| Connector for stop light in top case | |
fgaiazzi Scooter Rider
Number of posts : 34 Age : 63 Location : Buenos Aires - Argentina Points : 4217 Registration date : 2013-07-01
| Subject: Connector for stop light in top case Mon Apr 25, 2016 11:09 am | |
| Hello friends, I have bought a top case and I have installed it on my Silver Wing. I have put some leds on it, and then I have connected them with the brakes. They iluminate very well. I have put a RCA female connector on the base, and a RCA male connector in the top case. I can remove the top case and carry it with me. Later, when I put the top case in its position, both RCA connectors are connected, and the leds bright when I use the brakes. The problem is when I am riding, the movement of the motorcycle goes to the top case, and the electrical connection between both parts of RCA fails. Sometimes the leds bright, sometimes they don´t shine. When they don´t bright, I apply a little of force on the superior part of the case, and they bright. I am thinking in replacing RCA connection system with another kind of connectors, but I do not which one. I do not want to connect by hand every time I put the top case, and later disconnect mannualy when I remove the top case. I am looking for a connection system that connect both parts automatically. Any suggestions? Thanks in advance! - Attachments
- (219 Kb) Downloaded 43 times
- (263 Kb) Downloaded 31 times
Number of posts : 3838 Age : 75 Location : Seaham, Co Durham, UK Points : 9708 Registration date : 2009-06-29
| Subject: Re: Connector for stop light in top case Tue Apr 26, 2016 12:45 pm | |
| I have friends who have experienced the same problem with Givi's own connectors for top box lights.
I can see the desire not to have to manually connect and disconnect wires but I feel sure it's the only way to ensure a reliable connection.
If I were to do it I'd use these:
http://www.marine-products.com/seadog-polarized-connector-2-wire-plug-socket-426880-1.html
| Subject: Re: Connector for stop light in top case Tue Apr 26, 2016 1:46 pm | |
Number of posts : 1013 Age : 74 Location : HI Points : 4352 Registration date : 2015-12-18
| Subject: Re: Connector for stop light in top case Tue Apr 26, 2016 3:13 pm | |
hankster Maxi-Scooter Rider
Number of posts : 140 Age : 72 Location : Fort Myers FL Points : 3468 Registration date : 2015-11-14
| Subject: Re: Connector for stop light in top case Tue Apr 26, 2016 3:40 pm | |
| I purchased these and they work great. Nice thing is they have 6 wires so you can also wire up running lights, brake lights and turn signals with this single plug. The wire is small so I'd make sure to always use LEDs with it. 2 pair of plugs for $8.30 is hard to beat. http://www.ebay.com/itm/2Pairs-6Pin-Waterproof-Black-Cable-Wire-Connectors-IP68-Aviation-Contact-/181603943781 |
mike712 Scooter Rider
Number of posts : 95 Age : 85 Location : McKinney, Texas Points : 4294 Registration date : 2013-06-28
| Subject: Re: Connector for stop light in top case Tue Apr 26, 2016 4:18 pm | |
| Easyrider, Where did you get your lights? |
| Subject: Re: Connector for stop light in top case Tue Apr 26, 2016 4:33 pm | |
| Admore Lighting: http://www.admorelighting.com/
Givi's own kit: http://www.twistedthrottle.com/givi-e97-halogen-brakelight-stoplight-kit-for-e52-maxia-topcase |
| Subject: Re: Connector for stop light in top case Wed Apr 27, 2016 3:42 am | |
| - mike712 wrote:
- Easyrider, Where did you get your lights?
I purchased my lights directly from Admorelighting.com for $143.00. I think that the new price is $129. |
