- ronjr009 wrote:
- I know some of you guys probably have this back rest. Do any of you know if this rest will work with other boxes (other than Givi) mounted on the back of the swing.
Have you tried the Givi E95S gel pad??
The Givi TB-19 was mounted underneath the Givi SR-19 mount.
So there would be a couple of concerns
1) The non-Givi mount should not be longer (forward) than the Givi SR-19 ... otherwise the non-Givi mount would have to be move further back to allow the SR-19 to mount with 6 holes versus the normal 4 holes.
2) Some of the early Givi boxes could
not open without interference from the TB-19. Only some of the later designed Givi topboxes work properly. So non-Givi boxes could run into the same interference ... and unless someone tries and documents then you would have to experiment.
Another option may be to order DennisB arm rests and hang/position a good quality detachable foam pad to the arm rests. Then when the arm rest are lifted it could life the hanging foam pad .... just a thought.
