| Original Battery/ New Battery. | |
+3dspevack oldwingguy Silverwingdays 7 posters |
Silverwingdays Scooter Rider
Number of posts : 98 Location : UK Points : 2854 Registration date : 2017-06-05
| Subject: Original Battery/ New Battery. Mon Sep 04, 2017 7:07 pm | |
| I think my 2007 Silverwing is still on its original battery and ( and belt 10K ).
Going to look in at the battery tomorow time allowing and I think get a new one.
Can I just ask is the original one a Yuasa please ?
Also any suggestions for cold cranking/amps etc please would be handy too.
Many Thanks SWD. |
| Subject: Re: Original Battery/ New Battery. Mon Sep 04, 2017 7:14 pm | |
| Not sure about the Yuasa but I sure like my Lithium Ion, a fellow on here suggested it, $99 US delivered from Amazon. I did get almost 7 years out of a Yuasa on one of my G'Wings. |
dspevack Silver Wing Guru
| Subject: Re: Original Battery/ New Battery. Mon Sep 04, 2017 10:33 pm | |
| The original battery is a Yuasa YTZ12. If you want to stick with Yuasa, you can upgrade to the YTZ14 for a little more power. Its the same physical size. For lithium batteries see my post here to understand what is available and why you would use them: https://www.silverwing600.com/t10086-shorai-batteriesThere are other brands that may be available in the UK as well. Dan |
The Bern Silver Wing Expert
| Subject: Re: Original Battery/ New Battery. Tue Sep 05, 2017 5:05 am | |
| This is what I fitted ... http://www.ebay.co.uk/itm/YTZ12S-High-Power-Leoch-Motorcycle-Bike-Battery-Honda-Blackbird-VFR800-NC700-/381999553493?hash=item58f0f29bd5:g:STgAAOSwWxNYwpgS ... Ah & CCA are both higher than OEM original battery which was 16 years old |
| Subject: Re: Original Battery/ New Battery. Tue Sep 05, 2017 5:29 am | |
| Hi Thats it then for me Bern, looks great and in the UK too.
10 years is enough even on a Yuasa.
The starting is getting, not sluggish as such but, just not quite there sort of thing.
Ordering one when I can find another.
Many Thanks People.
Best SWD. |
| Subject: Re: Original Battery/ New Battery. Tue Sep 05, 2017 12:41 pm | |
| Halford's list them -it's where I bought mine.
My dealer supplied different make and although it was supposed to be the same it was a very tight fit and not nice!
| Subject: Re: Original Battery/ New Battery. Wed Sep 06, 2017 8:22 am | |
| Hi wel here is what has come out, actually doesn`t look too bad,
Its a unibat CT12A-BS
Here is what I have bought to replace it
http://www.ebay.co.uk/itm/Leoch-YTZ14S-Motorcycle-Quad-Battery-12V-LTZ14-4/162543448491?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2748.l2649
What do you think, the old one was 10 amp 175 CCraking.
Best SWD
| Subject: Re: Original Battery/ New Battery. Thu Sep 07, 2017 12:24 pm | |
| I swapped my seven year old Yuasa today for the Motobatt battery that's sat on my garage shelf since last year. As I also have a Motobatt Fat Boy charger I'll be now be using it instead of my Optimate.
I'll still give the Yuasa the occasional top up with the Optimate and probably put it back in the Silver Wing when I sell it. |
| Subject: Re: Original Battery/ New Battery. Fri Sep 08, 2017 12:51 am | |
| I've had great luck with Odyssey batteries. Â Not cheap but I don't know how long they last because I never wore one out. They sure will crank a six cylinder Goldwing with verve and vigor. They even make some to MILSPEC. Though those models are expensive and certainly overkill. |
| Subject: Re: Original Battery/ New Battery. Fri Sep 08, 2017 5:32 pm | |
| Well I`m hoping this Leoch one with 230 C Cranking will be good and looks as if it will fit.
Also the amps are right on the new one.
The starting just felt a little less that expected.
Best SWD
