» Rear wheel valve stem
2009 Silverwing 600 fuel leak I_icon_minitimeby MikeO Yesterday at 6:19 pm
2009 Silverwing 600 fuel leak I_icon_minitimeby COMick Yesterday at 6:13 pm
2009 Silverwing 600 fuel leak I_icon_minitimeby xwelder Yesterday at 12:31 pm
2009 Silverwing 600 fuel leak I_icon_minitimeby sonuvabug Thu Nov 21, 2024 4:17 pm
2009 Silverwing 600 fuel leak I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
2009 Silverwing 600 fuel leak I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
2009 Silverwing 600 fuel leak I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
2009 Silverwing 600 fuel leak I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
2009 Silverwing 600 fuel leak I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
2009 Silverwing 600 fuel leak I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
4 posters
Grandnglorious
Number of posts : 33
Registration date : 2022-09-23
2009 Silverwing 600 fuel leak Empty
PostSubject: 2009 Silverwing 600 fuel leak   2009 Silverwing 600 fuel leak I_icon_minitimeFri Oct 14, 2022 1:41 pm
I added fuel to the tank yesterday. No fuel on floor but had a strong smell of gas in garage in the morning. I started to get SW off center stand and gas started running out from under the SW. When I quit moving it the leak stopped. I sat on the bike to move it outside and it started pouring out again profusely. Moved outside, got still and stopped leaking. How do I find the leak, whether tank or line?
Number of posts : 1607
PostSubject: Re: 2009 Silverwing 600 fuel leak   2009 Silverwing 600 fuel leak I_icon_minitimeFri Oct 14, 2022 1:59 pm
There could be hole in the fuel tank at such a level that swishing around of the fuel, (i.e. moving the bike around), is causing it to seep out.
Grandnglorious
PostSubject: Re: 2009 Silverwing 600 fuel leak   2009 Silverwing 600 fuel leak I_icon_minitimeFri Oct 14, 2022 3:34 pm
Looking for that now but it does not seep. It pours!  Stops as soon as bike is still. Wondering if it could be. Cracked rubber hose that opens up when pressured??
PostSubject: Re: 2009 Silverwing 600 fuel leak   2009 Silverwing 600 fuel leak I_icon_minitimeFri Oct 14, 2022 4:52 pm
Going back to your first post you mention that your SW is a 2009 with 3600 miles. That suggests that it has been sitting unused for quite awhile. If it been sitting for months with less than a full tank there is a good possibility that the tank has developed a rust hole.
The fuel lines are under pressure (~40 psi) when the ignition is ON. So if it is not leaking when the SW is running and on the center stand and only when the SW is moved and the fuel is sloshed about, then that indicates that there is a hole in the upper section of the tank.
Hopefully not.
But if so then the best option is to find a good used tank on eBay. However if you need to order a new one from Ron Ayres or Partzilla (check both) take some comfort in that the new Honda tanks come complete with the fuel pump and fuel level sending unit as part of the deal.
You’ll need to remove the panel under the seat to expose the top of the fuel tank to inspect.
Please let us know how you get on with this.
Grandnglorious
PostSubject: Re: 2009 Silverwing 600 fuel leak   2009 Silverwing 600 fuel leak I_icon_minitimeSat Oct 15, 2022 9:27 am
Took the seat off and panel. Could not see much until I rocked the bike and sloshed gas around and saw gas pouring out from around the fuel pump cover. Looks like the seal on the fuel pump is shot which means the fuel tank will have to come off. Not looking forward to that.
PostSubject: Re: 2009 Silverwing 600 fuel leak   2009 Silverwing 600 fuel leak I_icon_minitimeSat Oct 15, 2022 10:03 am
There are several posts here about R & R the fuel tank. Use the Search window, above. The biggest PITA is removing that 3rd nut just above the fuel fill. Somebody posted a tip on that.
Grandnglorious
PostSubject: New one piece fuel tank assembly   2009 Silverwing 600 fuel leak I_icon_minitimeSat Oct 22, 2022 2:19 pm
Hopefully not.
Grandnglorious
PostSubject: Re: 2009 Silverwing 600 fuel leak   2009 Silverwing 600 fuel leak I_icon_minitimeSat Oct 22, 2022 2:20 pm
I finally Got everything apart and fuel tank dropped, but what an ordeal. I would like to find the one piece assembly but can not find all separate parts. We’re you referring to a newer one piece model that fits a 2009?
BrianInVA
BrianInVA
Number of posts : 295
Registration date : 2022-04-17
PostSubject: Re: 2009 Silverwing 600 fuel leak   2009 Silverwing 600 fuel leak I_icon_minitimeSat Oct 22, 2022 3:37 pm
I had to replace my 2006 tank due to rust holes in the bottom from sitting in storage for five years next to a saltwater bay. I ended up ordering a new tank and it came with the fuel pump, fuel filter and fuel gauge sending unit already assembled and installed. Frankly I think I’d recommend that instead of trying to replace the gasket, in case other parts of the fuel tank are ready to spring a leak too.
Prior to replacing my tank I tried a two part epoxy and fiberglass metal tank repair kit. It worked great, but another hole opened up in the tank within 24 hours.
PostSubject: Re: 2009 Silverwing 600 fuel leak   2009 Silverwing 600 fuel leak I_icon_minitimeSat Oct 22, 2022 4:25 pm
Hey Brian, Maybe you could post the part # of the tank assembly shown on your shipping receipt for Grandnglorious. I’m sure he’ll be reassured by your experience.
https://www.silverwing600.com/t12665-questions-full-fuel-tank-drained-out-last-night#129632
BrianInVA
BrianInVA
PostSubject: Re: 2009 Silverwing 600 fuel leak   2009 Silverwing 600 fuel leak I_icon_minitimeSat Oct 22, 2022 4:46 pm
Good idea, thanks. I looked for it but didn’t realize the image was in that thread. The part is
Tank, Fuel, Honda, item number 17510-MCT-010
I ended up ordering it from eBay which was a couple dollars more than Ron Ayres because I wanted to use the PayPal pay in 4 option. I found the item link in my purchase history:
https://www.ebay.com/itm/284798353063
Ron Ayers - $34 cheaper:
https://www.ronayers.com/oemparts/partsearch/honda?partsearch=17510-mct-010
BrianInVA
BrianInVA
PostSubject: Re: 2009 Silverwing 600 fuel leak   2009 Silverwing 600 fuel leak I_icon_minitimeSat Oct 22, 2022 6:33 pm
By the way, if you want to try just replacing the seal under the fuel pump access before trying a new tank, I have a new unused one. I’d be happy to toss it in a padded envelope and mail it to you. I ordered one prior to realizing the new tank came with one pre installed.
Grandnglorious
PostSubject: Re: 2009 Silverwing 600 fuel leak   2009 Silverwing 600 fuel leak I_icon_minitimeSat Oct 22, 2022 7:36 pm
Thank you for your advice. I’m going to keep my old tank and replace the fuel pump assembly. There wasn’t even a gasket on the fuel pump. No wonder it leaked so badly. I ordered the fuel pump from Motosport for a hundred dollars cheaper. This is a great forum. Now pray I can get it all back together 😜
Grandnglorious
PostSubject: Re: 2009 Silverwing 600 fuel leak   2009 Silverwing 600 fuel leak I_icon_minitimeFri Oct 28, 2022 6:17 pm
I decided to get a new tank. The old one was rusty inside and I don't want to have to take it off again any time in the future. So I'll have a new tank and fuel pump assembly. Thanks for all the advice. I'm now waiting for delivery and then re-assembly.
Grandnglorious
PostSubject: Re: 2009 Silverwing 600 fuel leak   2009 Silverwing 600 fuel leak I_icon_minitimeFri Nov 11, 2022 5:33 am
This is John’s wife, Carol. My husband John Bailey is amazing!! Took a while, but he fixed it himself!!! Took the bike apart. Installed a new gas tank and fuel pump! Put it back together and it started right up!! AND the gas gauge now works!!!
PostSubject: Re: 2009 Silverwing 600 fuel leak   2009 Silverwing 600 fuel leak I_icon_minitimeFri Nov 11, 2022 12:46 pm
Hi Carol. I hope John is feeling very smug and has an irritating smile on his face. What a Face
Grandnglorious
PostSubject: Re: 2009 Silverwing 600 fuel leak   2009 Silverwing 600 fuel leak I_icon_minitimeFri Nov 11, 2022 1:23 pm
I think He was more relieved than smug!!!!🤣🤣🤣
» New Owner 2009 Silverwing
» 2009 Honda Silverwing
» 2009 Silverwing 600 issue when driving
» 2009 Silverwing start issues
» New 2009 Silverwing Owner
