| Temperature Gauge that's Easy to Read and Looks Good | |
+5tankyuong theop dspevack masscoot DennisB 9 posters |
| Subject: Temperature Gauge that's Easy to Read and Looks Good Fri Nov 06, 2009 11:34 am | |
| Hi All, Old Dave in Western Nebraska (DaveR) sent me an email and told me of a great little Temperature gauge he found & mounted on his Swing. Dave's real particular about what accesseories he monuts on his scooter (see his scooters pictures in the album). Real Clean. He sent me a couple of pictures and the gauge & setup looked good. Out of the True kindness of his hart (And Thank You, Again). He sent me one. The cost for the Temperature unit was very low, Under $5.00 USD in cost and I have found it to be very accurite. It's made under the name "ACU-RITE" model # 00799. Easy to read with numbers 3/4" tall and has an ON/OFF switch on the bottom. This saves in the battery, which by the way is replaceable, # L1154 Cell. This unit has a WEATHER RESISTANT EXTERIOR. Well this is what I did with it, I removed the suction cup, Taped all but the back side of the lens and gave it a very light dusting with some fast drying white paint, I can see it allot better now. Cut a small piece of 1" aluminum (90 deg. angle 3/4" wide) and bent it to 115 degs. drilled a 10mm hole then sandblasted it and painted the mount black. I used a small amount of Ultra Black Sealer to hold it on to the new bracket and let it cure over night. Mounted it this morning. Had to find a little longer mirror bolt, done deal. What do you think? |
masscoot Silver Wing Rider
Number of posts : 438 Location : Central New England Points : 6182 Registration date : 2009-03-24
| Subject: Re: Temperature Gauge that's Easy to Read and Looks Good Fri Nov 06, 2009 11:42 am | |
| Nice job Dennis! That is a great mounting location. ......Ahh 65 degrees we will not see that again till spring |
| Subject: Re: Temperature Gauge that's Easy to Read and Looks Good Fri Nov 06, 2009 12:49 pm | |
| Windy and a little above 80 F. today 65 deg. was this morning. |
| Subject: Re: Temperature Gauge that's Easy to Read and Looks Good Fri Nov 06, 2009 1:57 pm | |
| - DennisB wrote:
- Windy and a little above 80 F. today 65 deg. was this morning.
Your sentence...my numbers Windy and a little above 51 F. today 32 deg. was this morning. |
dspevack Silver Wing Guru
| Subject: Re: Temperature Gauge that's Easy to Read and Looks Good Fri Nov 06, 2009 9:37 pm | |
| I used this one for years before I went to one with more functions. Time, stopwatch, voltage, and two thermometers, as well as an Ice warning. These things are available on ebay and in many bike stores. ($25-$40) The only concern I have with your (and Old Dave's) thermometer is it seems like unnecessarily bulky and obvious whereas you can mount this just above or below your dash gauges and idiot lights and you get more functions with a more subtle, built-in feel. Dan |
| Subject: Re: Temperature Gauge that's Easy to Read and Looks Good Fri Nov 06, 2009 10:35 pm | |
| Well Dan, Sounds like you got winner on your hands. I just don't need all the other readouts, just the temperature, that's all. I was just thinking.....do I really need something to tell me if it's icy. I don't think so. And I can see this one. Works for me. |
| Subject: Re: Temperature Gauge that's Easy to Read and Looks Good Sat Nov 07, 2009 7:59 am | |
theop Scooter Rider
Number of posts : 17 Age : 48 Location : London, UK Points : 5498 Registration date : 2009-11-30
| Subject: Re: Temperature Gauge that's Easy to Read and Looks Good Thu Dec 10, 2009 11:58 am | |
| I am also looking for a temp sensor. I need it mainly to check it first thing in the morning to see if there ll be any black ice etc... Seeing quite a few of the super thermometers and their assorted mounting bits and bobs that are on market, I decided I needed something simpler... Haven't found any simple digital waterproof stick-on ones., but I saw this from a US retailer : http://www.aerostich.com/navigate-communicate/scooter-clocks-compasses-thermometers/thermometers-and-gauges/liquid-crystal-temperature-strips.html I think its cool... |
tankyuong Silver Wing Rider
Number of posts : 475 Age : 49 Location : Missouri Points : 6298 Registration date : 2009-07-12
| Subject: Re: Temperature Gauge that's Easy to Read and Looks Good Thu Dec 10, 2009 1:36 pm | |
| Subject: Re: Temperature Gauge that's Easy to Read and Looks Good Thu Dec 10, 2009 3:33 pm | |
| - dspevack wrote:
- I used this one for years before I went to one with more functions. Time, stopwatch, voltage, and two thermometers, as well as an Ice warning. These things are available on ebay and in many bike stores. ($25-$40) The only concern I have with your (and Old Dave's) thermometer is it seems like unnecessarily bulky and obvious whereas you can mount this just above or below your dash gauges and idiot lights and you get more functions with a more subtle, built-in feel.
Dan
Too much information. Data overload. I'll stick to a speedo thank you. If its cold I'll get goose bumps - and dress accordingly. Other than that, regular rides should keep the battery in order!!! (Hopefully) Ice gauge!!!! I live in a fairly temperate climate so no real need. (However if the Ice Age cometh - cross that path at the time!!!!!!) |
KurtPerthWA Silver Wing Guru
Number of posts : 1711 Age : 75 Location : Belmont, Perth WA Points : 8158 Registration date : 2009-01-19
| Subject: Re: Temperature Gauge that's Easy to Read and Looks Good Thu Dec 10, 2009 7:16 pm | |
| There is a suitable suitable highly accurate weather guage, which is available from small compact portable version to the one shown in the picture.. |
| Subject: Re: Temperature Gauge that's Easy to Read and Looks Good Thu Dec 10, 2009 7:42 pm | |
| Hi Kurt, So where did you hang your weather telling rock on your SWing? |
| Subject: Re: Temperature Gauge that's Easy to Read and Looks Good Thu Dec 10, 2009 8:42 pm | |
| Actually, the kids bought me one for Chrismas many moons ago and hung it in the dunny (WC), but the pocket versions can be placed anywhere. I reckon a good plce to hang it on the Swing would be under the seat rear edge and only used stationary with the seat up as there it would not distract the rider and save him/her from suffereing from checkgaugeittis, which can be severely detrimental to the mental and physical health of the rider. C'mon, how many times did you check the temp guage in the first week you installed it? Truthfully now! |
| Subject: Re: Temperature Gauge that's Easy to Read and Looks Good Fri Dec 11, 2009 3:46 pm | |
| - KurtPerthWA wrote:
- There is a suitable suitable highly accurate weather guage, which is available from small compact portable version to the one shown in the picture..
When I did a course that involved meteorology part of the first package of my course was a weather forecasting kit. 1 nail!!!! With the instructions, obtain seaweed from nearest coastline. With enclosed nail, attach seaweed to side of building. Here comes the technical meteorological bit. If the seaweed is dry - it's ain't rainin'. If the seaweed is wet - it is raining. Simple really!!!!!! Who mentioned advection fog!!!!!!!! |
joncallihan Silver Wing Guru
Number of posts : 1025 Age : 86 Location : Lafayette, Colorado, USA Points : 6932 Registration date : 2009-02-16
| Subject: Re: Temperature Gauge that's Easy to Read and Looks Good Fri Dec 11, 2009 4:10 pm | |
| Similar things happen all round the world. Have a look for "wyoming wind sock" on Google. |
| Subject: Re: Temperature Gauge that's Easy to Read and Looks Good Fri Dec 11, 2009 11:56 pm | |
| A Garmin for $10 at Petco? Cool! |
| Subject: Re: Temperature Gauge that's Easy to Read and Looks Good Sat Dec 12, 2009 8:38 am | |
| Hi Guys, I found this on Ebay. Take a look, $1.00 + $2.49 shipping from China: http://shop.ebay.com/i.html?_trkparms=65%253A1%257C66%253A2%257C39%253A1&_nkw=Digital%20Terrarium%20Thermometer&_trksid=p3286.c0.m14&_pgn=1 |
| Subject: Re: Temperature Gauge that's Easy to Read and Looks Good Sat Dec 12, 2009 10:04 am | |
| Nice one Dennis, but fitting out a Swing for running submerged could be rather expensive, hey! |
| Subject: Re: Temperature Gauge that's Easy to Read and Looks Good Sat Dec 12, 2009 11:44 am | |
- Nice one Dennis, but fitting out a Swing for running submerged could be rather expensive, hey!
Saran wrap works good lol |
| Subject: Re: Temperature Gauge that's Easy to Read and Looks Good Sat Dec 12, 2009 11:52 am | |
| O' Kurt...your just a big kidder The LCD unit goes on the outside of the fish tank and the temperature probe goes inside the fish tank or in this application goes down the handlebar, under the cover. Not a bad idea...Lets just say it's a small step up from having a pet rock on a string hanging on the scooter.
Opalsboy Silver Wing Guru
| Subject: Re: Temperature Gauge that's Easy to Read and Looks Good Sat Dec 12, 2009 12:04 pm | |
| Dennis....I could have had this aquarium temp gauge in my shirt pocket on our trip from West OK to tulsa on our trip. Still drying out the little lady that rode behind me. |
