| Mirror Extension Ram Mount | |
Number of posts : 341 Location : Surprise, AZ. Points : 5790 Registration date : 2010-04-30
| Subject: Mirror Extension Ram Mount Wed Apr 13, 2011 5:53 pm | |
| For those of you with mirror extensions I found a ram mount to add a few more gadgets to the bars. http://www.gpscity.com/ram-mount-motorcycle-handlebar-clamp-ram-b-367u.html The mount replaces the 10m bolt that holds the extension to the original mirror mounting location. In addition to the mount you will need stainless steel 8m nylock nuts (1.25 thread pitch) and matching washers. The washer goes between the mount and the recess in the mirror extension. Use the longest bolt of three that are packaged with the Ram ball mount. I used a few wraps of 88 tape on the bare aluminum Ram base for aesthetics and a few wraps on the bolt threads to center and protect the threads in the mirror mount.
Number of posts : 2085 Age : 71 Location : St.Pete.FL. Points : 7559 Registration date : 2010-02-03
| Subject: Re: Mirror Extension Ram Mount Wed Apr 13, 2011 9:16 pm | |
| Thank you for the link. I like it and think I will get one. |
bob wells Maxi-Scooter Rider
Number of posts : 107 Age : 74 Location : Idaho Points : 5006 Registration date : 2011-07-06
| Subject: Re: Mirror Extension Ram Mount Sun Aug 21, 2011 6:46 pm | |
| Wher di you get you mirror mount extensions? This could be a cool set up.
Thanks Bob |
| Subject: Re: Mirror Extension Ram Mount Mon Aug 22, 2011 4:03 am | |
| I bought a set from gas-cap-dude on e-bay, try this URL shortcut ... http://tinyurl.com/mirror-ext |
| Subject: Re: Mirror Extension Ram Mount Mon Aug 22, 2011 10:33 am | |
| Subject: Re: Mirror Extension Ram Mount Mon Aug 22, 2011 1:40 pm | |
| Hear is a set for only $14.95+$4.95 shipping. http://cgi.ebay.com/ebaymotors/10mm-CNC-Motorcycle-Mirror-Riser-Extender-Adapter-Honda-/160553476214?_trksid=p4340.m185&_trkparms=algo%3DSIC.NPJS%26its%3DI%26itu%3DUA%26otn%3D8%26pmod%3D250729663916%26ps%3D63%26clkid%3D2245316686539961380 |
Number of posts : 2453 Location : Georgetown, Tx Points : 8373 Registration date : 2008-12-23
| Subject: Re: Mirror Extension Ram Mount Mon Aug 22, 2011 4:22 pm | |
| - model28a wrote:
- Hear is a set for only $14.95+$4.95 shipping.
http://cgi.ebay.com/ebaymotors/10mm-CNC-Motorcycle-Mirror-Riser-Extender-Adapter-Honda-/160553476214?_trksid=p4340.m185&_trkparms=algo%3DSIC.NPJS%26its%3DI%26itu%3DUA%26otn%3D8%26pmod%3D250729663916%26ps%3D63%26clkid%3D2245316686539961380 Does not have (or document) stainless steel 10MM screws ... so I would avoid. |
| Subject: Re: Mirror Extension Ram Mount Mon Aug 22, 2011 6:09 pm | |
| "Does not have (or document) stainless steel 10MM screws ... so I would avoid."
+1 Bill I forgot about that. I guess you could contact the seller and find out,but if they were stainless steel I would think they would list them. |
| Subject: Re: Mirror Extension Ram Mount Mon Aug 22, 2011 6:20 pm | |
| - model28a wrote:
- I forgot about that. I guess you could contact the seller and find out,but if they were stainless steel I would think they would list them.
I would not chance it. - trouble1100 wrote:
- I bought a set from gas-cap-dude on e-bay, try this URL shortcut ... http://tinyurl.com/mirror-ext
These have the stainless steel screws. |
Number of posts : 387 Age : 71 Location : Lattitude 47 Points : 5753 Registration date : 2010-03-31
| Subject: Re: Mirror Extension Ram Mount Mon Oct 24, 2011 12:16 am | |
Majac00 Scooter Rider
Number of posts : 18 Location : South Louisiana Points : 3758 Registration date : 2014-09-05
| Subject: Re: Mirror Extension Ram Mount Sun Sep 21, 2014 4:37 pm | |
| This setup worked really well for me. Thanks for posting this. I was concerned with putting an 8mm bolt in a 10mm hole, but that worked out fine. I did have to try 2 different places before I found stainless steel 8mm nuts. I used plumbers tape for spacing instead of electrical - I know from work that undoing electrical tape, if you have to, is a mess. |
