» Goodbye guys
Rear brake issue,  I_icon_minitimeby GHM-PM Today at 7:58 am
» noise under load
Rear brake issue,  I_icon_minitimeby dmosemorris Yesterday at 1:30 pm
» checking the oil
Rear brake issue,  I_icon_minitimeby arcamedies13 Yesterday at 9:32 am
Rear brake issue,  I_icon_minitimeby Terry Smith Thu May 16, 2024 6:39 pm
» Hello from Illinois!
Rear brake issue,  I_icon_minitimeby DescendingRaven Wed May 15, 2024 2:13 pm
» Silverwing Brakes
Rear brake issue,  I_icon_minitimeby Terry Smith Tue May 14, 2024 11:57 pm
» LF extended back rest
Rear brake issue,  I_icon_minitimeby Frenchy Mon May 13, 2024 7:57 pm
Rear brake issue,  I_icon_minitimeby BrianInVA Mon May 13, 2024 12:53 pm
» Left brake micro-switch
Rear brake issue,  I_icon_minitimeby Johnboy Fri May 10, 2024 7:57 pm
Rear brake issue,  I_icon_minitimeby BrianInVA Fri May 10, 2024 5:36 pm
 Rear brake issue,
3 posters
Havit
Number of posts : 2
Registration date : 2023-04-24
Rear brake issue,  Empty
PostSubject: Rear brake issue,    Rear brake issue,  I_icon_minitimeSat Mar 02, 2024 12:51 pm
I need some advice on my rear brake, I have no resistance on the lever, I have tried bleeding the
Lower front valve , lots of bubbles but still no resistance on the lever. I'm using a vacuum pump. On the rear, I pumped the vacuum opened the bleed valve and nothing no fluid and the vacuum pressure didn't change? Any ideas appreciated
Number of posts : 393
PostSubject: Re: Rear brake issue,    Rear brake issue,  I_icon_minitimeSat Mar 02, 2024 7:02 pm
Are you sure the bleed valve at the rear caliper was not clogged? You can unscrew it completely and check. You can also open the bleed valve and push the pistons back into the caliper which ought to squirt fluid out of the bleeder (as a test).
You have not said what has led you to need to do the brake bleed. Air likes to hide in brake lines and will float up to the master. Once there is air in the master this can be a blighter to shift but vacuum bleeding should overcome this.
Number of posts : 1570
PostSubject: Re: Rear brake issue,    Rear brake issue,  I_icon_minitimeSun Mar 03, 2024 2:53 pm
Doing a search in the search bar will bring up lots of info on this topic. To summarize, I had rear brake problems for ages with various results; until I replaced the Master Cylinder seals. It was the last piece of the jigsaw. Maybe start there?
Rear brake issue,
» Second Service
» Fjs 600 front brake issue
» Binding rear brake!!
» Rear Brake not working at all
Honda Silver Wing Scooter Forum :: Other Scooters and Motorcycles-
