N. Yesterday at 10:58 pm
» LF extended back rest
Led Upgrade I_icon_minitimeby Rzor93 Yesterday at 4:29 pm
» noise under load
Led Upgrade I_icon_minitimeby dmosemorris Sat May 18, 2024 1:30 pm
» checking the oil
Led Upgrade I_icon_minitimeby arcamedies13 Sat May 18, 2024 9:32 am
Led Upgrade I_icon_minitimeby Terry Smith Thu May 16, 2024 6:39 pm
» Hello from Illinois!
Led Upgrade I_icon_minitimeby DescendingRaven Wed May 15, 2024 2:13 pm
» Silverwing Brakes
Led Upgrade I_icon_minitimeby Terry Smith Tue May 14, 2024 11:57 pm
Led Upgrade I_icon_minitimeby BrianInVA Mon May 13, 2024 12:53 pm
» Left brake micro-switch
Led Upgrade I_icon_minitimeby Johnboy Fri May 10, 2024 7:57 pm
Led Upgrade I_icon_minitimeby BrianInVA Fri May 10, 2024 5:36 pm
 Led Upgrade
4 posters
ezed1
ezed1
Number of posts : 35
Registration date : 2023-07-28
Led Upgrade Empty
PostSubject: Led Upgrade   Led Upgrade I_icon_minitimeWed Nov 29, 2023 11:29 pm
For those who are interested ONLY  Led Lights Laughing
these are the bulbs I used and the fact that my fairings are removed for painting made it much easier to do
Head Light Bulb - https://www.ebay.com/itm/165487284233
these are legit sunny ,do not buy the look a likes they are using a weaker chip must say  CSP 3570 chips
Blinker Blubs - https://www.ebay.com/itm/134778316485 these will need
Hyper flash load resistors across signal and ground connection - https://www.ebay.com/itm/126044603706
Brake light bulbs - https://www.ebay.com/itm/134778316485 had to cut One of the mounting tabs to fit in socket
Tag Light bulb - https://www.ebay.com/itm/133733939703
good luck and happy led upgrading
Mighty Mouse
Mighty Mouse
Number of posts : 116
Registration date : 2017-05-03
Led Upgrade Empty
PostSubject: Re: Led Upgrade   Led Upgrade I_icon_minitimeThu Nov 30, 2023 3:35 am
From experience with LED's as main lights on bikes. Too weak and not focused enough to ride safely at night. Whatever you buy it won't last very long...
Perfect for extra lights but not the mains.
Number of posts : 4180
Led Upgrade Empty
PostSubject: Re: Led Upgrade   Led Upgrade I_icon_minitimeThu Nov 30, 2023 5:23 am
I have full LED lights on my Forza, and I'd also say the headlight beams are not as good as the Osram Night Breakers I updated the Silver Wing to. Not that it's mattered all that much since I bought the Forza since I no longer have to cross over the pitch black 50 miles of A66 road over the Pennines between Cumbria and North Yorkshire at night and in below zero temperatures.
The plus side is the LED's are far more energy efficient and the front array of headlights, a couple of rows of ‘eyebrow' lights above the headlights and amber turn signal/running lights in the mirrors make for a far more visible frontal area than the Silver Wing. Having said that I still regard every other road user as a blind dickhead.  Neutral
I'd also bear in mind that the headlight reflectors of the Silver Wing were designed over 20 years ago for Halogen not LED lamps  (Talk to an electrician and they'll tell you that they're called lamps and bulbs are what you plant in the garden).
Still, there's a topic on two on here about owners who have gone the LED route successfully.
Number of posts : 2568
Led Upgrade Empty
PostSubject: Re: Led Upgrade   Led Upgrade I_icon_minitimeThu Nov 30, 2023 7:44 am
LED's are great! My wife has a Mazda car that came with all LED's and they are far superior to the halogens in my truck. But Meldrew is right; putting them in a bike that was designed for halogens takes some doing. Not worth the effort for me but I seldom ride the scooters after dark.
ezed1
ezed1
Led Upgrade Empty
PostSubject: Re: Led Upgrade   Led Upgrade I_icon_minitimeThu Nov 30, 2023 4:26 pm
yeah had the fairings not been removed i would have stopped at the headlights trying to get them out thru a small space, mines were ceased on had to remove the bulb then remove it from its socket
Led Upgrade Empty
Led Upgrade
» Upgrade or not
» Full LED upgrade
» suspension upgrade
» Seat damper upgrade?
» Exhaust upgrade
