» LF extended back rest
Steering stem top nut octagonal socket I_icon_minitimeby Rzor93 Today at 4:29 pm
» Goodbye guys
Steering stem top nut octagonal socket I_icon_minitimeby Rzor93 Today at 4:27 pm
» noise under load
Steering stem top nut octagonal socket I_icon_minitimeby dmosemorris Yesterday at 1:30 pm
» checking the oil
Steering stem top nut octagonal socket I_icon_minitimeby arcamedies13 Yesterday at 9:32 am
Steering stem top nut octagonal socket I_icon_minitimeby Terry Smith Thu May 16, 2024 6:39 pm
» Hello from Illinois!
Steering stem top nut octagonal socket I_icon_minitimeby DescendingRaven Wed May 15, 2024 2:13 pm
» Silverwing Brakes
Steering stem top nut octagonal socket I_icon_minitimeby Terry Smith Tue May 14, 2024 11:57 pm
Steering stem top nut octagonal socket I_icon_minitimeby BrianInVA Mon May 13, 2024 12:53 pm
» Left brake micro-switch
Steering stem top nut octagonal socket I_icon_minitimeby Johnboy Fri May 10, 2024 7:57 pm
Steering stem top nut octagonal socket I_icon_minitimeby BrianInVA Fri May 10, 2024 5:36 pm
4 posters
Steering stem top nut octagonal socket Empty
PostSubject: Steering stem top nut octagonal socket   Steering stem top nut octagonal socket I_icon_minitimeMon Oct 06, 2014 6:25 pm
Lathe owner/access desirable or a nearby engineering shop, made from a piece of mild steel thick walled (bushing) tube, outside diameter to suit inside diameter of your stem nut tool x 3" long, bore through 32mm (1.26"), counter bore 34.5mm (1.359") leaving a "land" of the original bore approx 10mm (0.393").
After machining place the "blank" in a bench vice with the "land" facing upwards, colour the end with a marker pen, place the nut  on the blank & scribe around.
With a small pillar file (5/32" chainsaw file is ideal) cut down to the points, now with a small flat file (chainsaw ripper file is ideal) cut the flats, after filing operations test the fit of the nut, do any fettling to achieve a good fit then weld a 1/2" drive socket on the plain end.
Width of flats (0.532")
Steering stem top nut octagonal socket DSCF0296_zpsbc1f4bef
Width between flats (1.266")
Steering stem top nut octagonal socket DSCF0294_zps6fb78fb3
Width between points (1.362")
Steering stem top nut octagonal socket DSCF0293_zpsb307ba49
Nut in socket
Steering stem top nut octagonal socket DSCF0261_zps3abf0392
Finished article
PostSubject: Re: Steering stem top nut octagonal socket   Steering stem top nut octagonal socket I_icon_minitimeTue Oct 07, 2014 11:03 am
Thank you again for showing us your amazing craftsmanship. I sure wish I had machine shop access and the skills to fabricate tools, etc the way you can. I'm envious.
Here is a link to the Italian SW forum with plans for a DIY clutch bell installer. Given your resources you might like the challenge of making this, most elusive, tool:
http://translate.google.com/translate?hl=en&sl=it&u=http://www.swci.it/forum/&prev=/search%3Fq%3Dswci%2Bsilverwing%26client%3Dsafari%26hl%3Den%26biw%3D1024%26bih%3D671
And here is a link from the same site for constructing a clutch bell removal tool:
http://translate.google.com/translate?hl=en&sl=it&u=http://www.silverwing.it/&prev=/search%3Fq%3Dswci%2Bsilverwing%2Bitaly%26biw%3D1024%26bih%3D671
PostSubject: Re: Steering stem top nut octagonal socket   Steering stem top nut octagonal socket I_icon_minitimeTue Oct 07, 2014 12:29 pm
Thank you for your kind words Tim Embarassed If you can get a shop to machine the blank,filing the flats only take 1/2 hour or so.
Those look like a winter project Smile Fine pitch internal metric screw-cutting on an old imperial lathe sounds like fun
Speaking of things on SWCI, over the weekend I plan to do the front wheel double bearing "conversion" ( http://www.silverwing400.it/index.php?option=com_content&task=view&id=316&Itemid=83 ), the bearings need changing anyway & I'm hoping that doubling them up will help spread the shock loads & thus bearing wear from the vast amount of pot holes we have on UK roads.
PostSubject: Re: Steering stem top nut octagonal socket   Steering stem top nut octagonal socket I_icon_minitimeTue Oct 07, 2014 1:12 pm
The Bern wrote:
<>Speaking of things on SWCI, over the weekend I plan to do the front wheel double bearing "conversion" ( http://www.silverwing400.it/index.php?option=com_content&task=view&id=316&Itemid=83 ), the bearings need changing anyway & I'm hoping that doubling them up will help spread the shock loads & thus bearing wear from the vast amount of pot holes we have on UK roads.
I'd considered doing that as well, but  adding an additional bearing to each side eliminates the existing seal. Even with that axle seal and the sealed bearings I have still had two bearings fail due to water (and I suppose road salts) getting past the seals and contaminating the bearings.
It seems to me that, given the reports of the winter road conditions in the UK, that having the bearings exposed will certainly encourage a bearing failure
Maybe the winter road treatments in Italy are more bearing friendly.
PostSubject: Re: Steering stem top nut octagonal socket   Steering stem top nut octagonal socket I_icon_minitimeTue Oct 07, 2014 3:51 pm
Interesting point Tim, I shall think on a bit more about a way to do an axle wiping seal
PostSubject: Re: Steering stem top nut octagonal socket   Steering stem top nut octagonal socket I_icon_minitimeSat Oct 11, 2014 4:49 pm
I think I got it nailed Tim Wink will get some pic's up after its fitted
MadDog
Number of posts : 37
Registration date : 2016-07-11
PostSubject: Re: Steering stem top nut octagonal socket   Steering stem top nut octagonal socket I_icon_minitimeFri Jul 22, 2016 10:50 am
I must be a bit thick wheres the access to the steering stem top nut ? My steering is a might to easy will nipping up STN stiffen it a bit.
PostSubject: Re: Steering stem top nut octagonal socket   Steering stem top nut octagonal socket I_icon_minitimeFri Jul 22, 2016 5:11 pm
Remove the handlebar cover(s), remove the handlebar, remove the "handle post" clamp.  You'll need a special socket to fit that nut --it's octagonal.
Check eBay for a "Sunex 2804zd 1/2" drive 32mm 12 point Deep spindle nut socket"
Once you've removed that octagonal lock nut you'll need to tighten the stem bearing nut with a spanner tool.
MadDog
PostSubject: Re: Steering stem top nut octagonal socket   Steering stem top nut octagonal socket I_icon_minitimeSat Jul 23, 2016 3:57 am
Many thanks C_J couldn't find in th SW Shop Manual I would have been searching forever , don,t need to buy socket gotta pal who was an AA man he's got the lot will be able to borrow one . If not there are more reasonably priced sockets on ebay for what expect will be a one off job. Thanks again
HORNBLOWER
Number of posts : 171
PostSubject: Re: Steering stem top nut octagonal socket   Steering stem top nut octagonal socket I_icon_minitimeSun Jul 24, 2016 3:47 am
Have you ever tried using ACF 50 grease?
I was introduces to their products on the honda blackbird site a few years ago. Many owners use the oil that can be put onto polished alloy to stop it corroding with all the salt we have here in the UK.I tried it and found that a small application in Autumn (wipe on, leave overnight, wipe off) would protect my bike all winter! At a trade show I saw their grease which they say it can be used in boat launching trailers going into sea water and still protect the bearings. I bought some and have never had to replace a wheel bearing since on any of my bikes for the past 6 years.
I work with a lot of kids teaching whole classes to play trumpet and other brass instruments, I started using this grease on the tuning slides a few years ago and have had equally as good results.
ACF50 seems to inhibit corrosion on Steel, Brass, Copper, Niickle and alloy. I'm not sure if you can get it over in the states but seeing as it was initially made for PanAm to keep their shiny alloy aeroplanes sparkling I would expect you can.
It is quite expensive but a little goes a long way!
PostSubject: Re: Steering stem top nut octagonal socket   Steering stem top nut octagonal socket I_icon_minitimeSun Jul 24, 2016 8:49 pm
ACF 50 Grease isn't all that expensive but the shipping charge from the UK is about the same as the product. Either the small tube or the 16 oz can, same shipping charge.
Is the product so good that I'm going to toss away my lithium grease?
Number of posts : 4180
PostSubject: Re: Steering stem top nut octagonal socket   Steering stem top nut octagonal socket I_icon_minitimeMon Jul 25, 2016 1:42 am
If you look on your US eBay site, you'll find there's lot's of UK suppliers of ACF-50 grease offering free postage/shipping.
HORNBLOWER
PostSubject: Re: Steering stem top nut octagonal socket   Steering stem top nut octagonal socket I_icon_minitimeTue Jul 26, 2016 7:27 am
Try it and see Tim its all i use now except for Red Silicon grease on the hydraulics. The liquid is brilliant too and in my opinion much better than WD40!!!!!
» Steering Stem Socket
» Steering stem
» Steering stem nut.
» Steering stem nut tool
» Left hand valve stem possible?
