darkshvein Scooter Rider
Number of posts : 1 Location : Turkey, Mersin Points : 149 Registration date : 2023-12-26
| Subject: Reinforced variator housing Tue Dec 26, 2023 3:14 am | |
| Good day. I guess, do you know about SW600 weak point, Weak rear left suspension mount. Please suggest, possible to reinforce,strengthen this point? Does anyone sell reinforced hulls? or does anyone sell specially cut pieces of metal to support the bottom and strengthen it? ps.sorry for bad english. |
zrx212 Silver Wing Expert
| Subject: Re: Reinforced variator housing Tue Dec 26, 2023 9:24 am | |
| Never, Ever !!, heard of that failing and/or being a common issue, I've personally found the SW600 in general to be very robust and almost overbuilt/heavy than required materials used throughout the scooter. Is your is broken , it must have been many incredible/deep potholes and/or your rear shocks are really bad In any case a good welder/fabricator should be able to fix, maybe reinforce externally ??, in any case if done correctly stronger than before. |
