» LF extended back rest
Honda refkex 250 I_icon_minitimeby Rzor93 Today at 4:29 pm
» Goodbye guys
Honda refkex 250 I_icon_minitimeby Rzor93 Today at 4:27 pm
» noise under load
Honda refkex 250 I_icon_minitimeby dmosemorris Yesterday at 1:30 pm
» checking the oil
Honda refkex 250 I_icon_minitimeby arcamedies13 Yesterday at 9:32 am
Honda refkex 250 I_icon_minitimeby Terry Smith Thu May 16, 2024 6:39 pm
» Hello from Illinois!
Honda refkex 250 I_icon_minitimeby DescendingRaven Wed May 15, 2024 2:13 pm
» Silverwing Brakes
Honda refkex 250 I_icon_minitimeby Terry Smith Tue May 14, 2024 11:57 pm
Honda refkex 250 I_icon_minitimeby BrianInVA Mon May 13, 2024 12:53 pm
» Left brake micro-switch
Honda refkex 250 I_icon_minitimeby Johnboy Fri May 10, 2024 7:57 pm
Honda refkex 250 I_icon_minitimeby BrianInVA Fri May 10, 2024 5:36 pm
 Honda refkex 250
4 posters
Pindar
Number of posts : 27
Registration date : 2022-04-08
Honda refkex 250 Empty
PostSubject: Honda refkex 250   Honda refkex 250 I_icon_minitimeMon Apr 11, 2022 10:49 am
Hello
My refkex is lacks enthusiasm latetky. Starts, runs, doesnt burn oil and the fuel consumption is normal but it lost its pep. Changed oul, filter , air filter , belt is new .... Any pointers are greatly appreciated.... Enjoy every moment !
Number of posts : 929
PostSubject: Re: Honda refkex 250   Honda refkex 250 I_icon_minitimeMon Apr 11, 2022 12:18 pm
Is this decreased power a new phenomenon?  Did it start after you did some of the aforementioned maintenance?
Three things jumped to mind:
1) the spark plug is fouled
2) your rollers are wearing
3) perhaps a hot flush of your carb and fuel system would do the trick? (i.e. Seafoam)
The Dude
The Dude
Number of posts : 196
Registration date : 2022-02-20
PostSubject: Re: Honda refkex 250   Honda refkex 250 I_icon_minitimeMon Apr 11, 2022 4:16 pm
How many miles? Mine is low mileage <10k. (02). I had an issue where cold start was difficilult (died on rev) until warm.
Eventually, no start.
Cleaned the carb. Replaced fuel filter and pump. Some improvement, but still wouldn't run smoothly or at low rpm.
Finally took it in. Obviously fuel delivery issue because it ran fine if you dumped starter fluid or gas in the carb.
Turns out the aftermarket pump I bought was not delivering consistently. 😠 Tested the old Honda pump and it was dead as expected.
Had to bite the bullet and order OEM pump at $160 USD. 😡
Put the new pump on myself in the parking lot of the Honda shop and it fired up and ran great.
$260 for their labor. So close to $500 USD to sort it (tax!).
Anyway, easy test is to shoot a little starting fluid in the intake. If it perks up, you know it's likely a delivery issue. Then work your way from the filter to the pump. Just don't cheap out on the parts.
Sonuvabug also has good advice. Seafoam is a great product. 👍
Pindar
PostSubject: Re: Honda refkex 250   Honda refkex 250 I_icon_minitimeMon Apr 11, 2022 4:21 pm
Thanks for responses. The bike has 25000 miles on it. I started it frequently during the winter months.,it has always been a lemon but this year it idles rougher and has less power .... Heading out to get a new spark plug now. Cheers and thanks
Pindar
PostSubject: Re: Honda refkex 250   Honda refkex 250 I_icon_minitimeMon Apr 11, 2022 5:01 pm
I don't really know what or where rollers are?
PostSubject: Re: Honda refkex 250   Honda refkex 250 I_icon_minitimeMon Apr 11, 2022 5:36 pm
Either search this website for "rollers" or Google "CVT rollers".
Rollers (or you can also use sliders) are what regulate your acceleration, speed and top end vis a vis your throttle input/rpm's.  They are located in the CVT variator housing ... right behind where you changed your drive belt.
You can look them up in your FSM (Factory Service Manual).  If you don't have one, get one as it will be your single best investment if you will be servicing your own scoot.
Don't know if these symptoms have presented themselves after the scoot's winter hibernation or not.  Our Big Ruckus (pretty close to the same engine/CVT configuration) was always rough running early in the season. Always needed a good carb cleaning and some miles until it found it's groove.
Our Reflex, by comparison, was better but both scoots were cold natured and a little finicky.  I sure do appreciate the EFI now on our SWing and Burgy 400.
JazzDad
Number of posts : 5
Registration date : 2023-04-29
PostSubject: Re: Honda refkex 250   Honda refkex 250 I_icon_minitimeSat Apr 29, 2023 10:43 pm
THREAD BROUGHT BACK TO LIFE.
Mine was hard to start when cold. Took the fuel enricher out, cleaned it, and solved the problem.
Honda refkex 250
» Torque Monster Shootout…. Yamaha FZ1, Honda CBF 1000, Honda CB1300S.
» Honda SilverWing Parts Lists (Real Honda Part Numbers)
» 2 - New 2009 Honda ST1300's at the Honda shop
» Honda Accessories from Honda Japan
» 2008 Honda fes 125 Honda s-wing
Honda Silver Wing Scooter Forum :: Other Scooters and Motorcycles-
