jerry-d Scooter Rider
Number of posts : 12 Location : tampa Points : 779 Registration date : 2022-04-19
| Subject: anyone know if antilock brakes Wed Feb 21, 2024 10:07 am | |
| can be removed? how to convert anti-lock bike to no anti-lock. thanks in advance |
Erdoc48 Touring Scooter Rider
| Subject: Re: anyone know if antilock brakes Wed Feb 21, 2024 1:58 pm | |
| Actually, should be pretty easy (I had to do this on my 94 ST because sensors are no longer available and I was having ABS issues/ warming lights, etc.)- I pulled the fuses for ABS in the fuse block and no more ABS (just regular brakes on that bike)- the only issue you may have is a warning light on the instrument panel, but if you dismantle the area to get behind it, you could just pull the bulb. I would truthfully only do this if I was having ABS issues and either could not troubleshoot it properly or as I indicated, the parts are no longer available. The left brake handle should still activate both brakes and right handle the front as expected.
I would not want to take off the ABS parts as then you’re potentially messing with the unknown (my way, you’re just electrically disabling ABS) |
Number of posts : 189 Location : Ireland Points : 1584 Registration date : 2020-08-11
| Subject: Re: anyone know if antilock brakes Sun Feb 25, 2024 8:18 pm | |
| If you do, you'll probably need to list it as a mod on your insurance. |
| Subject: Re: anyone know if antilock brakes | |
