Installing Ultraseal. Tyre gloop I_icon_minitimeby john grinsel Today at 4:14 pm
» Rear wheel valve stem
Installing Ultraseal. Tyre gloop I_icon_minitimeby JohnyC Today at 11:53 am
Installing Ultraseal. Tyre gloop I_icon_minitimeby COMick Yesterday at 6:13 pm
Installing Ultraseal. Tyre gloop I_icon_minitimeby xwelder Yesterday at 12:31 pm
Installing Ultraseal. Tyre gloop I_icon_minitimeby sonuvabug Thu Nov 21, 2024 4:17 pm
Installing Ultraseal. Tyre gloop I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Installing Ultraseal. Tyre gloop I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Installing Ultraseal. Tyre gloop I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Installing Ultraseal. Tyre gloop I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Installing Ultraseal. Tyre gloop I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
madcatta
Cornishman
Cornishman
Cornishman
Number of posts : 181
Registration date : 2009-04-04
Installing Ultraseal. Tyre gloop Empty
PostSubject: Installing Ultraseal. Tyre gloop   Installing Ultraseal. Tyre gloop I_icon_minitimeSun Apr 26, 2009 6:52 am
I've fitted Ultraseal to my Silver Wing this morning. A method I've just implemented is to use a 60ml or larger, syringe. Instead of fitting the next to useless tubing to the bottle and squeezing until your hand aches, well mine does, fit the syringe to the tubing and fill the syringe with Ultraseal and inject. Remove the syringe from the tubing, refill, refit to tubing and repeat until desired amount is installed.
Bob
madcatta
Number of posts : 14
Registration date : 2010-04-16
PostSubject: Re: Installing Ultraseal. Tyre gloop   Installing Ultraseal. Tyre gloop I_icon_minitimeTue Jun 08, 2010 12:55 am
Bob
Hi Bob
I realise this is an old post but I was thinking of using this product on my Swing in Canberra, Australia and was wondering if you had some feedback on it's performance over the past year - did it work and did it have any detrimental effect on wheel balance and subsequently steering?
I've picked up a puncture in the front tyre it's a slow leak and i can't find the cause at this point but the Honda dealer has informed me that they will not plug a front tyre under any circumstances - so I'm up for a new tyre but thought i'd utilise the ultraseal product front and rear at the time of fitting the new tyre but i'd welcome some feedback?
I intend plugging the current front tyre if that proves possible and keeping it as a spare
Cheers
Scottie (aka Madcatta)
Number of posts : 3838
PostSubject: Re: Installing Ultraseal. Tyre gloop   Installing Ultraseal. Tyre gloop I_icon_minitimeTue Jun 08, 2010 3:57 am
I haven't yet got round to using Ultraseal on my Silverwing - the bottle I bought was out-of-date - but had it in my X9 tyres.
Absolutely no ill-effects if you do what it says on the bottle.
It's impossible to know if it's worked unless you get a largish hole or take off the tyre and see what's sticking in it.
True, it will not seal all holes as I know to my cost. I had a blow-out at speed when the tyre delaminated and went very 'Bang' but that's unusual and Michelin replaced the tyre FOC as it was part of a faulty batch apparently.
KurtPerthWA
KurtPerthWA
Number of posts : 1711
PostSubject: Re: Installing Ultraseal. Tyre gloop   Installing Ultraseal. Tyre gloop I_icon_minitimeTue Jun 08, 2010 5:10 am
Madcatter, be sure you read the label on the local stuff.
The Green stuff can and will attack the alloy in the rim over time. I've stuffed up the rim on my MZ with it and the only way I could keep air in there was by going to a tube. It got under the powder coating while seriously pitting the wheel as well.
I wish I had had a camera with me when the tyre was changed.
madcatta
PostSubject: Re: Installing Ultraseal. Tyre gloop   Installing Ultraseal. Tyre gloop I_icon_minitimeTue Jun 08, 2010 6:29 am
Cheers Kurt, I'll watch out for that - I sent ultraseal australia an email today requesting a bit more detail so unless I'm satisfied with the response I won't be using it
Scottie
Cornishman
Cornishman
PostSubject: Re: Installing Ultraseal. Tyre gloop   Installing Ultraseal. Tyre gloop I_icon_minitimeTue Jun 08, 2010 9:40 am
I've never had a problem with Ultraseal or OKO. As to it's effectiveness, it must work - I've never had a puncture
PostSubject: Re: Installing Ultraseal. Tyre gloop   Installing Ultraseal. Tyre gloop I_icon_minitimeTue Jun 08, 2010 11:30 am
I have a large John Deere tractor 455 tractor ... next larger size was a
farm tractor.
Do not use the green stuff (Slime), after having in the tire for 12-14 months I was continually getting flats. After I removed the tire the green Slime was now gelatin and useless to protect any holes. I believe the Slime deteriorated the both tires from the inside, cause you could see the tire rubber weakened in spots.
After cleaning the inside tire thoroughly, I added an inner tube and Ulraseal over two years ago and I have not had any problems with leaks. Since the tractor is low speed, I cannot answer your question about out-of-balance.
Number of posts : 2392
PostSubject: Re: Installing Ultraseal. Tyre gloop   Installing Ultraseal. Tyre gloop I_icon_minitimeTue Jun 08, 2010 3:51 pm
I use Ultraseal all the time.
It does work! When I replaced a previous rear wheel I was shown the 13 potential punctures by the tyre fitter. Neatly plugged by the minute slivers of vulcanised rubber. I was impressed and can only say that having UltrSeal in your tyres has to better than not having it and then relying upon some form of roadside repair.
As for the balancing qualities. The product is semi fluid and as such coats the inside of the tyre evenly thus preventing wobble or inbalance. After initially installing the product it will have pooled at the bottom of the tyre and they recomment a 10 minute ride to disperse the UltraSeal around the inner surface. Even then I have never noticed and inbalance.
Gets a big thumbs up from me. Installing Ultraseal. Tyre gloop Icon_cheers
madcatta
PostSubject: Ultraseal   Installing Ultraseal. Tyre gloop I_icon_minitimeFri Jun 11, 2010 8:06 am
Hi All,
Just some feedback on the supposed puncture I had in my front wheel as it turns out the tyre was leaking around the rim, the bead seal had broken so the tyre merely required refitting and the bead resealed around the rim - all fixed no need to replace the tyre. My local scooter shop said it sometimes happens - maybe I hit a big bump and broke the seal or it wasn't fitted properly to start with - not sure how it could be okay for 3500k and suddenly start leaking?
I was also considering utilising the puncture prevention product Ultraseal but it seems despite the the company having an Australian website and contact numbers the trail appears to lead nowhere - go figure?
Cheers
Scottie
PostSubject: Re: Installing Ultraseal. Tyre gloop   Installing Ultraseal. Tyre gloop I_icon_minitimeFri Jun 11, 2010 9:20 am
madcatta wrote:
Hi All,
Cheers
Scottie
There are a few similar products to UltraSeal. Gloop to name one. Can't think of the others at the moment.
» Have you had a flat tire?
» Installing GIVI question
» Variator and Belt Pictorial
» MPG before and after Dr. Sliders
» Installing DC socket
