» Rear wheel valve stem
How do you remove the rear cowl? I_icon_minitimeby MikeO Yesterday at 6:19 pm
How do you remove the rear cowl? I_icon_minitimeby COMick Yesterday at 6:13 pm
How do you remove the rear cowl? I_icon_minitimeby xwelder Yesterday at 12:31 pm
How do you remove the rear cowl? I_icon_minitimeby sonuvabug Thu Nov 21, 2024 4:17 pm
How do you remove the rear cowl? I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
How do you remove the rear cowl? I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
How do you remove the rear cowl? I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
How do you remove the rear cowl? I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
How do you remove the rear cowl? I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
How do you remove the rear cowl? I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
4 posters
carlosw
carlosw
Number of posts : 91
Registration date : 2011-09-09
How do you remove the rear cowl? Empty
PostSubject: How do you remove the rear cowl?   How do you remove the rear cowl? I_icon_minitimeTue Feb 05, 2013 3:56 pm
I cracked the back cowl of my Silverwing, the one that sits right on top of the light, that has the HONDA writing on it. I found one on ebay and it will be arriving soon. I want to get prepared and was trying to know if there is any instructions or even better any photos or diagrams showing the sequence and the different screws to remove etc. to replace it?
I did a bit of search but could not find anything about this. Any help would be greatly appreciated.
Number of posts : 2392
PostSubject: Re: How do you remove the rear cowl?   How do you remove the rear cowl? I_icon_minitimeTue Feb 05, 2013 4:16 pm
Remove the rear spoiler
Remove the side body panels
Remove two bolts and two screws
Disconnect the rear light connections
Finally remove the cover.
Straight from the manual!!!!
carlosw
carlosw
PostSubject: Re: How do you remove the rear cowl?   How do you remove the rear cowl? I_icon_minitimeTue Feb 05, 2013 4:23 pm
Thank you, at least this gives me a sequence of actions... I have not done any of these yet so I was wondering where all the different screws were and if there was any particular instruction to avoid breaking any of the plastic holders... sometimes they are stuck or help in place and without the data one can break some of the little parts... I know I have done that in the past with other bikes...
So this is great, but if there is any other instructions or photos it would be fantastic.
PostSubject: Re: How do you remove the rear cowl?   How do you remove the rear cowl? I_icon_minitimeTue Feb 05, 2013 4:30 pm
Can't reproduce the manual for fear of copyright. But I will post a link to Lings a Honda dealer and they show a diagram of the assembly.
PostSubject: Re: How do you remove the rear cowl?   How do you remove the rear cowl? I_icon_minitimeTue Feb 05, 2013 4:31 pm
Link for Lings! Break down of panels and there association with each other.
http://www.lingshondaparts.com/honda_motorcycle_parts_selection_pfk.php?block_01=13MCT601&block_02=F__1200&block_03=2871
tinman
Number of posts : 1298
PostSubject: Re: How do you remove the rear cowl?   How do you remove the rear cowl? I_icon_minitimeTue Feb 05, 2013 4:48 pm
For the side panels there are rubber plugs, back bottom that you need to pop out,with the screws of there are plastic ketchs on the top that you need to pop up to remove the side panel and push in to re instal .they are little hook type and are every were on the body works front fairing ,back plate below brake light . your owners manual should explain everything.
carlosw
carlosw
PostSubject: Re: How do you remove the rear cowl?   How do you remove the rear cowl? I_icon_minitimeTue Feb 05, 2013 5:25 pm
Awesome, thanks for the links. That diagram helps a lot.
I looked over the owners manual and there are instructions on how to remove the sides but not the actual rear cowl. But with this data I think I can do it.
Awesome forum and awesome people!
JeffR_
JeffR_
Number of posts : 1103
PostSubject: Re: How do you remove the rear cowl?   How do you remove the rear cowl? I_icon_minitimeTue Feb 05, 2013 10:44 pm
carlosw,
This pictorial may help you some:
https://www.silverwing600.com/t56-air-filter-pictorial
» Silverwing Rear Right Cowl Fairing Panel Cover
» How to: Remove Honda Silver Wing REAR WHEEL. Youtube
» How to: Remove Honda Silver Wing REAR BRAKE CALIPER.(Youtube)
» Remove fairings
» SilverWing Right Cowl Tab Fix
