Oil leak final drive ? I_icon_minitimeby john grinsel Today at 4:14 pm
» Rear wheel valve stem
Oil leak final drive ? I_icon_minitimeby JohnyC Today at 11:53 am
Oil leak final drive ? I_icon_minitimeby COMick Yesterday at 6:13 pm
Oil leak final drive ? I_icon_minitimeby xwelder Yesterday at 12:31 pm
Oil leak final drive ? I_icon_minitimeby sonuvabug Thu Nov 21, 2024 4:17 pm
Oil leak final drive ? I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Oil leak final drive ? I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Oil leak final drive ? I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Oil leak final drive ? I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Oil leak final drive ? I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
toolboxjesse
LN
LN
Number of posts : 64
Registration date : 2012-08-18
Oil leak final drive ? Empty
PostSubject: Oil leak final drive ?   Oil leak final drive ? I_icon_minitimeWed Oct 03, 2012 8:07 pm
2006 ABS
12000 miles
After fixing the stupid stator oil leak. I discovered that there's more. Anybody knows how to fix this ? As you see inside the belt case is all fine. The bikes makes a squiky noise for a couple of seconds until it takes off than it's all good. I drove about 300 miles and as soon as I stopped I smelled oil burning. Looked underneath...oil leak. Help please.
Thank you
Pictures here
https://www.box.com/s/wcqcdreuhlq03e6vhsm3
toolboxjesse
toolboxjesse
Number of posts : 330
PostSubject: Re: Oil leak final drive ?   Oil leak final drive ? I_icon_minitimeThu Oct 04, 2012 9:40 am
I can't access box at work, but i can tell you I had what I thought to be a final drive leak but it turned out to be a rear engine seal leak, which required me to remove the entire belt case & rear wheel assembly to replace the rear seal.
Jesse in Atlanta
PostSubject: Re: Oil leak final drive ?   Oil leak final drive ? I_icon_minitimeThu Oct 04, 2012 10:23 am
+ 1 on what Jesse said.
Replacing the crankshaft seal is a doable job, but it is a bit time consuming.
Go back and read Jesse's archived posts on how to do it. He has a couple of significant tips regarding the job.
The seals are actually inexpensive enough so you might want to order both the crank seal as well as the final drive seal (behind the Clutch Bell) just to have them on hand. I ended up replacing both of the seals.
RArch
RArch
Number of posts : 613
PostSubject: Re: Oil leak final drive ?   Oil leak final drive ? I_icon_minitimeThu Oct 04, 2012 1:43 pm
Sorry to hear Sad
If it is the shaft seal, what caused it?
Could it be a bearing breaking down?
http://www.rcmodeltalk.co.uk
micbusathens
micbusathens
Number of posts : 199
PostSubject: Re: Oil leak final drive ?   Oil leak final drive ? I_icon_minitimeThu Oct 04, 2012 2:38 pm
Did you change final shaft oil lately? Hope you didn't overfill it.
tankyuong
tankyuong
Number of posts : 475
PostSubject: Re: Oil leak final drive ?   Oil leak final drive ? I_icon_minitimeThu Oct 04, 2012 2:43 pm
I'd try OilStop leak in your final drive to recondition your seals before replacing the seals.
» Oil Leak on Final Drive?
» Final drive leak?
» Not happy; final drive oil leak
» Final drive front pulley oil leak
» FINAL DRIVE OVERFLOW
