95konig Scooter Rider
Number of posts : 17 Location : AZ, USA Points : 458 Registration date : 2023-03-15
| Subject: Cylinder Head Replacement Fri Mar 08, 2024 11:15 pm | |
| Hello again. I'm back with more maintenance questions. I am replacing the cylinder head on my 2002 Silverwing and am following the Honda service manual. I am at the "Remove the cylinder head" step, but it feels like the manual isn't providing enough detail for that and also skipped a few steps leading up to that. So my questions are:
1) Should I disconnect the throttle body inlet pipes before or after I take the cylinder head off? The manual didn't mention the inlet pipes at all, and as far as I can tell, they aren't attached to any other hard part.
2) Does the hinge(?) bolt at the bottom of the cylinder head need to be removed first or should I leave it connected while breaking the cylinder head loose?
3) How does one actually "remove the cylinder head"? Tap it with a mallet/hammer? Give it a good whack with a hammer? Is there a pry point I can stick something like a breaker bar?
Thank you in advance for all of the help. I can attach pictures as needed for clarity and I apologize if I've used the wrong terminology. |
