gklugie Scooter Rider
Number of posts : 10 Location : Garland, Texas Points : 1958 Registration date : 2019-08-03
| Subject: EMS Module Interchangability question Mon Aug 19, 2019 4:41 pm | |
| Are ECM modules interchangable between different years? Are ECM modules interchangable between ABS/non_ABS? |
| Subject: Re: EMS Module Interchangability question Mon Aug 19, 2019 11:34 pm | |
| Best to check and cross reference part #'s thru a reliable source. Like Partzilla: https://www.partzilla.com/catalog/honda/scooter Or Service Honda: https://www.servicehonda.com/oemparts/c/honda_scooter/parts
While both use the same Honda parts list sometimes one will have more in-depth info than the other.
And sometimes if you 'select' one ECU the following page will show the interchangeable models & years.
Sometimes too a later version of a part will sub for an earlier part but not necessarily vise versa. It would help you to know the part # of the other ECU you've located --not take the sellers word that it's for such & such year. The part # is usually on a label on the ECU.
| Subject: Re: EMS Module Interchangability question Tue Aug 20, 2019 8:28 am | |
