| ABS lamp on | |
+3Easyrider Cookie Siataukreg 7 posters |
Number of posts : 221 Age : 70 Location : uk saddleworth Points : 3845 Registration date : 2014-08-24
| Subject: ABS lamp on Wed Jun 15, 2016 3:46 pm | |
| Hi guys anyone had problems with abs red lamp on common issues what are they scoot is 2007 not seen it yet but got to sort it out well got the scoot and turns out engine has bottom end gone so used the engine/trans out of the 2003 scoot and a few other bits its now up and running not road tested it yet so not gone any further with the ABS issue as yet
Cookie Super Scooter Rider
Number of posts : 233 Location : Essex UK Points : 4859 Registration date : 2011-10-03
| Subject: Re: ABS lamp on Wed Jun 15, 2016 4:36 pm | |
| Hi, I've not had the problem myself but I've seen it on various forums in regard to numerous different bikes. The problem often seems to be the positioning of the sensors in relation to the reluctor rings (one on each wheel as you probably know). They seem to get knocked out of position when wheels are removed or refitted or when a bit of over enthusiastic cleaning/scrubbing is being done. They can apparently even get 'swamped' by a heavy build up of mud or road crap.
I think I would... 1. Make sure the rings are nice and straight and haven't got bent or bashed, straightening them if they are bent and clean them up if full of muck. 2. Make sure the sensors are clean and in position correctly, close but not touching the rings and not at weird angles etc. 3. Check any connections that go to the sensors.
None of this costs any cash so it's where I'd start.
Although the ABS system is quite complex it does seem to be pretty reliable. Hopefully someone's just clobbered a ring or sensor when getting a wheel in or out or something similar.
Good luck and please let us know of any findings. |
Number of posts : 1012 Age : 73 Location : HI Points : 4163 Registration date : 2015-12-18
| Subject: Re: ABS lamp on Thu Jun 16, 2016 12:00 am | |
| Not sure what your asking. If your question is that your ABS lamp does not go off after you exceed 6MPH, it could be a failing battery. Have your battery load tested at an auto parts store. |
| Subject: Re: ABS lamp on Thu Jun 16, 2016 12:02 am | |
| Wait a minute. Are you not parting out your Swing on another post? |
steve_h80 Silver Wing Expert
| Subject: Re: ABS lamp on Thu Jun 16, 2016 1:44 am | |
| Well if you can't sort the abs breaking it for spares is always an option :-) |
| Subject: Re: ABS lamp on Fri Jun 17, 2016 3:13 am | |
| - steve_h80 wrote:
- Well if you can't sort the abs breaking it for spares is always an option :-)
| Subject: Re: ABS lamp on Fri Jun 17, 2016 6:46 pm | |
| Agree with Easyrider, a weak battery often can cause ABS self check to fail. I've had the same problem with a BMW K1100LT. The battery was good enough to start the bike but the ABS self test failed due to low battery. The self test is done before the engine starts and the bike's alternator isn't charging. Sometimes you can ride a couple miles, shut off the engine and then restart which will clear the ABS warning until the next time. |
Number of posts : 379 Location : Yuma, AZ Points : 3335 Registration date : 2016-06-01
| Subject: Re: ABS lamp on Fri Jun 17, 2016 7:22 pm | |
| If the ground isn't tight on the battery post, all kinds of things can start flashing at you. I have seen it happen. |
DickO Founding Member
Number of posts : 1018 Age : 79 Location : Atchison, KS Points : 6775 Registration date : 2008-12-23
| Subject: Re: ABS lamp on Sat Jun 18, 2016 6:21 pm | |
| I had the same problem with a weak battery (that I didn't think was weak at all). ABS lite stayed on after a horrifying jump start (don't ask). Anyway, charged the battery again and the lite went out on the next test run. Funny thing though; it took longer to go out then (battery actually needed replacement). So... double check that battery or let a battery specialist do it for you. Mine had good enough voltage but the cranking amps were way to low. |
| Subject: Re: ABS lamp on Mon Jun 27, 2016 4:14 am | |
this is a different scoot 2007 breaking a 2003 had to use the engine from the 2003 as the 2007 had big end gone i am breaking the engine top end is good |
| Subject: Re: ABS lamp on Tue Jun 28, 2016 3:10 pm | |
| - siataukreg wrote:
this is a different scoot 2007 breaking a 2003 had to use the engine from the 2003 as the 2007 had big end gone i am breaking the engine top end is good Sorry, but can someone translate for me. Thanks in advance. |
| Subject: Re: ABS lamp on Tue Jun 28, 2016 10:43 pm | |
| Yes, "Easyrider"... My thoughts too... why is it folks are so lazy and thoughtless to not use even a modicum of proper punctuation and then we have to use our own thought processes to to make up for their lack of effort (if that's possible from what they've tried to put in print)... I realize no one is perfect including myself and I don't want to sound like the literary police, but, please, put at least a "little" thought into your statements... |
| Subject: Re: ABS lamp on | |
| ABS lamp on | |
