» Rear wheel valve stem
Radiator seems blocked I_icon_minitimeby MikeO Yesterday at 6:19 pm
Radiator seems blocked I_icon_minitimeby COMick Yesterday at 6:13 pm
Radiator seems blocked I_icon_minitimeby xwelder Yesterday at 12:31 pm
Radiator seems blocked I_icon_minitimeby sonuvabug Thu Nov 21, 2024 4:17 pm
Radiator seems blocked I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Radiator seems blocked I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Radiator seems blocked I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Radiator seems blocked I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Radiator seems blocked I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Radiator seems blocked I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
4 posters
GoonerKev
GoonerKev
Number of posts : 409
Registration date : 2019-04-09
Radiator seems blocked Empty
PostSubject: Radiator seems blocked   Radiator seems blocked I_icon_minitimeFri Apr 12, 2019 6:35 pm
Happend to look at the radiator when I was putting the alarm disc lock on and noticed that the radiator looked all blocked, but when running the temp is fine !
I can rig up a air cylinder from my my old department in the Fire service and give it a blast but don't want to damage anything, thoughts please.
Kev
Number of posts : 1935
PostSubject: Re: Radiator seems blocked   Radiator seems blocked I_icon_minitimeFri Apr 12, 2019 9:43 pm
If you have road crap, bugs ect. warm soapy water liberally applied to the front, let set for 10 or 15 minuets then flush out from the back side of the radiator. Avoid poking the fins and don't use a pressure washer to flush the radiator.
PostSubject: Re: Radiator seems blocked   Radiator seems blocked I_icon_minitimeFri Apr 12, 2019 11:32 pm
After you've cleaned off the crud & grime consider adding a mudflap.
GoonerKev
GoonerKev
PostSubject: Re: Radiator seems blocked   Radiator seems blocked I_icon_minitimeSat Apr 13, 2019 2:22 am
Oldwingguy
Many thanks for the help and advice, may even fix some fine mesh in front.
Kev thumbs up
Number of posts : 757
PostSubject: Re: Radiator seems blocked   Radiator seems blocked I_icon_minitimeSat Apr 13, 2019 9:03 am
I have the fine mesh in front of mine. It is a piece of window screen zip-tied to the plastic grille part in front. Doesn't need to be too elaborate, just thread it behind that grille and stretch it out. Mostly keeps itself in place. I fashioned a mud flap out of a plastic flower pot: Meldrew's idea ! It is attached by two strips of gorilla double-sided tape. Hasn't moved one bit in 3 years ! I put the screen material in my car too !
Jay.
GoonerKev
GoonerKev
PostSubject: Re: Radiator seems blocked   Radiator seems blocked I_icon_minitimeSat Apr 13, 2019 9:08 am
Many thanks cotetoi, I will do it that way then Wink
PostSubject: Re: Radiator seems blocked   Radiator seems blocked I_icon_minitimeSat Apr 13, 2019 9:27 am
Yes on the mesh, have it tucked in there on everything including the tractor.
» New member from the uk
» Radiator hoses
» Radiator Guard
» New radiator needed
» Using heat from the radiator?
