| Subject: vibration at take off Tue Jun 28, 2011 6:11 pm | |
| I have a vibration right at the start of acceleration from a stop and it sounds like it is in the dash/windshield. Anyone know what causes this? |
Number of posts : 2387 Location : Winnipeg Points : 7908 Registration date : 2010-05-02
| Subject: Re: vibration at take off Tue Jun 28, 2011 6:54 pm | |
| - claudia wrote:
- I have a vibration right at the start of acceleration from a stop and it sounds like it is in the dash/windshield. Anyone know what causes this?
Please do a search on this topic. it has been beaten to death on this and every other silverwing forum. |
DickO Founding Member
Number of posts : 1020 Age : 79 Location : Atchison, KS Points : 6965 Registration date : 2008-12-23
| Subject: Re: vibration at take off Tue Jun 28, 2011 7:35 pm | |
| Hi Claudi, I see that this is your first post on this site. Welcome! I'm not the expert here (there are some really good ones here too) but I believe the vibration you are experiencing is an anomaly of the drive system caused by the belt and variator. Not a major malfunction; just an irritant to some.
I'm sure there'll be some others with the technical explanation but until then, do as "bigbird" suggested and do a site search on clutch/variator/belt/and even 'vibration'. You'll find a host of info on this subject, no doubt. Once again, welcome to the site. |
Number of posts : 378 Location : Cornelius NC Points : 5793 Registration date : 2010-02-28
| Subject: Re: vibration at take off Sat Jul 02, 2011 11:47 am | |
| I just posted this on another topic in this forum:
I vote with bigbird - the J Costa really smoothed the machine out.
Realizing they are expensive and harder to find, I would suggest using lighter rollers or Dr. Pulley sliders. The stock rollers are too heavy and cause the motor/drive to lug for a bit and cause vibration and rumble. Lighter weights will allow the motor to spool up with less load on it, removing most of the vibration.
jdeereanton Silver Wing Guru
Number of posts : 1995 Age : 77 Location : Huntsville, AL Points : 7883 Registration date : 2008-12-24
| Subject: Re: vibration at take off Sat Jul 02, 2011 6:47 pm | |
