| Front brake noise | |
+5Lost it oldwingguy Osprey The Bern Mrmoz 9 posters |
Mrmoz Scooter Rider
Number of posts : 32 Location : Uk Points : 2254 Registration date : 2018-08-23
![Front brake noise Empty](https://2img.net/i/empty.gif) | Subject: Front brake noise Wed Jun 05, 2019 1:48 pm | |
| Hi guys since its winter strip down and mini refurbishment the bike has developed a noise when braking. Its only when I use the front brake' and its revolution based ie the quicker the bike is traveling the more quickly the noise appears. So new pads went in over winter and initially no problem but now the noise is driving me mad. Warped disc is my only answer but when I use the back brake which also dose the front no noise and I proper squeeze the back so the front dives under braking and no noise absolutely nothing. So why when I use the front I get this warped disc noise. Grrrrr |
The Bern Silver Wing Expert
![The Bern](https://2img.net/u/3413/63/00/33/avatars/3758-23.gif)
Number of posts : 897 Location : Telford, UK Points : 4556 Registration date : 2014-11-20
![Front brake noise Empty](https://2img.net/i/empty.gif) | Subject: Re: Front brake noise Wed Jun 05, 2019 3:32 pm | |
| I bet you've used a sintered pad rather the a 'natural' ? |
Mrmoz Scooter Rider
![Front brake noise Empty](https://2img.net/i/empty.gif) | Subject: Re: Front brake noise Wed Jun 05, 2019 3:40 pm | |
| But how come there is no noise when I use the back brake on its own I know the front pads are being pressed against the disc because the front dips ![:unamused: 😒](https://cdn.jsdelivr.net/emojione/assets/png/1f612.png?v=2.2.7) |
![Front brake noise Empty](https://2img.net/i/empty.gif) | Subject: Re: Front brake noise Wed Jun 05, 2019 3:56 pm | |
| Because by using the rear brake you are reducing the pressure applied between the pads & the disc (compared to the front lever) reduced pressure will increase the disc temperature, which will bring it closer to the operating temperature of sintered pads. |
Mrmoz Scooter Rider
![Front brake noise Empty](https://2img.net/i/empty.gif) | Subject: Re: Front brake noise Wed Jun 05, 2019 4:03 pm | |
| Well I've just bought some organic pads of ebay il fit them and see how I go on if problem/noise is still there its got to be the disc. |
Osprey Maxi-Scooter Rider
Number of posts : 113 Location : Northern NH Points : 2399 Registration date : 2018-06-30
![Front brake noise Empty](https://2img.net/i/empty.gif) | Subject: Re: Front brake noise Wed Jun 05, 2019 7:38 pm | |
| Please excuse my intrusion. What in the world is a sintered brake pad? Just want to keep on learnin' ![Smile](https://2img.net/i/fa/i/smiles/icon_smile.gif) |
![Front brake noise Empty](https://2img.net/i/empty.gif) | Subject: Re: Front brake noise Wed Jun 05, 2019 9:58 pm | |
| Another different compound, ceramic, sintered, organic pads, the IMPORTANT thing is using the correct pad for the rotor you are using, pad / rotor matches for proper wear and stopping power.
https://r.search.yahoo.com/_ylt=A0geK.D9cvhcmKoAy0ZXNyoA;_ylu=X3oDMTBybGY3bmpvBGNvbG8DYmYxBHBvcwMyBHZ0aWQDBHNlYwNzcg--/RV=2/RE=1559815038/RO=10/RU=https%3a%2f%2fwww.worldwidecyclery.com%2fblogs%2fworldwide-cyclery-blog%2fmountain-bike-brake-pads-sintered-vs-organic/RK=2/RS=pfcn4xlUWAnqvQFrbjeSlaTkmls- |
Mrmoz Scooter Rider
![Front brake noise Empty](https://2img.net/i/empty.gif) | Subject: Re: Front brake noise Thu Jun 06, 2019 3:50 am | |
| Supurb explanation from these guys https://youtu.be/yWtH5a-QDvE |
![Front brake noise Empty](https://2img.net/i/empty.gif) | Subject: Re: Front brake noise Thu Jun 06, 2019 6:40 am | |
| Apologies for the brief explanation but I'm just back from hospital (without pnuemonia ![Smile](https://2img.net/i/fa/i/smiles/icon_smile.gif) ) it's as oldwingguy said ..... - oldwingguy wrote:
- the IMPORTANT thing is using the correct pad for the rotor you are using, pad / rotor matches for proper wear and stopping power.
.... thanks bud :Happy Holiday: I'm gonna blame the morphine that's still in my system for this bit ![Laughing](https://2img.net/i/fa/i/smiles/icon_lol.gif) >>>>>>>>>>>> ![Front brake noise 60654630_2174734652616822_7110663433380429824_n.jpg?_nc_cat=101&_nc_ht=scontent.flhr3-1](https://scontent.flhr3-1.fna.fbcdn.net/v/t1.0-9/60654630_2174734652616822_7110663433380429824_n.jpg?_nc_cat=101&_nc_ht=scontent.flhr3-1.fna&oh=526d8b55d5fd673de6c814c1130be045&oe=5D92F990 ) |
![Front brake noise Empty](https://2img.net/i/empty.gif) | Subject: Re: Front brake noise Thu Jun 06, 2019 7:31 am | |
| - Mrmoz wrote:
- Well I've just bought some organic pads of ebay il fit them and see how I go on if problem/noise is still there its got to be the disc.
One other bit, SOME pads will benefit ( EBC ) for one if you take a file and knock the sharp edges off the new pad, don't know why for sure but it helped with some I've installed. |
Lost it Maxi-Scooter Rider
Number of posts : 136 Age : 67 Location : Hayling Island UK Points : 2095 Registration date : 2019-05-13
![Front brake noise Empty](https://2img.net/i/empty.gif) | Subject: Re: Front brake noise Thu Jun 06, 2019 9:11 am | |
| Sintered pads do "sing". They also wear out the disc slightly faster. |
Mrmoz Scooter Rider
![Front brake noise Empty](https://2img.net/i/empty.gif) | Subject: Re: Front brake noise Thu Jun 06, 2019 9:14 am | |
| I hope it is just sintered pads making that awful noise and these ebc organic pair will be quieter no bothered if they wear out quicker there only a tenner ![:blush: 😊](https://cdn.jsdelivr.net/emojione/assets/png/1f60a.png?v=2.2.7) |
![Front brake noise Empty](https://2img.net/i/empty.gif) | Subject: Re: Front brake noise Thu Jun 06, 2019 9:45 am | |
| I use OEM pads----Honda already figured everything out. Over 90,000 miles with 2 new SilverWings, never had to replace pad or pads.
Winter Tip: I squirt salt/dirt out/off with water hose.
![Front brake noise Empty](https://2img.net/i/empty.gif) | Subject: Re: Front brake noise Thu Jun 06, 2019 2:19 pm | |
| As do I on the Viffer. Last longer too. The organic ones are very dusty, used them on my Deauville when I had that. Good for about 10,000 miles of London commuting. But they gripped well. |
Vyacheslav Scooter Rider
![Vyacheslav](https://2img.net/u/3413/63/00/33/avatars/4931-74.jpg)
Number of posts : 26 Age : 49 Location : Russia, Sverdlovsk region, Severouralsk Points : 2462 Registration date : 2018-01-17
![Front brake noise Empty](https://2img.net/i/empty.gif) | Subject: Re: Front brake noise Sat Jun 08, 2019 12:15 pm | |
| You may have a buzz if you put the SPRING PAD wrong. There will be a strong iron creak about the brake disc. ![Front brake noise <a href=](<a href=) ![Front brake noise Ba58c8d6db88](https://b.radikal.ru/b04/1906/3c/ba58c8d6db88.jpg) " /> |
Mrmoz Scooter Rider
![Front brake noise Empty](https://2img.net/i/empty.gif) | Subject: Re: Front brake noise Sun Jun 09, 2019 2:32 pm | |
| Not sure about that picture above I can't recall my caliper looking like that what's them teeth? Anyway many thanks to the Bern as my new organic pads are whisper quiet never again will I buy sintered pads again for the swing |
![Front brake noise Empty](https://2img.net/i/empty.gif) | Subject: Re: Front brake noise Sun Jun 09, 2019 3:20 pm | |
| - Mrmoz wrote:
Anyway many thanks to the Bern as my new organic pads are whisper quiet My pleasure bud, we're all here to help each other where we can, I just happened along first on this occasion :Happy Holiday: |
![Front brake noise Empty](https://2img.net/i/empty.gif) | Subject: Re: Front brake noise Mon Jun 10, 2019 1:25 pm | |
| Do organic pads cause more brake dust on the rim as compared to metalic? |
![Front brake noise Empty](https://2img.net/i/empty.gif) | Subject: Re: Front brake noise Mon Jun 10, 2019 9:44 pm | |
| Brake dust is minimal with any pad wheels just get dirty from road dirt. Rear wheel is always dirtier than front because front picks it up and lands on the rear. Front does most of braking and it's cleaner?
I've seen some cars with black nasty front wheels from brake dust but driven hard and rarely washed.
