| darkside tire, front wheel wobble at high speed (80+mph) | |
+3john grinsel GHM-PM Kunamika Hopper 7 posters |
Kunamika Hopper Scooter Rider
Number of posts : 47 Location : texas Points : 1592 Registration date : 2020-09-18
| Subject: darkside tire, front wheel wobble at high speed (80+mph) Fri May 19, 2023 7:00 am | |
| Hello all!
I've been riding with an achilles DS for a year or so, but recently had to go back to a Pirelli while I awaited a replacement.
With the Pirelli, I had no problems with going speeds up to 100, however, now that I'm back on the dark side, I get a bit of handlebar wobble on deceleration after I've crossed 80 mph.
I had previously had a similar problem, but it turned out my rear wheel nut had come loose. That is not the current cause, as I have retorqued the nut.
currently running at 35 psi on the rear and 25 on the front.
Does anyone have any ideas? I've searched the forum, but only found info on the swing's low speed wobble (which seems part in parcel for the bike).
Number of posts : 2625 Age : 72 Location : Bullhead City, AZ Points : 7516 Registration date : 2012-05-17
| Subject: Re: darkside tire, front wheel wobble at high speed (80+mph) Fri May 19, 2023 7:14 am | |
| For the weight of the bike I would think that 25 psi is too little for the front. I run 30 front and 36 rear but that is with motorcycle tires. Perhaps someone on here will chime in with info on DS tires. Good luck. |
| Subject: Re: darkside tire, front wheel wobble at high speed (80+mph) Fri May 19, 2023 7:49 am | |
| - GHM-PM wrote:
- For the weight of the bike I would think that 25 psi is too little for the front. I run 30 front and 36 rear but that is with motorcycle tires. Perhaps someone on here will chime in with info on DS tires. Good luck.
Thanks for the reply Glenn! I was thinking it might be too low, but didn't have a problem with it when riding both MC tires. I'll take it up to 30 and see if it fixes it, though, I'm curious why it would make a difference. |
Number of posts : 3316 Age : 85 Points : 9469 Registration date : 2009-08-18
| Subject: Re: darkside tire, front wheel wobble at high speed (80+mph) Fri May 19, 2023 8:10 am | |
| How do you go around corners? |
Erdoc48 Touring Scooter Rider
Number of posts : 382 Age : 60 Location : Myrtle Beach, SC Points : 1303 Registration date : 2022-05-31
| Subject: Re: darkside tire, front wheel wobble at high speed (80+mph) Fri May 19, 2023 8:54 am | |
| Totally unrelated topic…what saddlebags are you using on your SWing and do you have to use mounts under the bags or just an over the rear seat Velcro attachment? Those look good in your avatar pic. |
DickO Founding Member
Number of posts : 1020 Age : 79 Location : Atchison, KS Points : 6965 Registration date : 2008-12-23
| Subject: Re: darkside tire, front wheel wobble at high speed (80+mph) Fri May 19, 2023 12:58 pm | |
| Hi Kuna... I run standard specified psi on my front tire and 40 on my rear darkside... never had any problems... |
Number of posts : 1607 Age : 63 Location : South East England Points : 4758 Registration date : 2016-10-01
| Subject: Re: darkside tire, front wheel wobble at high speed (80+mph) Fri May 19, 2023 1:20 pm | |
| I can't confess to having any visits to the Dark Side. Although the recommended psi for the front is 29 I can't imagine 5 psi causing a wobble on throttling off.
Could it be a question of balance?...i.e. the extra load on the front wheel when decelerating from 80mph+
| Subject: Re: darkside tire, front wheel wobble at high speed (80+mph) Fri May 19, 2023 3:26 pm | |
| De-cel steering wobbles can/do happen on two wheelers at times. |
Number of posts : 4218 Location : York, North Yorkshire, England UK Points : 9447 Registration date : 2010-11-16
| Subject: Re: darkside tire, front wheel wobble at high speed (80+mph) Fri May 19, 2023 3:39 pm | |
I'm taking this 100 mph nonsense with a very large pinch of salt. |
| Subject: Re: darkside tire, front wheel wobble at high speed (80+mph) Fri May 19, 2023 5:23 pm | |
| - Erdoc48 wrote:
- Totally unrelated topic…what saddlebags are you using on your SWing and do you have to use mounts under the bags or just an over the rear seat Velcro attachment? Those look good in your avatar pic.
I'm not sure what model they are, but they're giving universal bags. No mounts, just the velcro straps. Thanks! I'm a big fan, so long as I don't have to leave them on the bike unattended. |
| Subject: Re: darkside tire, front wheel wobble at high speed (80+mph) Fri May 19, 2023 5:25 pm | |
| [/quote] I'm taking this 100 mph nonsense with a very large pinch of salt.[/quote]
I don't know how optimistic my speedo is, but a couple freeways here get up to 75 mph, and people drive 90-100 on them. my speedo says 100, and I keep up with everyone else, but idk |
| Subject: Re: darkside tire, front wheel wobble at high speed (80+mph) Fri May 19, 2023 5:27 pm | |
| - DickO wrote:
- Hi Kuna... I run standard specified psi on my front tire and 40 on my rear darkside... never had any problems...
I'm still not sure what the physics are, but I pushed it up to 30 before going to work, and the issue seems to be resolved. |
| Subject: Re: darkside tire, front wheel wobble at high speed (80+mph) Fri May 19, 2023 5:29 pm | |
Could it be a question of balance?...i.e. the extra load on the front wheel when decelerating from 80mph+ I didn't think 5psi would make a huge difference at that range, but it seems to have been the issue. |
| Subject: Re: darkside tire, front wheel wobble at high speed (80+mph) Fri May 19, 2023 5:31 pm | |
| - john grinsel wrote:
- How do you go around corners?
cornering is smooth |
| Subject: Re: darkside tire, front wheel wobble at high speed (80+mph) Fri May 19, 2023 6:26 pm | |
| did you know that car tire beads and motorcycle beads are different? |
| Subject: Re: darkside tire, front wheel wobble at high speed (80+mph) Fri May 19, 2023 7:03 pm | |
- did you know that car tire beads and motorcycle beads are different?
I did! I don't understand the physics of psi and balance though(obviously). |
| Subject: Re: darkside tire, front wheel wobble at high speed (80+mph) Sat May 20, 2023 11:27 am | |
| were you riding when bikes came with steering dampers? Wheel balance---my experience most shops do not/can not balance small scooter wheels. "Ride On" works well as balancing aide---not cheap but wors well in scooter wheels/tires. |
| Subject: Re: darkside tire, front wheel wobble at high speed (80+mph) Sat May 20, 2023 6:01 pm | |
- were you riding when bikes came with steering dampers? Wheel balance---my experience most shops do not/can not balance small scooter wheels. "Ride On" works well as balancing aide---not cheap but wors well in scooter wheels/tires.
I was not. I've only been riding for about 7 years now, and only 3 of those are on the swing. I'll check out "ride on". Thank for the suggestion John! |
