» Rear wheel valve stem
Headlight Switch - an Insight I_icon_minitimeby MikeO Yesterday at 6:19 pm
Headlight Switch - an Insight I_icon_minitimeby COMick Yesterday at 6:13 pm
Headlight Switch - an Insight I_icon_minitimeby xwelder Yesterday at 12:31 pm
Headlight Switch - an Insight I_icon_minitimeby sonuvabug Thu Nov 21, 2024 4:17 pm
Headlight Switch - an Insight I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Headlight Switch - an Insight I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Headlight Switch - an Insight I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Headlight Switch - an Insight I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Headlight Switch - an Insight I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Headlight Switch - an Insight I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
4 posters
Number of posts : 1607
Headlight Switch - an Insight Empty
PostSubject: Headlight Switch - an Insight   Headlight Switch - an Insight I_icon_minitimeFri Jul 22, 2022 5:29 pm
If it ain’t broke, fix it anyway! I decided to have a look at the headlight switch on my SW because it felt a bit notchy and stiff. When I released the switch ‘button’ from the assembly it came off with a ‘ping’ and the button, the spring and the ball bearing went all over the garage floor. Yikes!
I found the button and the spring but the bearing disappeared into my garage equivalent of the Bermuda Triangle. Now what?
Easy. Measure the size of the spring outer circumference and buy some new ball bearings of the correct diameter. Metal or plastic ball bearings? I went for plastic.
I’m not only a Silverwing Guru, I’m a genius. It fitted perfectly and after re-attaching the button to the switch it worked. However, there was no improvement in the notchy and stiff operation.
If you look at the picture below, the ‘track’ of the ball bearing over the position ‘notches’ is stepped in a peculiar manner. This is probably the case in most switch assemblies but it sure confused me. Anyhow, if this folly helps anybody else who lies awake at night wondering if there is a problem with their headlight switch, then my work is done.
Maybe that’s why modern motorcycles have lights permanently ON.
The steps of the bearing track:
Headlight Switch - an Insight Switch10
The switch button with the spring in its recess:
Headlight Switch - an Insight Switch15
The switch button with the new ball bearing ready to install:
Headlight Switch - an Insight Switch13
The button is held in place by a clip edge on the switch stem which snaps into a slot in the underside of the switch button:
Headlight Switch - an Insight Switch14
Here are the plastic bearings I bought:
Headlight Switch - an Insight Ball_b11
I hope that my yearning to discover how things work will help all SW owners sleep better thumbs up
Number of posts : 382
PostSubject: Re: Headlight Switch - an Insight   Headlight Switch - an Insight I_icon_minitimeFri Jul 22, 2022 8:51 pm
Interesting…I was in the past trying to clean my ST1100 indicator switch (a few years back)- I lost the spring (same circumstances, kind of fell apart when I wasn’t looking)- I used a cut spring from a pen and it was nearly the right size- worked perfectly. You know what they say: ‘Necessity is the mother of invention’
Number of posts : 1037
PostSubject: Re: Headlight Switch - an Insight   Headlight Switch - an Insight I_icon_minitimeSat Jul 23, 2022 3:25 am
From the "if it ain't broke, break it" school of maintenance 🙂
cello33
Number of posts : 150
Registration date : 2018-07-09
PostSubject: Re: Headlight Switch - an Insight   Headlight Switch - an Insight I_icon_minitimeSat Jul 23, 2022 3:16 pm
Yes life as a habit of crapping on you at every opportunity......the bb will turn up one day I,m sure Smile
» A little in-depth insight on rollers/pulleys?
» Headlight (Low and High) won't turn on
» T-Mode Switch
» Ignition switch
» Kill Switch Usage
