Gyro Touring Scooter Rider
Number of posts : 321 Age : 71 Location : Frontenac, Ks Points : 4449 Registration date : 2013-04-07
| Subject: Fat Riders and Trikes Wed Jun 19, 2013 11:33 am | |
| I discovered, to my dismay, that the rear fender of the S'wing was hitting the rear fiberglass cover on the Danson kit! It was wearing through the fiberglass! I did not want to change the shock settings, so I decided to trim one inch off the end of the fender. After trimming and reshaping everything, I applied a piece of masking tape over the rub marks on the Danson rear cover. Ack! It still rubbed! Well, I reluctantly cut another inch off the rear fender. It was actually a fairly easy task using the router attachment to my Dremel tool to make the horizontal cut and a woodworkers backsaw to make the angle cuts. Radiusing was done with a Microplane. The smaller piece of fender in the pic below was the first piece I removed from the fender. I do not think the final result looks bad at all. If I still get any rubbing when riding two-up, I will adjust the shocks up a notch, even though I do not want to stiffen the ride. :P |
Scroller Scooter Rider
Number of posts : 35 Age : 86 Location : NB ,Can Points : 4059 Registration date : 2013-05-25
| Subject: Re: Fat Riders and Trikes Wed Jun 19, 2013 11:39 am | |
| Gyro : looks like you have your problem solved,,good lookiNg job perhaps you should pass this tip to the trike manufacturer for their reference .
Cheers, ScrolledScrolled |
| Subject: Re: Fat Riders and Trikes Wed Jun 19, 2013 12:31 pm | |
| I think I'll do that! Thanks for the suggestion. |
KurtPerthWA Silver Wing Guru
Number of posts : 1709 Age : 75 Location : Belmont, Perth WA Points : 7969 Registration date : 2009-01-19
| Subject: Re: Fat Riders and Trikes Fri Jun 21, 2013 7:25 am | |
| Sorry Gyro, just Can't help myself somtimes..... |
| Subject: Re: Fat Riders and Trikes Fri Jun 21, 2013 10:48 am | |
| :lol!: Hey! I resemble that remark! (Pic is from 2004, but other than more grey in the beard, I'm about the same.) |
| Subject: Re: Fat Riders and Trikes | |
