| Subject: Rigid Gas Tank Needs Replacement Thu Jun 18, 2009 7:21 am | |
| Hi all. :arrow: I recently had to have my gas tank replaced. It is supposed to be flexible, and instead was rigid. I understand from the dealership that this is quite serious, and could result in a gas explosion if you go down. What I noticed was gas leakage when the bike went down once (I dropped it ). Anyway, this was a recall and there was no charge for the replacement. I wanted to let everyone know, just in case. |
masscoot Silver Wing Rider
Number of posts : 438 Location : Central New England Points : 6183 Registration date : 2009-03-24
| Subject: Re: Rigid Gas Tank Needs Replacement Thu Jun 18, 2009 9:26 am | |
| I found this listing for 2003 Silver Wings: Recall ID #37078 Recall ID #37078 - FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY Recall ID #37078 - FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY Recall Date | APR 12, 2004 | Component | FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY | Motorcycle Affected | SILVER WING | Potential Motorcycles Affected | 2497 Recall Details |
Recall Date APR 12, 2004 Motorcycle Affected 2003 HONDA SILVER WING Summary ON CERTAIN SCOOTERS, SOME FUEL TANKS WERE IMPROPERLY MANUFACTURED AND DO NOT MEET MATERIAL STRENGTH SPECIFICATIONS. Consequence ENGINE VIBRATION OR RIDING ON BUMPY ROADS COULD CAUSE THESE TANKS TO CRACK AND LEAK. FUEL LEAKAGE, IN THE PRESENCE OF AN IGNITION SOURCE, CAN RESULT IN A FIRE. Remedy DEALERS WILL PERFORM AN INSPECTION PROCEDURE THAT IDENTIFIES DEFECTIVE FUEL TANKS. IF THE FUEL TANK FAILS THE INSPECTION, THE DEALER WILL REPLACE IT WITH AN UPDATED FUEL TANK. OWNER NOTIFICATION BEGAN DURING APRIL 16, 2004. OWNERS SHOULD CONTACT HONDA AT 1-866-784-1870. Potential Motorcycles Affected 2497 Notes HONDA (AMERICAN HONDA MOTOR CO.) P26 |
