| A service manual! Please | |
+4lloyd193 GeoffM carolina wing rider Raouf 8 posters |
Raouf Scooter Rider
Number of posts : 10 Location : Egypt Points : 2638 Registration date : 2017-09-15
| Subject: A service manual! Please Tue Feb 06, 2018 10:12 am | |
| Hello everyone, I am tired of searching for a service manual for my Silverwing 600 ABS 2007, I dont need a hard copy (book), its too costy for me and + will need shipping to egypt! How can i get an English service manual! a PDF one! |
carolina wing rider Touring Scooter Rider
Number of posts : 305 Age : 70 Location : Mebane NC Points : 2958 Registration date : 2018-01-22
| Subject: Service Manual Tue Feb 06, 2018 10:44 am | |
| Take a look at ebay item #302465298051. Maybe this will work for you. |
GeoffM Scooter Rider
Number of posts : 25 Age : 70 Location : Westbury, Wiltshire, U.K. Points : 2535 Registration date : 2018-01-15
| Subject: Re: A service manual! Please Tue Feb 06, 2018 11:48 am | |
| - carolina wing rider wrote:
- Take a look at ebay item #302465298051. Maybe this will work for you.
Damn.... I wish I'd seen that before I bought a printed copy. |
| Subject: Re: A service manual! Please Tue Feb 06, 2018 12:08 pm | |
| Yeah....................me too. |
Raouf Scooter Rider
| Subject: Re: A service manual! Please Sat Feb 10, 2018 2:55 pm | |
Number of posts : 327 Age : 84 Location : Orlando Fl. USA Points : 3311 Registration date : 2017-05-13
| Subject: Re: A service manual! Please Sat Feb 10, 2018 3:06 pm | |
| - Raouf wrote:
- Thank you very very much
Raouf, The Honda service manual is online. Type Honda service manual FSC600 Silverwing into your search engine, When it comes up you will see the index. You will have to maneuver around until you find what you are looking for. scroll down until you reach the desired section, It can be printed out if you want for free. Happy motoring Lloyd 193. |
Raouf Scooter Rider
| Subject: Re: A service manual! Please Fri Feb 16, 2018 2:05 pm | |
| Hello lloyd, I searched again and get no results! If you could help with direct link or you could send me by mail, i'll be much grateful.. If this is not banned by forum rules for sure |
Raouf Scooter Rider
| Subject: Re: A service manual! Please Fri Feb 16, 2018 2:09 pm | |
| Anyone help when to change the clutch outer bell My swing have 39k km used and now idea if the bell was changed by previous owner or not! Is there is indicated milage interval to change! How i know its time to change, I am considering changing the belt and rollers and clutch pads soon, should i am confused about the bell alsi,
Much appreciated for help! |
The Bern Silver Wing Expert
| Subject: Re: A service manual! Please Fri Feb 16, 2018 3:00 pm | |
| It's not a normal service item bud, there is a dimension check though ....
Standard internal diameter 160 - 160.2 mm (6.30 -6.31 inhes)
Service limit .................. 160.5 mm (6.32 inches) |
| Subject: Re: A service manual! Please Fri Feb 16, 2018 5:48 pm | |
| Unless the clutch pads are completely worn down and clutch bell is deeply grooved than at 39k km it is very doubtful that it will need replacing. |
Raouf Scooter Rider
| Subject: Re: A service manual! Please Sat Feb 17, 2018 8:12 am | |
| Okay thanks, I’ll measure it |
| Subject: Re: A service manual! Please Sat Feb 17, 2018 9:39 pm | |
| Raouf, Why were you concerned about you bell and clutch pads? If your bike is making squealing sounds when starting, you need to deglaze the clutch. Easiest way is to lock the hand brake, hold the left brake handle tight and run the engine to 4000k RPM for 4 seconds. To lessen the chance of it happening again, try a faster start from start. Don't baby it. DISCLAIMER ***** Do this procedure at your own risk.
Another way is to remove the clutch housing from the bell. Check for grooves in the bell and sand smooth. Replace if badly worn. Sand/replace the clutch pads also. Good luck. |
amnaguib Scooter Rider
Number of posts : 1 Location : Egypt Points : 3433 Registration date : 2015-06-26
| Subject: Re: A service manual! Please Thu Oct 04, 2018 7:25 am | |
| Raouf,
Have you managed to get a soft copy from the manual.
Thanks, Naguib |
