| Subject: A Question of Dimension Fri Jul 13, 2018 8:13 am | |
| 'Can anyone tell me the size from the exhaust manifold to where it joins the silencer please?' I suppose he could have measured it but.......! Thanks in advance. |
The Bern Silver Wing Expert
| Subject: Re: A Question of Dimension Fri Jul 13, 2018 8:48 am | |
| Exhaust Connection Gasket (Inner: 35mm, Outer: 41mm, Height: 25mm) so exhaust pipe is 35mm outside diameter bud.
Info taken from .... https://tinyurl.com/y7lz6gfx |
| Subject: Re: A Question of Dimension Fri Jul 13, 2018 9:21 am | |
| To add to the confusion; I just mic'd the pipe end od at 31.5mm
[ Edit ] Bern, that's a mighty odd illustration for the application of that gasket. |
| Subject: Re: A Question of Dimension Fri Jul 13, 2018 12:15 pm | |
| Thanks; I'll pass it on. |
| Subject: Re: A Question of Dimension Sat Jul 14, 2018 9:00 am | |
- To add to the confusion; I just mic'd the pipe end od at 31.5mm
[ Edit ] Bern, that's a mighty odd illustration for the application of that gasket. Hi Tim, following your post I've just been down & measured mine & it comes in at 31.86mm Heyho best not to believe all they say in adverts on the internet, odd though as I tried the drop downs & it listed SilverWing as fitting as you say odd illustration bud |
| Subject: Re: A Question of Dimension Sat Jul 14, 2018 9:03 am | |
| - MikeO wrote:
- Thanks; I'll pass it on.
Hi Mike. I've posted an apology & corrected info on the MM farcebook page (presuming it was him you were talking to) |
