Naples Vidiot Scooter Rider
Number of posts : 13 Location : Naples, Florida Points : 1153 Registration date : 2021-04-05
| Subject: Re: Air Filter Pictorial Thu Apr 15, 2021 9:09 am | |
| Subject: Re: Air Filter Pictorial Thu Apr 15, 2021 10:13 am | |
| Yeah, the K&N filter doesn’t seat properly and it is missing that post as well as not needing one of the dozen or so screws to hold the filter in. No worries.
Regarding your panel concerns; why not grease the tip of that mount post or rubber grommet? It’ll make it much less concerning to remove the panel next time. Same thing on the left panel. My 2¢ |
| Subject: Re: Air Filter Pictorial Thu Apr 15, 2021 10:24 am | |
| I, too had problems with K & N filters not fitting scooter just right----Burgman 400---SilverWings ridden to about or near 50,000 miles, never went thru the bother of changing them, was going to trade them anyway I find pavement ridden scooters have good filter life of at least 30,000 miles----even more for trailer bikers!
Had 2 Honda CB750 Nighthawk's----each traded at 50,000 mile mark---put K & N filters in them at beginning (they fit) and I left them alone for life of bike, including Alaska trips. No trouble |
| Subject: Re: Air Filter Pictorial Thu Apr 15, 2021 12:00 pm | |
| Just a few years ago the 'drilled airbox and K & N filter' mod seemed to a be very popular topic on maxi forums, or to add to your Signature with all your other bits. I never could see the point of the extra expense and drilling unnecessary holes personally. Although I do remember all sorts of outlandish claims about extra performance from it's devotees.
| Subject: Re: Air Filter Pictorial Thu Apr 15, 2021 12:04 pm | |
| For me----K & N, could be cleaned-----only performance was intake noise from Burgman and same with CB750. |
zrx212 Silver Wing Expert
| Subject: Re: Air Filter Pictorial Thu Apr 15, 2021 5:50 pm | |
| Well experiences will vary, my oem did not look good at 11k when I got bike , I check/vacuum clean my air filters at oil changes in all my vehicles, we have 4 month long pollen season in Florida, May/June is a good time replace/ck air filters. |
| Subject: Re: Air Filter Pictorial Thu Apr 15, 2021 7:47 pm | |
| I was never a fan of K&N after using one and seeing all the junk it didn't filter left behind in airbox. That's a dirty filter for 11K. Mine never look like that at but never let it go that long 8K or less. Dirt wears out internal engine parts very quickly. |
| Subject: Re: Air Filter Pictorial Thu Apr 15, 2021 8:30 pm | |
| - Mech 1 twa wrote:
- Never was a K&N fan after using one and seeing all the junk it didn't filter left behind in airbox.
That's a dirty filter for 11K. Mine never look like that at but never let it go that long 8K or less. Dirt wears out internal engine parts very quickly. That's what I found on my recently purchased used bike, IAC the inside of my airbox was spotless, so that filter was doing is job, I wonder if PO had many pets, or .... "The K&N air filter debate" is kinda like a "oil debate" no end in sight, no winners, just opinions I like the oiled foam filters in my smaller scooters, just no good for Fuel Inj., O2 sensors, emissions, etc... |
| Subject: Re: Air Filter Pictorial Thu Apr 15, 2021 9:56 pm | |
| Older type foam filters worked great some recommended engine oil but a good foam oil was super sticky and a better option. OE got away from that just sell you a new one and less trouble cleaning it letting it dry and reoil. Dirt biking days all foam type always had 2 filters 1 clean ready to install. Filter type really won't change much with Fuel Inj. on newer bikes with O2 sensors. |
| Subject: Re: Air Filter Pictorial Fri Apr 16, 2021 8:17 am | |
| I agree with the above, some like K&N and some don't. I do! Have used them for YEARS with no problems, cars, trucks, motorcycles and scooters. I never find any residue under them in the air box and they are easy to clean and replace in the bike.
It's kind of like why many will NOT use Fram oil filters, they quote a test done by an individual on the internet done in 1996. DOH.
I have used Fram oil filters many times as well with no failures (other brands yes).
Moral to the story is use what YOU like! |
| Subject: Re: Air Filter Pictorial Sat Apr 17, 2021 9:21 am | |
| Wow, thanks for all your input. Nothing personal with K&N but was expecting it to seal / seat properly at 45 bucks. I ended up with the hiflofiltro but Frustrated having my “twist and shout” unassembled waiting for the Amazon delivery truck. By Monday I’ll be up and running on the city streets of Naples, Florida. Cheers! |
Spud76 Scooter Rider
Number of posts : 8 Age : 47 Location : Belfast, Northern Ireland Points : 590 Registration date : 2022-10-17
| Subject: Re: Air Filter Pictorial Thu Nov 03, 2022 9:17 am | |
| Thanks for the pictorial, very helpful! |
silvercat600 Scooter Rider
Number of posts : 19 Location : Montreal Points : 1415 Registration date : 2020-07-25
| Subject: Re: Air Filter Pictorial Wed Jun 21, 2023 7:20 pm | |
| - JeffR wrote:
- Hi,
I did a Pictorial on replacing the air filter for the Silver Wing. I replaced my stock filter with the K&N but this can be used for just performing maintenance too. If you have any questions or comments please respond to this post.
This is also an easy procedure if you follow the step-by-step instructions. It can save you a lot of money to do it yourself.
Here is a .pdf format link: Thank you for your great totarial. |
| Subject: Re: Air Filter Pictorial | |
