ezed1 Scooter Rider
Number of posts : 35 Age : 63 Location : Huntsville AL Points : 348 Registration date : 2023-07-28
| Subject: Battery Tender Plug Mon Jan 22, 2024 5:19 pm | |
| From the search I see nobody has done this hUMMMM Well I'm going to do it I've done it on my reflex clone project, Nothing like just plugin it up and walking away 10ga type coming off the battery I just need to pick a spot and mount I cut the Charger leads and put a SAE connector on the end to plug into Scoot |
Number of posts : 393 Age : 59 Location : Auckland, New Zealand Points : 1948 Registration date : 2020-03-11
| Subject: Re: Battery Tender Plug Mon Jan 22, 2024 7:36 pm | |
| I have one of those 12v leads connected to the batteries on all my bikes, I normally have them connected to drive heated grips or other accessories through a relay. Then disconnect when I need to use the charger, or I can also power up a small compressor that I carry for tyre emergencies on long rides. |
ezed1 Scooter Rider
| Subject: Re: Battery Tender Plug Mon Jan 22, 2024 8:11 pm | |
| - Terry Smith wrote:
- I have one of those 12v leads connected to the batteries on all my bikes, I normally have them connected to drive heated grips or other accessories through a relay. Then disconnect when I need to use the charger, or I can also power up a small compressor that I carry for tyre emergencies on long rides.
Yes you can use it as a power outlet as well :-) |
| Subject: Re: Battery Tender Plug Wed Jan 24, 2024 6:52 am | |
| Invaluable on all my 2 and 3 wheelers! Makes hooking up a battery maintainer a snap. In addition on a trip with the Silver Wing I can charge my phone or camera while riding and they are safely under the seat! |
dniwe Scooter Rider
Number of posts : 11 Location : Planet Earth Points : 2121 Registration date : 2018-08-11
| Subject: Re: Battery Tender Plug Sat Mar 09, 2024 2:42 am | |
| Sorry, but I did not get the idea of having this on SW. The 12V outlet in the left pocket is already and always connected to the battery. All I'm doing is using adapter like this in the picture and connecting my CTEK maintenance charger to it. |
| Subject: Re: Battery Tender Plug | |
