| Subject: LARGE, Dual Flag Mount for the Silverwing? Wed Dec 30, 2009 9:19 pm | |
| Hi All, Been tossing this around. Would anybody be interested in a large, dual flag mount for the Silverwing? It would be based on the same mounting bolt locations as the trailer hitch. Flags would be 3' x 5' on a 6' flag pole. The base of the flag poles would be pined in place on steel studs and the mid point of the flag pole would be supported and slide through eye bolts welded to a support bracket system attached onto the bottom of the spoiler. You can install larger flags but you would need a longer flag pole. Let me know....I'll make one so you can see it. This should work good. I know some of you want foot rests...It's just to darn cold on the shop floor right now. |
| Subject: Re: LARGE, Dual Flag Mount for the Silverwing? Wed Dec 30, 2009 11:21 pm | |
| - DennisB wrote:
- Would anybody be interested in a large, dual flag mount for the Silverwing?
It would be based on the same mounting bolt locations as the trailer hitch. Flags would be 3' x 5' on a 6' flag pole. The base of the flag poles would be pined in place on steel studs and the mid point of the flag pole would be supported and slide through eye bolts welded to a support bracket system attached onto the bottom of the spoiler. You can install larger flags but you would need a longer flag pole. Let me know....I'll make one so you can see it. This should work good. This sounds familar . I would like to see a picture. |
| Subject: Re: LARGE, Dual Flag Mount for the Silverwing? Thu Dec 31, 2009 8:41 am | |
| Bill, If I don't get at least 10 people interested in this large dual flag set-up then I'm not going to spend the time or money to develop it any further. |
| Subject: large dual flag set-up Sat Mar 27, 2010 10:46 am | |
| Yes I would be interested in the dual flag set-up for my 2009 SW. |
| Subject: Re: LARGE, Dual Flag Mount for the Silverwing? Sat Mar 27, 2010 11:05 am | |
| Hi George, Welcome aboard the forum. OK...That makes 2 of you for the large flag mount. |
