Lights and fuses I_icon_minitimeby zrx212 Yesterday at 4:40 pm
Lights and fuses I_icon_minitimeby Meldrew Yesterday at 4:37 pm
Lights and fuses I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Lights and fuses I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Lights and fuses I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Lights and fuses I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Lights and fuses I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Lights and fuses I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Lights and fuses I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Lights and fuses I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
 Lights and fuses
2 posters
Lugwrench
Number of posts : 37
Registration date : 2018-08-15
Lights and fuses Empty
PostSubject: Lights and fuses   Lights and fuses I_icon_minitimeWed Oct 24, 2018 4:31 pm
Its me again. Well my low beam headlight is out on my2002swing. SO where to buy replacement. HL 55. And other bulbs that one might need. Fuses are pretty straight forward.
Thanks Lugwrench
Number of posts : 1384
PostSubject: Re: Lights and fuses   Lights and fuses I_icon_minitimeWed Oct 24, 2018 5:15 pm
Any auto store will have the bulb. H7 is high and low beam bulb. Unless 02 is different mine takes H7 bulb. What is HL 55.??
Lugwrench
PostSubject: Re: Lights and fuses   Lights and fuses I_icon_minitimeWed Oct 24, 2018 5:20 pm
HL 55 is typo error.
PostSubject: Re: Lights and fuses   Lights and fuses I_icon_minitimeWed Oct 24, 2018 5:54 pm
OK Plastic cover above light needs to be removed for low beam. Screws and some tabs. 2 from behind windshield and 2 in the vent from front side. PRY it loose gently and remove it. Its tight in there.
Remove connector then rubber boot. Small metal retainer holds the bulb into housing push it in to unhook it then it swings on a hinge out of way. There is a plastic spacer on back of bulb pull it off and install on new bulb. Hardest part is getting that wire retainer hooked back into headlight housing.
Take your time. Get a good flash light to see how that wire is hooked in headlight housing.
Lights and fuses
» Keep Blowing Fuses
» LED lights
» Aux. Lights (LED)
» Hazard lights?
» Accent lights
