| actual fuel range | |
+7GHM-PM Chilliwing MikeO The Scootist Cookie Meldrew steve_h80 11 posters |
steve_h80 Silver Wing Expert
| Subject: actual fuel range Mon Jun 06, 2016 4:53 pm | |
| So I filled up today at 130 miles and put 11.2 litres in there. This gives me a theoretical range of about 185 miles, which is kinda nice. But how much usable fuel does the 16 litre tank hold? Often there is some space reserved for expansion. Plan 2 it to put a gal of gas in a fuel container and ride it till it stops :-) |
| Subject: Re: actual fuel range Mon Jun 06, 2016 5:35 pm | |
| I've gone 170 miles or more quite a few times without all the bars extinguished and reserve flashing, I used to think I'd like to try for 200 miles and carry a reserve can under the seat in case, then like a lot of other "projects" I lost interest. It's enough to know I can normally go at least 150 miles or more at motorway speeds before I start looking for the next fuel stop. Usually it's a full bladder not an empty tank that prompts me to stop earlier.
That theory works for me,but a few years ago I brimmed the tank at Penrith, flogged the scooter over the A66 Pennines to Scotch Corner, and down the A1(M) to York, picked up Mrs M, and then rode down to Squires Cafe in time to take part in a charity ride, we then got back on the A1(M) with a couple of hundred other riders up to Catterick Garrison. A place I'd rode past only a couple of hours previously on the way down. By the time we got there the reserve was flashing and luckily I filled up within a couple of miles, I'd used that tankful up in about 130 miles. |
Cookie Super Scooter Rider
Number of posts : 233 Location : Essex UK Points : 4859 Registration date : 2011-10-03
| Subject: Re: actual fuel range Mon Jun 06, 2016 5:39 pm | |
| The most I've managed is 210 miles with a couple of litres remaining but that was taking it quite easy and was on a longish run. I've done a few fill ups at about 200 miles and there's been two or three litres left.
I don't check it every fill up but I do from time to time and allowing for what's left the range would be about 220 or so.
I usually fill up on the way out unless I've got enough to do the planned ride but otherwise I start to look for garages at around 180 or so miles.
I found a Honda diagram that showed the amount of fuel for each segment on the gauge. The interesting thing was that the amount of fuel used when the first bar goes out is about the same as the amount left when down to the one flashing bar. So you should be good for 45 miles or so when down to the last flashing bar. I've never tried it that far but I've done 30 miles with the bar flashing a couple of times.
Number of posts : 693 Age : 66 Location : Loveland, Colorado Points : 6266 Registration date : 2009-01-23
| Subject: Re: actual fuel range Tue Jun 07, 2016 9:46 am | |
| The owners manual says the tank holds 4.2 US gallons and the reserve indicator light comes on when you have about 0.92 gallons remaining. If you average at least 50 mpg, then you should be able to squeeze 200 miles out of a tank. Also note as Cookie mentioned in their post, the amount of fuel consumed per bar seems to vary a little. During the first bar I usually get around 50 miles, then for the next few bars I get around 15 miles, the second to the last bar around 25 miles, then the last bar (flashing) should be good for about 45 miles or so. Several times I have exceeded 200 miles on one tank of gas, but usually start to look for a gas station when the last bar starts to flash, as I would hate to end up walking... |
| Subject: Re: actual fuel range Tue Jun 07, 2016 12:59 pm | |
| I found the diagram that I mentioned. The text is not in English but it's the diagram bit that is relevant. So the last bar should be the same as the first. In real terms it could be a bit less since (if you're anything like me) you brim the tank right up into the neck when filling up. |
| Subject: Re: actual fuel range Tue Jun 07, 2016 3:41 pm | |
| Based on my weekend's riding and log-keeping, I get roughly 60 miles from the first block on the petrol gauge. |
Chilliwing Maxi-Scooter Rider
Number of posts : 146 Age : 68 Location : Chilliwack, British Columbia, Canada Points : 4813 Registration date : 2011-09-03
| Subject: Re: actual fuel range Wed Jun 08, 2016 12:09 am | |
| On trip I count on 50 miles or 80 kms on the last bar and carry a 1 litre gas bottle for insurance. Last year on the Oregon Coast I was pushing my luck and rode into a gas station on fumes! Ever since that I have carried the gas bottle. |
| Subject: Re: actual fuel range Thu Jun 09, 2016 8:04 am | |
| I traveled 212.3 miles on a tank several years ago! Last bar was flashing and was on HWY 395 outside Yosemite, in California. Not many gas stations around there... On that particular tank I averaged 58.2 MPG US. So actually had some left, amazing for sure. I do not normally push it that far |
Number of posts : 2940 Age : 75 Location : Winnsboro, Texas, U.S.A. Points : 8371 Registration date : 2010-02-17
Number of posts : 1936 Location : Hocking Hills U.S.A. Points : 5175 Registration date : 2016-01-29
| Subject: Re: actual fuel range Thu Jun 09, 2016 5:10 pm | |
| After the winter drive line tune up I just completed my first good ride, mostly country at 50 to 70 mph. 167 miles 3.09 gal to fill up. 54 mpg. On day trips like this I normally fill up at home from my can supply, this time at a station for a change. This is better than my 1st guesstimate |
Number of posts : 379 Location : Yuma, AZ Points : 3335 Registration date : 2016-06-01
| Subject: Re: actual fuel range Thu Jun 09, 2016 11:11 pm | |
| - oldwingguy wrote:
- After the winter drive line tune up I just completed my first good ride, mostly country at 50 to 70 mph. 167 miles 3.09 gal to fill up. 54 mpg. On day trips like this I normally fill up at home from my can supply, this time at a station for a change. This is better than my 1st guesstimate
Ours were very close. I rode 165 miles and used 3.00 gallons exactly. 55 mpg. |
hardee41 Scooter Rider
Number of posts : 80 Age : 82 Location : Iowa Points : 4059 Registration date : 2013-07-23
| Subject: Re: actual fuel range | |
