| About our Paint | |
+4Easyrider gremlin bikehiker docjones 8 posters |
docjones Scooter Rider
Number of posts : 52 Age : 58 Location : North Florida Points : 4792 Registration date : 2011-10-12
![About our Paint Empty](https://2img.net/i/empty.gif) | Subject: About our Paint Mon Nov 20, 2017 7:33 pm | |
| I'm pretty sure the colored parts of our scooters aren't painted. Some kind of color injected plastic or something. My problem is there seems to be some sort of light film all over my plastic parts of the scooter. It's as if the Swing was sitting next to a spray booth and clear overspray got all over it. It isn't that bad but feels that way when I try and wax it. Anyone try Mothers Clay bar or something like that. I know these aren't clear coated but I hate swirl marks. Any help would be appreciated. Tom |
bikehiker Silver Wing Rider
![bikehiker](https://2img.net/u/3413/63/00/33/avatars/4857-32.jpg)
Number of posts : 433 Location : New Cumberland PA Points : 3107 Registration date : 2017-09-07
![About our Paint Empty](https://2img.net/i/empty.gif) | Subject: Re: About our Paint Mon Nov 20, 2017 10:00 pm | |
| Clay bar might be useful. Go to an inconspicuous spot on the bike and try some different products: Clay bar, rubbing compound, polishing compound. Maybe even look for one of those new headlight restorer kits.
A good area to try might be the plastic on the underside of the floor board. |
gremlin Super Scooter Rider
![gremlin](https://2img.net/u/3413/63/00/33/avatars/3878-10.jpg)
Number of posts : 227 Age : 72 Location : Brisbane, Australia Points : 3707 Registration date : 2015-04-09
![About our Paint Empty](https://2img.net/i/empty.gif) | Subject: Re: About our Paint Mon Nov 20, 2017 10:37 pm | |
| - docjones wrote:
- I'm pretty sure the colored parts of our scooters aren't painted. Some kind of color injected plastic or something..........Tom
I am pretty sure that you are wrong there; give them a good scratch and you will see the plastic underneath! |
![About our Paint Empty](https://2img.net/i/empty.gif) | Subject: Re: About our Paint Mon Nov 20, 2017 10:39 pm | |
| I believe it is white ABS plastic under the color paint. |
cliffyk Maxi-Scooter Rider
![cliffyk](https://2img.net/u/3413/63/00/33/avatars/4336-36.jpg)
Number of posts : 182 Age : 78 Location : Saint Augustine FL Points : 3239 Registration date : 2016-05-15
![About our Paint Empty](https://2img.net/i/empty.gif) | Subject: Re: About our Paint Mon Nov 20, 2017 11:55 pm | |
| They are most definitely painted... |
The Bern Silver Wing Expert
![The Bern](https://2img.net/u/3413/63/00/33/avatars/3758-23.gif)
Number of posts : 897 Location : Telford, UK Points : 4556 Registration date : 2014-11-20
![About our Paint Empty](https://2img.net/i/empty.gif) | Subject: Re: About our Paint Tue Nov 21, 2017 4:59 am | |
| - docjones wrote:
- I know these aren't clear coated
Odd, they definately are clear coated this side of the pond, as previously stated the base material is ABS plastic, then : Primer Base coat (Silver metallic in my case) Colour coat (Candy Apple Red in my case) Clear coat Reverse side of panels are also painted, this is to protect them from solvents (petrol in particular, which will melt unprotected ABS) although the clear coat is not applied, as no shiney finish is needed on non-visible parts |
![About our Paint Empty](https://2img.net/i/empty.gif) | Subject: Re: About our Paint Tue Nov 21, 2017 8:57 am | |
| Thanks gentlemen, I had no idea. I'll try that area no one ever sees. |
Gustafa Super Scooter Rider
![Gustafa](https://2img.net/u/3413/63/00/33/avatars/4143-55.jpg)
Number of posts : 218 Location : Cordova, TN Points : 3525 Registration date : 2015-10-10
![About our Paint Empty](https://2img.net/i/empty.gif) | Subject: Re: About our Paint Tue Nov 21, 2017 9:38 am | |
| I personally repainted the entire set of furniture (plastic parts) of my silverwing this summer, they are indeed ABS, white and are painted and cleared. It seems like its a one stage shot tho, not two stages. Color and Clear in one. |
![About our Paint Empty](https://2img.net/i/empty.gif) | Subject: Re: About our Paint Tue Nov 21, 2017 6:35 pm | |
| Hope you will show us the end results Gustafa. I've seen a bad paint job on a Swing at one of our local Stealerships. |
janitorj1 Maxi-Scooter Rider
Number of posts : 104 Age : 71 Location : Folkston, GA Points : 3785 Registration date : 2014-09-07
![About our Paint Empty](https://2img.net/i/empty.gif) | Subject: Re: About our Paint Wed Nov 22, 2017 12:25 pm | |
| tooth paste works quite well - not that abrasive - time consuming.
Jon |
| About our Paint | |
