Change brake pads on reflex 250 (2002) I_icon_minitimeby zrx212 Yesterday at 4:40 pm
Change brake pads on reflex 250 (2002) I_icon_minitimeby Meldrew Yesterday at 4:37 pm
Change brake pads on reflex 250 (2002) I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Change brake pads on reflex 250 (2002) I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Change brake pads on reflex 250 (2002) I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Change brake pads on reflex 250 (2002) I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Change brake pads on reflex 250 (2002) I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Change brake pads on reflex 250 (2002) I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Change brake pads on reflex 250 (2002) I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Change brake pads on reflex 250 (2002) I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
3 posters
KniteMare
Number of posts : 4
Registration date : 2009-10-17
Change brake pads on reflex 250 (2002) Empty
PostSubject: Change brake pads on reflex 250 (2002)   Change brake pads on reflex 250 (2002) I_icon_minitimeThu Dec 03, 2009 4:19 pm
I would like to know how to do this before I remove the wrong bolts. Can anyone help. I can find nothing on the net to guide me.
Number of posts : 2778
PostSubject: Re: Change brake pads on reflex 250 (2002)   Change brake pads on reflex 250 (2002) I_icon_minitimeFri Dec 04, 2009 9:36 am
Hi KniteMare,
I'm sure someone here has a shop manual for a Honda 250 Reflex that can help you.
Maybe not. Change brake pads on reflex 250 (2002) Icon_pale
Sometimes I go to the Honda dealerships web pages. They have illustrations and parts lists of different assemblies on scooters to look at.
You might just take a look.
Front Brake: http://www.hondaoftulsa.com/fiche_section_detail.asp?section=153505&category=SCOOTERS&make=HONDA&year=2002&fveh=3565
Back Brake: http://www.hondaoftulsa.com/fiche_section_detail.asp?section=153507&category=SCOOTERS&make=HONDA&year=2002&fveh=3565
I hope this helps.
KniteMare
Number of posts : 4
PostSubject: Reflex brakes   Change brake pads on reflex 250 (2002) I_icon_minitimeWed Dec 09, 2009 11:48 pm
That was exactly what I was looking for. I have built many bikes just from the manual so now that I can see the exploded view it will be no problem
Thanks so much!
MaxB
MaxB
Number of posts : 302
PostSubject: Re: Change brake pads on reflex 250 (2002)   Change brake pads on reflex 250 (2002) I_icon_minitimeFri Dec 11, 2009 9:50 pm
Be careful on the back piston, it is part of the parking brake ass'y. To get the piston back in to fit new brake pads you need to screw it in, not just press it back in. I forget which way to turn it. It has to do with the parking brake. There are all kinds of little pieces inside the piston. It has a big cross hatch on it and I used a piece of 3/16 flat stock to turn it.
If changing or bleeding brakes on the back (left grip) bleed the front first piston (the middle part of front brake, lower bleeder)then the back piston.
DO NOT ALLOW RES TO GET LOW!!!!!!!!!!!!! It is a pain to get the air out of the lines then. Usually an air bubble gets caught in the banjo bolt at the handlebars.
Hope this helps
MaxB
KniteMare
Number of posts : 4
PostSubject: Re: Change brake pads on reflex 250 (2002)   Change brake pads on reflex 250 (2002) I_icon_minitimeFri Dec 11, 2009 11:08 pm
OK, I will begin this project tommorow. I will take pictures to post so that the next person can see the process.
Any other tips, suggestions, cautions??
Thanks
Brian
» 2002 Honda Reflex 250cc ABS
» rear brake lever locks up ?
» Brake pads
» New brake pads
» Brake pads.
Honda Silver Wing Scooter Forum :: Other Scooters and Motorcycles :: Other Scooter Topics-
