| storage compartment latch | |
+6heinlein oldwingguy KeystoneWimg tarmacburner2 billc. TxS'wingrider64 10 posters |
TxS'wingrider64 Scooter Rider
Number of posts : 13 Age : 60 Location : Jasper, Tx Points : 4671 Registration date : 2011-08-23
| Subject: storage compartment latch Thu Oct 20, 2011 5:13 pm | |
| I can't help but notice the picture above on the main "forum". The right hand, forward storage compartment appears to have a piece of electrical tape holding it closed. Resembles mine, except I have TWO pieces of tape on mine! I thought the "latch" mechanism was broken, so I ordered a new one, and it came in the other day ($2.47, I think). After receiving the new one, and comparing it to the old one, I determined the old one is NOT broken, after all! I still can't seem to get the darned thing to latch, though. Anyone know what I can do to adjust it, or anything?
Thanks, Tracy |
billc. Maxi-Scooter Rider
Number of posts : 189 Age : 75 Location : Atlanta, Ga. Points : 5427 Registration date : 2010-02-19
| Subject: Re: storage compartment latch Fri Oct 21, 2011 9:33 pm | |
Number of posts : 1099 Age : 70 Location : Cleveleys, Lancashire, England Points : 6347 Registration date : 2010-03-27
| Subject: Re: storage compartment latch Sat Oct 22, 2011 4:54 am | |
| Two pieces of tape - that is what we would call a 'belt and braces fix' Cheers, |
KeystoneWimg Scooter Rider
Number of posts : 1 Location : arizona Points : 2739 Registration date : 2016-11-19
| Subject: Re: storage compartment latch Sat Nov 19, 2016 2:27 pm | |
| Got a part number for that latch by chance? |
| Subject: Re: storage compartment latch Sat Nov 19, 2016 4:17 pm | |
| Re the forum photo; I kinda doubt that it's tape holding that cubby lid down. That's an '09 model with the 'new' type dash with the improved cubby lids. If you've got a S'Wing with a painted dash & cubby lids, the left side should still be able to be locked, but the right side cubby is infamous for popping open and spilling the contents in the worse of possible locations.
Aside from duct tape the only effective fix for the right side is to replace the whole cubby with the later version. You can order all the parts for both sides individually from Partzilla, but it so happens that I have an entire right side cubby available if anyone is interested --of course it being the 'new' version it's black. PM me if interested.
Number of posts : 1936 Location : Hocking Hills U.S.A. Points : 5175 Registration date : 2016-01-29
| Subject: Re: storage compartment latch Sat Nov 19, 2016 5:11 pm | |
| Is it possible to use the lid from an older model with the NEW compartment, just swap lids. |
heinlein Scooter Rider
Number of posts : 10 Location : Placerville, CA Points : 2061 Registration date : 2018-10-06
| Subject: Re: storage compartment latch Sun Oct 07, 2018 8:20 pm | |
Tim Does the new style rattle like my old style does? Bob |
| Subject: Re: storage compartment latch Sun Oct 07, 2018 11:45 pm | |
| No rattle. The new style firmly latches.
I've still got the above mentioned new style right side cubby available if you (or anyone) are interested. |
| Subject: Re: storage compartment latch Mon Oct 08, 2018 1:05 pm | |
| Hey All, my right hand compartment had blu-tac holding it shut when I bought my 2001 SW. I ordered the replacement latch parts from David Silver Spares in the UK. Once fitted, the cover works fine. It's a bit temperamental but it works. Be gentle with it. Mine now stays closed when riding and opens when required...and it doesn't rattle. |
London Auto SC Scooter Rider
Number of posts : 2 Location : London UK Points : 1382 Registration date : 2020-08-08
| Subject: Re: storage compartment latch Sat Aug 08, 2020 2:02 pm | |
| Hi all. Newbie here. How easy is it To remove tne right hand storage compartment? I need to secure my side fairing as it looks like the panel fastener is going in to fresh air so hoping to remove storage compartment so I can secure it through with a bolt maybe. Thanks |
steve_h80 Silver Wing Expert
| Subject: Re: storage compartment latch Sun Aug 09, 2020 3:04 pm | |
| Lift the lid, remove the screw and wiggle the box out. |
| Subject: Re: storage compartment latch Sun Aug 09, 2020 3:34 pm | |
| - steve_h80 wrote:
- Lift the lid, remove the screw and wiggle the box out.
^^this + squeeze in the sides of the compartment. EZ Peasy. |
| Subject: Re: storage compartment latch Sun Aug 09, 2020 3:36 pm | |
| I took out the glove box and drilled a small hole at an angle to the glove box housing. I then used a small cable tie which is strong and quite unnoticed. |
| Subject: Re: storage compartment latch | |
