Brakes and some other questions... I_icon_minitimeby sonuvabug Today at 4:19 pm
Brakes and some other questions... I_icon_minitimeby sonuvabug Today at 4:17 pm
Brakes and some other questions... I_icon_minitimeby sonuvabug Today at 4:06 pm
Brakes and some other questions... I_icon_minitimeby JohnyC Yesterday at 10:04 am
Brakes and some other questions... I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Brakes and some other questions... I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Brakes and some other questions... I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Brakes and some other questions... I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Brakes and some other questions... I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Brakes and some other questions... I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
4 posters
LeRoi50
Number of posts : 13
Registration date : 2017-08-13
Brakes and some other questions... Empty
PostSubject: Brakes and some other questions...   Brakes and some other questions... I_icon_minitimeSun Aug 27, 2017 11:55 am
The brakes on my 2003 ABS Silverwing work, but that's about it.
The front brake feels a bit soggy and the linked rear/front brakes works best....but could be better I think.
I'm used to sharp really well dosed brakes on my FJR, am I spoiled or do I need to get used to a new kind of brake feel?
I will replace the fluids soon for DOT 5.1, is there anything to keep in mind my bike being a ABS version....?
I did clean the front calliper today and lubed the slide pins. Caliper and pads look really good.
Also, I have a slight oil leak. I took the skid plate off and cleaned everything to get a good idea where it's coming from. I read about some possible causes on the forum.
Btw, can I ride without the skid plate? I don't thing the skid plate bolts hold anything together.....they just hold the plate. Or am I mistaken?
Thanks for any tips
PostSubject: Re: Brakes and some other questions...   Brakes and some other questions... I_icon_minitimeSun Aug 27, 2017 12:26 pm
Sure you can ride without the skid plate. However you run the risk of puncturing the crankcase.
It sounds as if you need to bleed the brakes --sooner rather than later. The front brake should feel "normal" not spongy. The rear (linked) brake does feel softer than the front, but that seems to be because the rear brake also must travel further to activate the starter interlock switch.
I hope all this makes sense.
Number of posts : 1037
PostSubject: Re: Brakes and some other questions...   Brakes and some other questions... I_icon_minitimeSun Aug 27, 2017 12:44 pm
I've just changed the front pads on mine last week, after a little bedding in things are much improved. The previous pads still had plenty if meat on them but I suspect they had become slightly contaminated over the god knows how many years.
Anyone know how long the original hoses last?
terrier
terrier
Number of posts : 302
PostSubject: Re: Brakes and some other questions...   Brakes and some other questions... I_icon_minitimeSun Aug 27, 2017 1:34 pm
The correct fluid is DOT 4
LeRoi50
PostSubject: Re: Brakes and some other questions...   Brakes and some other questions... I_icon_minitimeSun Aug 27, 2017 2:16 pm
That is correct, however I have a big bottle of 5.1 and they mix.
Also, the 5.1 has a higher boiling point....but that won't matter to much on a Silverwing I think.
I will bleed the brakes and see what happens, should improve.
Anything special to keep in mind bleeding the brakes on a ABS equipped bike?
As for the skid plate, I just want it off for a few days and be able to get a better look at the possible leak.
If I find it, or not, I will fit it again.
Btw, the brakes aren't dangerous at the moment, could be better though....
» brakes or rather no brakes
» CBS Brakes
» ABS brakes
» Brake pads
» Complete brake failure
