Engine inspection I_icon_minitimeby zrx212 Yesterday at 4:40 pm
Engine inspection I_icon_minitimeby Meldrew Yesterday at 4:37 pm
Engine inspection I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Engine inspection I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Engine inspection I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Engine inspection I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Engine inspection I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Engine inspection I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Engine inspection I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Engine inspection I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
 Engine inspection
Lugwrench
Lugwrench
Number of posts : 37
Registration date : 2018-08-15
Engine inspection Empty
PostSubject: Engine inspection   Engine inspection I_icon_minitimeWed Jan 01, 2020 12:01 pm
Hello all and Happy New Year.
I need to inspect my engine on swing and am curious about how difficult and how much do I remove just to get a good look at engine. Still chasing a oil leak. too damm old to look underneath.
any thoughts from the gurus.
Number of posts : 4218
PostSubject: Re: Engine inspection   Engine inspection I_icon_minitimeWed Jan 01, 2020 12:26 pm
Happy New Year. An easy way of looking underneath the Silver Wing for leaks is placing a cheapo mirror tile on the floor under the engine, and shining an inspection lamp or LED torch up around where you want to look at. I've got a long plastic IKEA mirror tile I use and it works great still with it's protective wrapper on.
PostSubject: Re: Engine inspection   Engine inspection I_icon_minitimeThu Jan 02, 2020 12:01 am
Hey Lugwrench, at your advanced age you need a Harbor Freight bike lift. I got one several year ago. It's been a great boon to this old geezer, I've had several Goldwings up on it, as well as my K1100LTs and the Silver Wing, C650GT, Burgman and a scattering of Chinese scooters. No more difficulties getting down on the floor to adjust things and change oil. Even makes checking pressure in the rear tire on the Silverwing easy.
One hint for that rear tire pressure checking. Get a pair of hex type tire valve caps, and then a socket with an extension that will fit them. That will make getting that cap on and off the valve stem with ease. Use a Truck type valve adapter on you air source and you're all set to make that job a snap.
https://www.amazon.com/Valve-Loc-Universal-Motorcycles-Heavy-Duty-Light-Weight/dp/B07KN542B2?psc=1&SubscriptionId=AKIAILSHYYTFIVPWUY6Q&tag=duckduckgo-ffnt-20&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B07KN542B2
https://www.amazon.com/CZC-AUTO-Inflatable-Compatible-Accessories/dp/B07QNNDBLQ/ref=sr_1_3?crid=22FSELKKX4LR2&keywords=tire+inflator+extension&qid=1577941262&s=automotive&sprefix=tir+inflator+e%2Cautomotive%2C240&sr=1-3
Sepp
Number of posts : 126
Registration date : 2019-10-09
PostSubject: Re: Engine inspection   Engine inspection I_icon_minitimeSat Jan 04, 2020 7:40 pm
maybe my blog post can be of assistance to give you an idea where is what.
https://hosiwi.blogspot.com/2019/11/honda-swt-400-propulsion-unit-and-naked.html
PostSubject: Re: Engine inspection   Engine inspection I_icon_minitimeSat Jan 04, 2020 9:32 pm
I felt a little embarrassed looking at some of those pictures that verged on racy.
Number of posts : 1935
PostSubject: Re: Engine inspection   Engine inspection I_icon_minitimeSun Jan 05, 2020 10:39 am
Smile mirror mirror on the floor
lets you see
a whole lot more.
And a mirror on a stick will certainly do the trick.
Number of posts : 1384
PostSubject: Re: Engine inspection   Engine inspection I_icon_minitimeSun Jan 05, 2020 7:57 pm
Mirror on the celling lets you see a whole lot more just depends on your position. What were we talking about? Smile
Sepp
PostSubject: Re: Engine inspection   Engine inspection I_icon_minitimeMon Jan 06, 2020 7:06 am
How do you inspect an engine with a mirror on the floor? the only thing you might see is some oil.
Remove the service flap and take out the spark plugs, take off the transmission cover so you can rotate the driving pulley and put a camera down the cylinder.
One of the first things I did, but forgot to rotate the pistons so I could have a longer viewing area.
So I saw only to top of the pistons and not the cylinder side wall. (Next time)
https://hosiwi.blogspot.com/2019/11/honda-swt-400-personal-log.html#more
PostSubject: Re: Engine inspection   Engine inspection I_icon_minitimeMon Jan 06, 2020 7:20 am
That's good Sepp but he is only looking for an external oil leak, if the source isn't EZ to spot by just looking without raising the bike mirrors make the job easier for sure.
Engine inspection
» Valve Inspection
» Inspection on our Silverwings
» So I took the bike for an inspection....
»  Yearly Inspection
» Coolant Inspection
